I believe I made big mistake. I attempted to restore to prior to the update. when that didnt work, I deleted the integrations, assuming I would be able to easily set up again. Now, this is where I am.
I did try to search the “all hardware” for product name but that didnt seem to work. I am currently trying to set up the zigbee through ZHA. I see the silicon labs (Nortek) when I select the device,
![2022-10-25 - Screen Shot 2022-10-25 at 3.37.14 PM](https://community-assets.home-assistant.io/original/4X/3/5/3/3530598ee278a4e5db874c142c87b38ce6a402f2.png)
i get the “serial Port Settings” window.
![2022-10-25 - Screen Shot 2022-10-25 at 3.39.57 PM](https://community-assets.home-assistant.io/original/4X/9/5/9/959d22902aa46f76c50ac0f8f84d41bacb6e7a4c.png)
When I select submit I get this error message.
So, I am stuck.
Also, when I attmpt to reinstall ZWAVE JS, i get an error as well.
here is the log error I get after restoring and ZHA failing to set up:
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:172
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 3:49:47 PM (3 occurrences)
Last logged: 3:49:54 PM
Couldn’t start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 1 of 3)
Couldn’t start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 2 of 3)
Couldn’t start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 3 of 3)
File “/usr/local/lib/python3.10/site-packages/serial/serialposix.py”, line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_11600383-if01-port0’
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 172, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 144, in new
await app.startup(auto_form=auto_form)
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 124, in startup
await self.connect()
File “/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py”, line 124, in connect
self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
File “/usr/local/lib/python3.10/site-packages/bellows/ezsp/init.py”, line 103, in initialize
await ezsp.connect()
File “/usr/local/lib/python3.10/site-packages/bellows/ezsp/init.py”, line 120, in connect
self._gw = await bellows.uart.connect(self._config, self)
File “/usr/local/lib/python3.10/site-packages/bellows/uart.py”, line 382, in connect
protocol, connection_done = await thread.run_coroutine_threadsafe(
File “/usr/local/lib/python3.10/site-packages/bellows/uart.py”, line 361, in _connect
transport, protocol = await zigpy.serial.create_serial_connection(
File “/usr/local/lib/python3.10/site-packages/zigpy/serial.py”, line 37, in create_serial_connection
transport, protocol = await pyserial_asyncio.create_serial_connection(
File “/usr/local/lib/python3.10/site-packages/serial_asyncio/init.py”, line 448, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File “/usr/local/lib/python3.10/site-packages/serial/init.py”, line 90, in serial_for_url
instance.open()
File “/usr/local/lib/python3.10/site-packages/serial/serialposix.py”, line 325, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_11600383-if01-port0: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_11600383-if01-port0’
