I based this blueprint on a couple of other ZHA blueprints for this device:
Feel free to mix and match, these are the features that my blueprint has that I couldn’t figure out in the other blueprints:
- each button can be associated with multiple lights. It will toggle all the lights in the same way a light group works: if at least one is on, it turns them all off, and if they are all off, it turns them all on.
- a light can be associated with more than one button. You could use buttons 1-3 for individual lights and button 4 for all 3 lights at once.
- the dimmer dial controls the brightness only for the lights that are currently on. If you turn on a light with button 1, then another one with button 2, you can then use the dial to dim up or down only these two
- as a bonus, if none of the lights is on, the dimmer dial dims up all the lights associated with the 4 buttons starting from 0.
- Edit: added an event emitted for each light that is toggled. I use that event to suspend motion activation for the lights when switched on.
blueprint:
name: Hue tap dial switch
description: Control multiple lights with a Hue tap dial switch
source_url: https://github.com/GordonFreemanK/ha-blueprints/blob/main/hue_tap_dial_switch.yaml
domain: automation
input:
switch:
description: The switch that will trigger the automation
selector:
device:
integration: zha
manufacturer: Signify Netherlands B.V.
model: RDM002
multiple: false
button_1_lights:
name: Button 1 lights
description: The lights to toggle with Button 1
selector:
entity:
domain: light
multiple: true
button_2_lights:
name: Button 2 lights
description: The lights to toggle with Button 2
selector:
entity:
domain: light
multiple: true
default: []
button_3_lights:
name: Button 3 lights
description: The lights to toggle with Button 3
selector:
entity:
domain: light
multiple: true
default: []
button_4_lights:
name: Button 4 lights
description: The lights to toggle with Button 4
selector:
entity:
domain: light
multiple: true
default: []
brightness:
description: The brightness to turn on the lights at
selector:
number:
min: 0
max: 100
unit_of_measurement: '%'
default: 80
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input switch
variables:
command: "{{ trigger.event.data.command }}"
button_1_lights: !input button_1_lights
button_2_lights: !input button_2_lights
button_3_lights: !input button_3_lights
button_4_lights: !input button_4_lights
- choose:
- conditions: "{{ command == 'recall' }}"
sequence:
- variables:
scene: "{{ trigger.event.data.args[1] }}"
lights: >
{% if scene == 1 %}
{{ button_1_lights }}
{% elif scene == 0 %}
{{ button_2_lights }}
{% elif scene == 5 %}
{{ button_3_lights }}
{% elif scene == 4 %}
{{ button_4_lights }}
{% endif %}
state: "{{ expand(lights) | selectattr('state','eq','on') | list | length > 0 }}"
- if:
- condition: template
value_template: "{{ state }}"
then:
- service: light.turn_off
entity_id: "{{ lights }}"
else:
- service: light.turn_on
brightness_pct: !input brightness
- repeat:
for_each: "{{ lights }}"
sequence:
- event: light_toggled
event_data:
state: "{{ not state }}"
entity_id: "{{ repeat.item }}"
- conditions: "{{ command == 'step_with_on_off' }}"
sequence:
- variables:
step_mode: "{{ trigger.event.data.params.step_mode }}"
step_size: "{{ trigger.event.data.params.step_size }}"
- choose:
- conditions: "{{ step_mode == 'StepMode.Up' }}"
sequence:
- variables:
lights: >
{% set lights_all = expand([button_1_lights, button_2_lights, button_3_lights, button_4_lights]) %}
{% set lights_on = lights_all | selectattr('state','eq','on') | list %}
{% set lights_used = lights_on if lights_on | length > 0 else lights_all %}
{{ lights_used | map(attribute='entity_id') | unique | list }}
brightness_step_pct: "{{ step_size }}"
transition: 1
- conditions: "{{ step_mode == 'StepMode.Down' }}"
sequence:
- variables:
lights: >
{{ expand([button_1_lights, button_2_lights, button_3_lights, button_4_lights])
| unique
| list }}
brightness_step_pct: '{{ -step_size }}'
transition: 1
