Can anyone help me understand why the switches don’t report their status back when physically switched? How can I investigate this further & find a solution?
Furthermore, if I try to adjust their brightness in hass.io, the switch crashes and requires restart.
I am using Conbee II and have exact same issue with 3A 4Gang (https://3asmarthome.com/zigbee-scene-switch). I can turn the switch on and off in HA but there is no status send when switch is manually turned on or off.
I don’t have any issue with 3A 3Gang.
NUE 3A 4Gang is detected as FB56+ZSW1JKJ2.7 by Feibit Inc co.
NUE 3A 3Gang is detected as LXN-3S27LX1.0 by 3A Smart Home DE
Looks like it might be a problem with DCONZ or whatever software is talking to the Conbee. I just looked at the zigbee2mqtt code (which I use) and that zigbeeModel is listed as as a Nue / 3A product.
I’ve ordered another zigbee device which I am planning to use it with zigbee2mqtt. I would then be able to verify this. Also got this response from 3A vendor:
“The 4 gang switch is a ZigBee ZHA device, not the ZigBee 3.0 one like the 3 gang switch. We did not test it with Conbeell by ourselves.”
