I am currently changing from Deconz to ZHA (with the Conbee2) and would also like to be able to adjust the settings for my sensors here. But I can’t find my way around. Unfortunately, I didn’t find any simple documentation.
So sensitivity and delay.
Can someone tell me which clusters/attributes I have to set and how if I want to change the delay from 8sec (default, I think) to 30 seconds? This also saves energy…
My motion settings only version is below. It was always a quick and dirty job, not meant for public consumption, but I don’t think can do any lasting harm.
YMMV. Use at your own risk.
blueprint:
name: SML001 Sensitivity and Timeout
description: |
The basic occupancy sensor automation does the following:
The sets the sensor attributes when Home Assistant boots
domain: automation
input:
occupancy_entity:
description: "The occupancy sensor to use for this automation"
selector:
entity:
domain: binary_sensor
device_class: occupancy
ieee_id:
name: Occupancy Sensor Zigbee IEEE ID
description: "The zigbee network id of the sensor"
selector:
text:
o_to_u_delay:
name: Occupied to Unoccupied delay
description: |
Set the time in seconds we require the light(s) to stay on.
This delay is reset each time motion is detected.
default: 180
selector:
number:
min: 10
max: 600
step: 5
#mode: box
unit_of_measurement: "seconds"
sensitivity:
name: Sensitivity of sensor
description: |
Set how sensitive we want the sensor to be: 0 = least sensitive
NOTE: Restart Home Assistant on changing this value
default: 2
selector:
number:
min: 0
max: 2
# The automation
variables:
ieee_id: !input ieee_id
# Trigger mode
mode: single
# Trigger
# When HA starts
- platform: homeassistant
event: start
# Actions
# TODO: Figure out how to get ieee address of sensor from entity
- alias: "What caused the trigger?"
choose:
- conditions:
- condition: template
value_template: "{{ true }}"
sequence:
# Set device occupancy off delay
- service: zha.set_zigbee_cluster_attribute
ieee: "{{ ieee_id }}"
endpoint_id: 2
cluster_id: 0x0406
cluster_type: in
attribute: 0x0010
value: !input o_to_u_delay
# Set device sensitivity
endpoint_id: 2
cluster_id: 0x0406
cluster_type: in
attribute: 0x0030
value: !input sensitivity
default: []
