dtsrcc
(Dtsrcc)
December 12, 2022, 11:24am
1
I have a 4 Channel switch module SML-04Z. it gets discovered by ZHA as a TS0004.InkedScreenshot 2022-12-12 112922|499x500
SML-04Z Tuya Smart Zigbee 4CH Switch Module Smart, compact, mini body, easy to place; Support two-way control: This smart DIY switch can be used for your old 2-way control wall switch. After canceling the installation, you can still manually control...
Price: USD 12.2
the problem is that all channels are trigered at the same time, and i can not change the on/off state of each channel independently.
It seems to be the same problem as described here:
I have a TS0012 2-gang switch . When I press the physical left button, everything works as expected:
[Screenshot 2022-11-11 at 20.03.21]
When I initiate the left button press from Home Assistant (or from Zigbee2mqtt → Devices), both switches turn on. Digging deeper, I see that 4 mqtt messages are sent for some reason:
[Screenshot 2022-11-11 at 19.53.03]
Any thoughts on how to dig deeper? I cannot build any automations because the switches can’t be worked independently from Home Assistant.
opened 07:22PM - 17 Oct 22 UTC
closed 04:29PM - 18 Oct 22 UTC
problem
### What happened?
Hi!
I a pretty sure the [TS0003](https://www.zigbee2mqtt.… io/devices/TS0003_switch_module.html) version has exactly the same issue that you fixed for its 2-Gang version in:
https://github.com/Koenkk/zigbee2mqtt/issues/13954
The manual switches do work fine, so it needs it needs some TuYa magic for that one too :)
### What did you expect to happen?
Each gang to be switched individually.
### How to reproduce it (minimal and precise)
- Add TS0003 to your network.
- Toggle any of its switches from Zigbee2MQTT
### Zigbee2MQTT version
1.28.0
### Adapter firmware version
20220219
### Adapter
SONOFF Zigbee 3.0 USB Dongle Plus-P
### Debug log
_No response_
opened 11:43PM - 10 Sep 22 UTC
closed 08:05AM - 11 Sep 22 UTC
problem
### What happened?
Hello everyone.
I already use several devices model [Tuya… TS0002_switch_module](https://www.zigbee2mqtt.io/devices/TS0002_switch_module.html#tuya-ts0002_switch_module) and they all work perfectly. Right now, I'm replacing the latest wifi devices with a few more of this model. And to my surprise, I'm encountering strange behavior. After pairing on the Z2M, when I turn on one of the channels, the other is also turned on. I imagined that it might be a need to update the firmware, but when pairing them in a tuya hub, there is no update and the operation is perfect.
This problem only happens for new devices, the ones that were already on the Z2M continue to work perfectly.
Can anyone save me?
That the operation of the channels were independent
_No response_
1.27.2-1
Home Assistant 2022.9.1
### Adapter
SONOFF Zigbee 3.0 USB Dongle Plus ZBDongle-P
### Debug log
No data
probably we need the same fix for ZHA as mentioned above for zigbee2mqtt.
can someone support me to create a custom quirk for this device?
Thanks in advance
Have exactly the same problem, with a 2-gang relay switch from Tuya/Girier. Its get discovered as TZ3000
When i put the input local on the switch its works independently as aspected. But in HomeAssistant its always activated both switches. Can’t see a log problem. Hopefully it got fixed soon in the next update.
-edit- uses a Conbee2 stick with Zigbee Home Assistant
Wlkanos
(Ibrahem)
April 20, 2023, 12:31am
3
I have the same issue using conbee2 and deconz, has anyone found any fix for this?
Dzidza
(Nikola Ilic)
April 20, 2023, 7:57am
4
Me too. I see that it’s fixed for zigbee2mqtt.
Where do I/we write to add the same quirk update for ZHA? Is there an official place for that?
I have a ZGB-LS 03 3 channel switch with the same problem. someone with more experience please help!
My solution was to change to Z2M and it is working correctly now.
Edit:
Actually, was working correctly on first connect but then it is misbehaving again.
Edit:
Restarted and now its working again… My god, was it a mistake to start home automation???
dtsrcc
(Dtsrcc)
August 11, 2023, 7:24am
7
I tried it again about two monts ago and it worked. Now my Heating valves for the floor heating work great. I think it has been fixed in ZHA.
Bare in mind to bind your devices close to the actual use location. Zigbee is not robust at rerouting…
Br.
jadsakr
(Jad Sakr)
March 27, 2024, 5:55pm
8
is it just for me or these devices have a very low signal strength? what’s my solution I already bought a bunch
