First I want to say thank you for this blueprint its awesome!! Is it possible to make a triple press option or more if wanted? just curious of the limitations. Thanks again
I second this. I’d also love to have this Blueprint (or similar) for Zigbee2mqtt.
Is it possible to [fairly] easily convert this Blueprint from ZHA to Zigbee2mqtt? What changes would need to be made? (Willing to do the research if I can get pointed in the right direction.)
Hi. I’ve been having issues with controlling lights with the Smartthings button. If the light is on already, it will turn the light off for a few seconds then turn it back on but if I press it again it turns it off. Other times if the light is off, it will turn the light on then off again, and if I press it again it will turn on again. Any help you can provide would be great. Thank you for your time
I have 2 SmartThings buttons and the one that gets used less does this from time to time. The other doesn’t. For me, it seems to happen when they drop off the network and pop back on randomly.
Hi, i have been using this blueprints for 2 years without any trouble. Fished out a couple of a drawer to use them. And now i can not for the life of me save the new blueprint setup. Have tried to duplicate an old one for a new button. But still same result. After searching around i see that there may be some problems with some blueprints in later time. Does anyone have similar problems?
Is this about the Aeotec Samjin button? it looks exactly like pictured above.
I had it paired with ZHA, but because I also run Zigbee2mqtt - i had RF issues, so i de-installed my ZHA controller. Now I cannot get this button to pair with my zigbee2mqtt - although that runs fine for all other functions and is very stable.
what i do; take out battery. set Z2M in pairing mode
put in battery. push and hold the pinhole until led blinks green/red
