ZHA Zigbee Tested Devices...Please add your device results
I mean since that pull request was created, the original source base have diverged and now changes made by RCloran don’t apply cleanly to the existing 0.67.1 source.
I won’t be able to explain in a single post how to apply a pull request, but can provide the “direction” to what to google. Pretty much it is all about “git” and mastering git. I can only recommend to start with some git tutorials and once you comprehend the basics, articles like best way to merge a github pull request start making sense :slight_smile: I know, i’ve been there :slight_smile:
i’ve tried a rebase of that request against 0.67.1 and if you are willing to experiment, you could try to replace the following files in your 0.67.1 hass installation, assuming you are not running a “docker” installation.
./homeassistant/components/binary_sensor/zha.py
Binary sensors on Zigbee Home Automation networks.
For more details on this platform, please refer to the documentation
at https://home-assistant.io/components/binary_sensor.zha/
import logging
from homeassistant.components.binary_sensor import DOMAIN, BinarySensorDevice
from homeassistant.components import zha
_LOGGER = logging.getLogger(__name__)
DEPENDENCIES = ['zha']
# ZigBee Cluster Library Zone Type to Home Assistant device class
CLASS_MAPPING = {
    0x000d: 'motion',
    0x0015: 'opening',
    0x0028: 'smoke',
    0x002a: 'moisture',
    0x002b: 'gas',
    0x002d: 'vibration',
async def async_setup_platform(hass, config, async_add_devices,
                               discovery_info=None):
    """Set up the Zigbee Home Automation binary sensors."""
    discovery_info = zha.get_discovery_info(hass, discovery_info)
    if discovery_info is None:
        return
    from zigpy.zcl.clusters.general import OnOff
    from zigpy.zcl.clusters.security import IasZone
    if IasZone.cluster_id in discovery_info['in_clusters']:
        await _async_setup_iaszone(hass, config, async_add_devices,
                                   discovery_info)
    elif OnOff.cluster_id in discovery_info['out_clusters']:
        await _async_setup_remote(hass, config, async_add_devices,
                                  discovery_info)
async def _async_setup_iaszone(hass, config, async_add_devices, discovery_info=None):
    device_class = None
    cluster = discovery_info['in_clusters'][IasZone.cluster_id]
    if discovery_info['new_join']:
        await cluster.bind()
        ieee = cluster.endpoint.device.application.ieee
        await cluster.write_attributes({'cie_addr': ieee})
    try:
        zone_type = await cluster['zone_type']
        device_class = CLASS_MAPPING.get(zone_type, None)
    except Exception:  # pylint: disable=broad-except
        # If we fail to read from the device, use a non-specific class
        pass
    sensor = BinarySensor(device_class, **discovery_info)
    async_add_devices([sensor], update_before_add=True)
async def _async_setup_remote(hass, config, async_add_devices, discovery_info):
    async def safe(coro):
        """Run coro, catching ZigBee delivery errors, and ignoring them."""
        import zigpy.exceptions
        try:
            await coro
        except zigpy.exceptions.DeliveryError as exc:
            _LOGGER.info("Ignoring error during setup: %s", exc)
        from zigpy.zcl.clusters.general import OnOff, LevelControl
        out_clusters = discovery_info['out_clusters']
        if OnOff.cluster_id in out_clusters:
            cluster = out_clusters[OnOff.cluster_id]
            await safe(cluster.bind())
            await safe(cluster.configure_reporting(0, 0, 600, 1))
        if LevelControl.cluster_id in out_clusters:
            cluster = out_clusters[LevelControl.cluster_id]
            await safe(cluster.configure_reporting(0, 1, 600, 1))
    sensor = Switch(**discovery_info)
    async_add_devices([sensor])
class BinarySensor(zha.Entity, BinarySensorDevice):
    """The ZHA Binary Sensor."""
    _domain = DOMAIN
    def __init__(self, device_class, **kwargs):
        """Initialize the ZHA binary sensor."""
        super().__init__(**kwargs)
        self._device_class = device_class
        self._ias_zone_cluster = self._in_clusters[IasZone.cluster_id]
    @property
    def should_poll(self) -> bool:
        """Let zha handle polling."""
        return False
    @property
    def is_on(self) -> bool:
        """Return True if entity is on."""
        if self._state == 'unknown':
            return False
        return bool(self._state)
    @property
    def device_class(self):
        """Return the class of this device, from component DEVICE_CLASSES."""
        return self._device_class
    def cluster_command(self, tsn, command_id, args):
        """Handle commands received to this cluster."""
        if command_id == 0:
            self._state = args[0] & 3
            _LOGGER.debug("Updated alarm state: %s", self._state)
            self.async_schedule_update_ha_state()
        elif command_id == 1:
            _LOGGER.debug("Enroll requested")
            res = self._ias_zone_cluster.enroll_response(0, 0)
            self.hass.async_add_job(res)
    async def async_update(self):
        """Retrieve latest state."""
        from bellows.types.basic import uint16_t
        result = await zha.safe_read(self._endpoint.ias_zone,
                                     ['zone_status'])
        state = result.get('zone_status', self._state)
        if isinstance(state, (int, uint16_t)):
            self._state = result.get('zone_status', self._state) & 3
class Switch(zha.Entity, BinarySensorDevice):
    """ZHA switch/remote controller/button."""
    _domain = DOMAIN
    class OnOffListener:
        """Listener for the OnOff ZigBee cluster."""
        def __init__(self, entity):
            """Initialize OnOffListener."""
            self._entity = entity
            if command_id in (0x0000, 0x0040):
                self._entity._set_state(False)
            elif command_id in (0x0001, 0x0041, 0x0042):
                self._entity._set_state(True)
            elif command_id == 0x0002:
                self._entity._set_state(not self._entity._state)
        def attribute_updated(self, attrid, value):
            """Handle attribute updates on this cluster."""
            if attrid == 0:
                self._entity._state = value
                self._entity.schedule_update_ha_state()
    class LevelListener:
        """Listener for the LevelControl ZigBee cluster."""
            """Initialize LevelListener."""
            if command_id == 0x0001:  # move_to_level
                self._entity._set_level(args[0])
            elif command_id == 0x0002:  # step
                # Step (technically shouldn't change on/off)
                if args[0] == 0:
                    self._entity._move_level(args[1])
                else:
                    self._entity._move_level(-args[1])
            elif command_id == 0x0004:  # move_to_level_with_on_off
            elif command_id == 0x0005:  # move_with_on_off
                # We should dim slowly -- for now, just step once
                if args[0] == 0:
                    self._entity._move_level(10)
                else:
                    self._entity._move_level(-10)
        def attribute_update(self, attrid, value):
            if attrid == 0:
                self._entity._set_level(value)
    def __init__(self, **kwargs):
        """Initialize Switch."""
        self._state = True
        self._level = 255
        from zigpy.zcl.clusters import general
        self._out_listeners = {
            general.OnOff.cluster_id: self.OnOffListener(self),
            general.LevelControl.cluster_id: self.LevelListener(self),
    @property
        """Return true if the binary sensor is on."""
        return self._state
    @property
    def device_state_attributes(self):
        """Return the device state attributes."""
        return {'level': self._state and self._level or 0}
    def _move_level(self, change):
        """Increment the level, setting state if appropriate."""
        if not self._state and change > 0:
            self._level = 0
        self._level += min(255, max(0, self._level + change))
        self._state = bool(self._level)
        self.schedule_update_ha_state()
    def _set_level(self, level):
        """Set the level, setting state if appropriate."""
        self._level = level
    def _set_state(self, state):
        """Set the state."""
        self._state = state
./homeassistant/components/zha/__init__.py
Support for ZigBee Home Automation devices.
For more details about this component, please refer to the documentation at
https://home-assistant.io/components/zha/
import collections
import enum
import logging
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
from homeassistant import const as ha_const
from homeassistant.helpers import discovery, entity
from homeassistant.util import slugify
REQUIREMENTS = [
    'bellows==0.5.1',
    'zigpy==0.0.3',
    'zigpy-xbee==0.0.2',
DOMAIN = 'zha'
class RadioType(enum.Enum):
    """Possible options for radio type in config."""
    ezsp = 'ezsp'
    xbee = 'xbee'
CONF_BAUDRATE = 'baudrate'
CONF_DATABASE = 'database_path'
CONF_DEVICE_CONFIG = 'device_config'
CONF_RADIO_TYPE = 'radio_type'
CONF_USB_PATH = 'usb_path'
DATA_DEVICE_CONFIG = 'zha_device_config'
DEVICE_CONFIG_SCHEMA_ENTRY = vol.Schema({
    vol.Optional(ha_const.CONF_TYPE): cv.string,
CONFIG_SCHEMA = vol.Schema({
    DOMAIN: vol.Schema({
        vol.Optional(CONF_RADIO_TYPE, default='ezsp'): cv.enum(RadioType),
        CONF_USB_PATH: cv.string,
        vol.Optional(CONF_BAUDRATE, default=57600): cv.positive_int,
        CONF_DATABASE: cv.string,
        vol.Optional(CONF_DEVICE_CONFIG, default={}):
            vol.Schema({cv.string: DEVICE_CONFIG_SCHEMA_ENTRY}),
}, extra=vol.ALLOW_EXTRA)
ATTR_DURATION = 'duration'
ATTR_IEEE = 'ieee_address'
SERVICE_PERMIT = 'permit'
SERVICE_REMOVE = 'remove'
SERVICE_SCHEMAS = {
    SERVICE_PERMIT: vol.Schema({
        vol.Optional(ATTR_DURATION, default=60):
            vol.All(vol.Coerce(int), vol.Range(1, 254)),
    SERVICE_REMOVE: vol.Schema({
        vol.Required(ATTR_IEEE): cv.string,
# ZigBee definitions
CENTICELSIUS = 'C-100'
# Key in hass.data dict containing discovery info
DISCOVERY_KEY = 'zha_discovery_info'
# Internal definitions
APPLICATION_CONTROLLER = None
async def async_setup(hass, config):
    """Set up ZHA.
    Will automatically load components to support devices found on the network.
    global APPLICATION_CONTROLLER
    usb_path = config[DOMAIN].get(CONF_USB_PATH)
    baudrate = config[DOMAIN].get(CONF_BAUDRATE)
    radio_type = config[DOMAIN].get(CONF_RADIO_TYPE)
    if radio_type == RadioType.ezsp:
        import bellows.ezsp
        from bellows.zigbee.application import ControllerApplication
        radio = bellows.ezsp.EZSP()
    elif radio_type == RadioType.xbee:
        import zigpy_xbee.api
        from zigpy_xbee.zigbee.application import ControllerApplication
        radio = zigpy_xbee.api.XBee()
    await radio.connect(usb_path, baudrate)
    database = config[DOMAIN].get(CONF_DATABASE)
    APPLICATION_CONTROLLER = ControllerApplication(radio, database)
    listener = ApplicationListener(hass, config)
    APPLICATION_CONTROLLER.add_listener(listener)
    await APPLICATION_CONTROLLER.startup(auto_form=True)
    for device in APPLICATION_CONTROLLER.devices.values():
        hass.async_add_job(listener.async_device_initialized(device, False))
    async def permit(service):
        """Allow devices to join this network."""
        duration = service.data.get(ATTR_DURATION)
        _LOGGER.info("Permitting joins for %ss", duration)
        await APPLICATION_CONTROLLER.permit(duration)
    hass.services.async_register(DOMAIN, SERVICE_PERMIT, permit,
                                 schema=SERVICE_SCHEMAS[SERVICE_PERMIT])
    async def remove(service):
        """Remove a node from the network."""
        from bellows.types import EmberEUI64, uint8_t
        ieee = service.data.get(ATTR_IEEE)
        ieee = EmberEUI64([uint8_t(p, base=16) for p in ieee.split(':')])
        _LOGGER.info("Removing node %s", ieee)
        await APPLICATION_CONTROLLER.remove(ieee)
    hass.services.async_register(DOMAIN, SERVICE_REMOVE, remove,
                                 schema=SERVICE_SCHEMAS[SERVICE_REMOVE])
    return True
class ApplicationListener:
    """All handlers for events that happen on the ZigBee application."""
    def __init__(self, hass, config):
        """Initialize the listener."""
        self._hass = hass
        self._config = config
        self._device_registry = collections.defaultdict(list)
        hass.data[DISCOVERY_KEY] = hass.data.get(DISCOVERY_KEY, {})
    def device_joined(self, device):
        """Handle device joined.
        At this point, no information about the device is known other than its
        address
        # Wait for device_initialized, instead
        pass
    def device_initialized(self, device):
        """Handle device joined and basic information discovered."""
        self._hass.async_add_job(self.async_device_initialized(device, True))
    def device_left(self, device):
        """Handle device leaving the network."""
        pass
    def device_removed(self, device):
        """Handle device being removed from the network."""
        for device_entity in self._device_registry[device.ieee]:
            self._hass.async_add_job(device_entity.async_remove())
    async def async_device_initialized(self, device, join):
        """Handle device joined and basic information discovered (async)."""
        import zigpy.profiles
        import homeassistant.components.zha.const as zha_const
        zha_const.populate_data()
        for endpoint_id, endpoint in device.endpoints.items():
            if endpoint_id == 0:  # ZDO
                continue
            discovered_info = await _discover_endpoint_info(endpoint)
            component = None
            profile_clusters = ([], [])
            device_key = "{}-{}".format(device.ieee, endpoint_id)
            node_config = self._config[DOMAIN][CONF_DEVICE_CONFIG].get(
                device_key, {})
            if endpoint.profile_id in zigpy.profiles.PROFILES:
                profile = zigpy.profiles.PROFILES[endpoint.profile_id]
                if zha_const.DEVICE_CLASS.get(endpoint.profile_id,
                                              {}).get(endpoint.device_type,
                                                      None):
                    profile_clusters = profile.CLUSTERS[endpoint.device_type]
                    profile_info = zha_const.DEVICE_CLASS[endpoint.profile_id]
                    component = profile_info[endpoint.device_type]
            if ha_const.CONF_TYPE in node_config:
                component = node_config[ha_const.CONF_TYPE]
                profile_clusters = zha_const.COMPONENT_CLUSTERS[component]
            if component:
                in_clusters = [endpoint.in_clusters[c]
                               for c in profile_clusters[0]
                               if c in endpoint.in_clusters]
                out_clusters = [endpoint.out_clusters[c]
                                for c in profile_clusters[1]
                                if c in endpoint.out_clusters]
                discovery_info = {
                    'application_listener': self,
                    'endpoint': endpoint,
                    'in_clusters': {c.cluster_id: c for c in in_clusters},
                    'out_clusters': {c.cluster_id: c for c in out_clusters},
                    'new_join': join,
                    'unique_id': device_key,
                discovery_info.update(discovered_info)
                self._hass.data[DISCOVERY_KEY][device_key] = discovery_info
                await discovery.async_load_platform(
                    self._hass,
                    component,
                    DOMAIN,
                    {'discovery_key': device_key},
                    self._config,
            async def attempt_single_cluster_device(cluster, profile_clusters,
                                              device_classes, discovery_attr):
                if cluster.cluster_id in profile_clusters:
                    return
                if type(cluster) not in device_classes:
                    return
                component = device_classes[type(cluster)]
                cluster_key = "{}-{}".format(device_key, cluster_id)
                discovery_info = {
                    'in_clusters': {},
                    'out_clusters': {},
                    'new_join': join,
                    'unique_id': cluster_key,
                    'entity_suffix': '_{}'.format(cluster_id),
                discovery_info[discovery_attr] = {cluster.cluster_id: cluster}
                self._hass.data[DISCOVERY_KEY][cluster_key] = discovery_info
                    self._hass,
                    component,
                    DOMAIN,
                    {'discovery_key': cluster_key},
                    self._config,
            for cluster_id, cluster in endpoint.in_clusters.items():
                await attempt_single_cluster_device(
                    cluster,
                    profile_clusters[0],
                    zha_const.SINGLE_INPUT_CLUSTER_DEVICE_CLASS,
                    'in_clusters',
            for cluster_id, cluster in endpoint.out_clusters.items():
                    cluster,
                    profile_clusters[1],
                    zha_const.SINGLE_OUTPUT_CLUSTER_DEVICE_CLASS,
                    'out_clusters',
    def register_entity(self, ieee, entity_obj):
        """Record the creation of a hass entity associated with ieee."""
        self._device_registry[ieee].append(entity_obj)
class Entity(entity.Entity):
    """A base class for ZHA entities."""
    _domain = None  # Must be overridden by subclasses
    # Normally the entity itself is the listener. Base classes may set this to
    # a dict of cluster ID -> listener to receive messages for specific
    # clusters separately
    _in_listeners = {}
    _out_listeners = {}
    def __init__(self, endpoint, in_clusters, out_clusters, manufacturer,
                 model, application_listener, unique_id, **kwargs):
        """Init ZHA entity."""
        self._device_state_attributes = {}
        ieee = endpoint.device.ieee
        ieeetail = ''.join(['%02x' % (o, ) for o in ieee[-4:]])
        if manufacturer and model is not None:
            self.entity_id = "{}.{}_{}_{}_{}{}".format(
                self._domain,
                slugify(manufacturer),
                slugify(model),
                ieeetail,
                endpoint.endpoint_id,
                kwargs.get('entity_suffix', ''),
            self._device_state_attributes['friendly_name'] = "{} {}".format(
                manufacturer,
                model,
        else:
            self.entity_id = "{}.zha_{}_{}{}".format(
                self._domain,
                ieeetail,
        for cluster_id, cluster in in_clusters.items():
            cluster.add_listener(self._in_listeners.get(cluster_id, self))
        for cluster_id, cluster in out_clusters.items():
            cluster.add_listener(self._out_listeners.get(cluster_id, self))
        self._endpoint = endpoint
        self._in_clusters = in_clusters
        self._out_clusters = out_clusters
        self._state = ha_const.STATE_UNKNOWN
        self._unique_id = unique_id
        application_listener.register_entity(ieee, self)
    @property
    def unique_id(self) -> str:
        """Return a unique ID."""
        return self._unique_id
    @property
        """Return device specific state attributes."""
        return self._device_state_attributes
    def attribute_updated(self, attribute, value):
        """Handle an attribute updated on this cluster."""
        pass
    def zdo_command(self, tsn, command_id, args):
        """Handle a ZDO command received on this cluster."""
        pass
async def _discover_endpoint_info(endpoint):
    """Find some basic information about an endpoint."""
    extra_info = {
        'manufacturer': None,
        'model': None,
    if 0 not in endpoint.in_clusters:
        return extra_info
    async def read(attributes):
        """Read attributes and update extra_info convenience function."""
        result, _ = await endpoint.in_clusters[0].read_attributes(
            attributes,
            allow_cache=True,
        extra_info.update(result)
    await read(['manufacturer', 'model'])
    if extra_info['manufacturer'] is None or extra_info['model'] is None:
        # Some devices fail at returning multiple results. Attempt separately.
        await read(['manufacturer'])
        await read(['model'])
    for key, value in extra_info.items():
        if isinstance(value, bytes):
            try:
                extra_info[key] = value.decode('ascii').strip()
            except UnicodeDecodeError:
                # Unsure what the best behaviour here is. Unset the key?
                pass
    return extra_info
def get_discovery_info(hass, discovery_info):
    """Get the full discovery info for a device.
    Some of the info that needs to be passed to platforms is not JSON
    serializable, so it cannot be put in the discovery_info dictionary. This
    component places that info we need to pass to the platform in hass.data,
    and this function is a helper for platforms to retrieve the complete
    discovery info.
        return
    discovery_key = discovery_info.get('discovery_key', None)
    all_discovery_info = hass.data.get(DISCOVERY_KEY, {})
    return all_discovery_info.get(discovery_key, None)
async def safe_read(cluster, attributes):
    """Swallow all exceptions from network read.
    If we throw during initialization, setup fails. Rather have an entity that
    exists, but is in a maybe wrong state, than no entity. This method should
    probably only be used during initialization.
    try:
        result, _ = await cluster.read_attributes(
            attributes,
            allow_cache=False,
        return result
        return {}
./homeassistant/components/zha/const.py
"""All constants related to the ZHA component."""
DEVICE_CLASS = {}
SINGLE_INPUT_CLUSTER_DEVICE_CLASS = {}
SINGLE_OUTPUT_CLUSTER_DEVICE_CLASS = {}
COMPONENT_CLUSTERS = {}
def populate_data():
    """Populate data using constants from bellows.
    These cannot be module level, as importing bellows must be done in a
    in a function.
    from zigpy import zcl
    from zigpy.profiles import PROFILES, zha, zll
    DEVICE_CLASS[zha.PROFILE_ID] = {
        zha.DeviceType.ON_OFF_SWITCH: 'binary_sensor',
        zha.DeviceType.LEVEL_CONTROL_SWITCH: 'binary_sensor',
        zha.DeviceType.REMOTE_CONTROL: 'binary_sensor',
        zha.DeviceType.SMART_PLUG: 'switch',
        zha.DeviceType.ON_OFF_LIGHT: 'light',
        zha.DeviceType.DIMMABLE_LIGHT: 'light',
        zha.DeviceType.COLOR_DIMMABLE_LIGHT: 'light',
        zha.DeviceType.ON_OFF_LIGHT_SWITCH: 'binary_sensor',
        zha.DeviceType.DIMMER_SWITCH: 'binary_sensor',
        zha.DeviceType.COLOR_DIMMER_SWITCH: 'binary_sensor',
    DEVICE_CLASS[zll.PROFILE_ID] = {
        zll.DeviceType.ON_OFF_LIGHT: 'light',
        zll.DeviceType.ON_OFF_PLUGIN_UNIT: 'switch',
        zll.DeviceType.DIMMABLE_LIGHT: 'light',
        zll.DeviceType.DIMMABLE_PLUGIN_UNIT: 'light',
        zll.DeviceType.COLOR_LIGHT: 'light',
        zll.DeviceType.EXTENDED_COLOR_LIGHT: 'light',
        zll.DeviceType.COLOR_TEMPERATURE_LIGHT: 'light',
        zll.DeviceType.COLOR_CONTROLLER: 'binary_sensor',
        zll.DeviceType.COLOR_SCENE_CONTROLLER: 'binary_sensor',
        zll.DeviceType.CONTROLLER: 'binary_sensor',
        zll.DeviceType.SCENE_CONTROLLER: 'binary_sensor',
        zll.DeviceType.ON_OFF_SENSOR: 'binary_sensor',
    SINGLE_INPUT_CLUSTER_DEVICE_CLASS.update({
        zcl.clusters.general.OnOff: 'switch',
        zcl.clusters.measurement.RelativeHumidity: 'sensor',
        zcl.clusters.measurement.TemperatureMeasurement: 'sensor',
        zcl.clusters.security.IasZone: 'binary_sensor',
        zcl.clusters.hvac.Fan: 'fan',
    SINGLE_OUTPUT_CLUSTER_DEVICE_CLASS.update({
        zcl.clusters.general.OnOff: 'binary_sensor',
    # A map of hass components to all Zigbee clusters it could use
    for profile_id, classes in DEVICE_CLASS.items():
        profile = PROFILES[profile_id]
        for device_type, component in classes.items():
            if component not in COMPONENT_CLUSTERS:
                COMPONENT_CLUSTERS[component] = (set(), set())
            clusters = profile.CLUSTERS[device_type]
            COMPONENT_CLUSTERS[component][0].update(clusters[0])
            COMPONENT_CLUSTERS[component][1].update(clusters[1])
before you replace the files above, you need to make sure to exclude the existing switch from zigbee network, because there’s some configuration done to the device only what a device joins the network, so it won’t work if you just replace the files with device already existing in zigbee.db .
You can exclude the dimmer switch by calling “zha.remove” with {“ieee_address”: “84:18:26:00:00:e8:fa:90”} JSON data. Confirm the device was excluded with bellows devices -D ~/.homeassistant/zigbee.db (adjust for your specific file path and zigbee database filename). After that, replaces the files above, start homeassistant, call service zha.permit and join the switch. If everything successful, you should get
Good luck! And yep, things may break, but this is what makes it more fun, isn’t it :smiley:
