I’m not entirely sure if it added or not - I checked under ZHA devices and there was nothing new there. The log didn’t show anything new joining the network either, unless I missed it since it scrolled by quick. Is there an easier way to verify?
I’m not sure, you might need to enable the debug log. Maybe you can test it by placing the router between the coordinator and a far away device, and then check the signal levels on that far away device before and after adding the router?
I have CC2531 with debug router firmware and it joins fine, I just don’t recall how to reset them. Shows up on the network as LUMI Router device with on/off cluster
Man, I’ve tried flashing the debug firmware, tried reset… still won’t detect under ZHA. I’m using zigpy-deconz if it makes a difference.
Just wanted to report that these Heiman Humidity/Temp sensors pair flawlessly with ZHA and work great as shower sensors. Appears to report with a 5% humidity change trigger threshold, and maybe 30min periodic reports.
It would be really cool to have a ZHA category instead of this massive thread
I agree, @robbiet480 any ideas how we may accomplish getting an area created for ZHA? Or is there someone else that is responsible for the forum?
https://community.home-assistant.io/c/configuration/zha
Now if some kind user could pin a bunch of the useful stuff from here…
Awesome, thanks!
Hello Friends,
Thank you for this thread.
I’m considerting buying the Husbzb-1 hub to control Zigbee smart bulbs in my new home.
Does anyone know if the hub can control GU10 smart LED bulbs manufactured by Innr?
https://www.amazon.co.uk/gp/product/B07KT98J3Q/
They appear to be a cheaper and open platform alternative to Philips Hue.
I hope they are supported.
Those bulbs look to be Zigbee 3.0 compliant. It seems there were a few changes changes to ZHA and zigpy to support Zigbee 3.0 lights, so I think they will work. YMMV of course.
We already have this category:
How did you get the Osram lights to pair? My system won’t show any of my Osram lights (which are in discoverable mode).
I have 3 Motion sensors Iris 3326-L that all Joined the zigbee network but they joined as Moisture Sensor. Can this be changed to Motion Sensor somewhere in Home Assistant?
You can change the “Device class” under the Configuration->Customizations menu.
Alternately you could make a quirk for that device that adjusts the attribute like I did here. This will change the default so that other users will benefit as well.
I currently have 4 Visonic MCT340 door sensors that had been working perfectly until recently. Two of them suddenly went unavailable so I removed them and re-added them and they seem to be working fine for the moment. The third sensor suddenly started flipping from available to unavailable every 30 seconds or so. I tried removing and re-adding but it kept doing it. So I assumed the sensor might have gone bad(?). Now the next day the 4th sensor is doing the same thing flipping from available to unavailable every 30 seconds or so. Seems odd that 2 sensors would go bad almost back to back. Is there something I could try or need to do that might correct this?
I am currently on v0.101.3 and using a HUSBZB-1 Stick
you would need to enable debug logging for zigpy and zha and homeassistant.core and post logs here or open an issue in github.
Thanks that worked great… I’m not sure we want me making any quirk for others. Lol. I just started with Home Assistant…
Did you add any new devices to the network? Any chance the batteries are dying?
Oddly enough I went to enable debugging so I could post the logs and after a few restarts the flipping stopped on both of the door sensors. I have been monitoring it for the last few days and they both have been working fine again. It started on the one after I had replaced the battery and the other has a battery that is 78% full. I don’t know why it started or what fixed it other than a couple of restarts of HA. For the moment it seems to be resolved but I’ll keep an eye on it and if it appears again hopefully I can grab a log and post it here.
