Ok, I’m in for proper debugging now.
the MQTT integration looks like this:
I have a password and a username set here.
Mosquitto looks like this:
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
I did not change anything regarding ports:
I now have a new Raspberry Pi 3 setup with IP 192.168.1.105, and a brand-new " SONOFF Zigbee Gateway, ZBDongle-E 3.0 USB Dongle Plus". This website (https://smarthomescene.com/blog/best-zigbee-dongles-for-home-assistant-2023/) said that the CC2652 chip would be good.
I have setup z2m on the pi without docker, because I’m a noob and I don’t understand docker. But Z2M is running and it’s in pairing mode (some of that config stuff came in by itself, the advanced and decive options):
# cat /opt/zigbee2mqtt/data/configuration.yaml
homeassistant: false
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.1.100
user: mqtt-user
password: *****
serial:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231122135024-if00
advanced:
homeassistant_legacy_entity_attributes: false
legacy_api: false
legacy_availability_payload: false
device_options:
legacy: false
devices:
'0xa4c1389344582510':
friendly_name: '0xa4c1389344582510'
As you can see, 1 device is already paired (one of the 9 identical power sockets I bought, “Silvercrest”/Lidl). It was paired immediately and with a breeze. I can see lots of MQTT/Zigbee packets flying in on the Z2M raspberry pi:
Zigbee2MQTT:info 2024-02-26 21:29:48: Connecting to MQTT server at mqtt://192.168.1.100
Zigbee2MQTT:info 2024-02-26 21:29:49: Connected to MQTT server
Zigbee2MQTT:info 2024-02-26 21:29:49: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Zigbee2MQTT:info 2024-02-26 21:29:50: Zigbee2MQTT started!
Zigbee2MQTT:info 2024-02-26 21:33:16: Device '0xa4c1389344582510' joined
Zigbee2MQTT:info 2024-02-26 21:33:16: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c1389344582510","ieee_address":"0xa4c1389344582510"},"type":"device_joined"}'
Zigbee2MQTT:info 2024-02-26 21:33:16: Starting interview of '0xa4c1389344582510'
Zigbee2MQTT:info 2024-02-26 21:33:16: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c1389344582510","ieee_address":"0xa4c1389344582510","status":"started"},"type":"device_interview"}'
Zigbee2MQTT:info 2024-02-26 21:33:17: Successfully interviewed '0xa4c1389344582510', device has successfully been paired
Zigbee2MQTT:info 2024-02-26 21:33:17: Device '0xa4c1389344582510' is supported, identified as: Lidl Silvercrest smart plug with power monitoring (EU, FR) (HG08673)
Zigbee2MQTT:info 2024-02-26 21:33:17: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Silvercrest smart plug with power monitoring (EU, FR)","exposes":[{"features":[{"access":7,"description":"On/off state of the switch","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"access":7,"description":"Recover state after power outage","label":"Power outage memory","name":"power_outage_memory","property":"power_outage_memory","type":"enum","values":["on","off","restore"]},{"access":7,"description":"LED indicator mode","label":"Indicator mode","name":"indicator_mode","property":"indicator_mode","type":"enum","values":["off","off/on","on/off","on"]},{"access":1,"category":"diagnostic","description":"Instantaneous measured power","label":"Power","name":"power","property":"power","type":"numeric","unit":"W"},{"access":1,"category":"diagnostic","description":"Instantaneous measured electrical current","label":"Current","name":"current","property":"current","type":"numeric","unit":"A"},{"access":1,"category":"diagnostic","description":"Measured electrical potential value","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"V"},{"access":1,"description":"Sum of consumed energy","label":"Energy","name":"energy","property":"energy","type":"numeric","unit":"kWh"},{"features":[{"access":3,"description":"Enables/disables physical input on the device","label":"State","name":"state","property":"child_lock","type":"binary","value_off":"UNLOCK","value_on":"LOCK"}],"label":"Child lock","type":"lock"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"HG08673","options":[{"access":2,"description":"Only the energy value is polled for this device.","label":"Measurement poll interval","name":"measurement_poll_interval","property":"measurement_poll_interval","type":"numeric","value_min":-1},{"access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device.","label":"Power calibration","name":"power_calibration","property":"power_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Power precision","name":"power_precision","property":"power_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the current value (percentual offset), takes into effect on next report of device.","label":"Current calibration","name":"current_calibration","property":"current_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for current, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Current precision","name":"current_precision","property":"current_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device.","label":"Voltage calibration","name":"voltage_calibration","property":"voltage_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for voltage, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Voltage precision","name":"voltage_precision","property":"voltage_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the energy value (percentual offset), takes into effect on next report of device.","label":"Energy calibration","name":"energy_calibration","property":"energy_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for energy, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Energy precision","name":"energy_precision","property":"energy_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true}],"supports_ota":true,"vendor":"Lidl"},"friendly_name":"0xa4c1389344582510","ieee_address":"0xa4c1389344582510","status":"successful","supported":true},"type":"device_interview"}'
Zigbee2MQTT:info 2024-02-26 21:33:17: Configuring '0xa4c1389344582510'
Zigbee2MQTT:info 2024-02-26 21:33:18: Successfully configured '0xa4c1389344582510'
Zigbee2MQTT:info 2024-02-26 21:33:22: MQTT publish: topic 'zigbee2mqtt/0xa4c1389344582510', payload '{"linkquality":240,"voltage":234}'
Zigbee2MQTT:info 2024-02-26 21:33:24: MQTT publish: topic 'zigbee2mqtt/0xa4c1389344582510', payload '{"child_lock":"UNLOCK","indicator_mode":"off/on","linkquality":236,"power_outage_memory":"off","state":"OFF","voltage":234}'
Zigbee2MQTT:info 2024-02-26 21:34:07: MQTT publish: topic 'zigbee2mqtt/0xa4c1389344582510', payload '{"child_lock":"UNLOCK","current":0,"indicator_mode":"off/on","linkquality":236,"power":0,"power_outage_memory":"off","state":"OFF","voltage":233}'
Zigbee2MQTT:info 2024-02-26 21:34:07: MQTT publish: topic 'zigbee2mqtt/0xa4c1389344582510', payload '{"child_lock":"UNLOCK","current":0,"energy":0,"indicator_mode":"off/on","linkquality":236,"power":0,"power_outage_memory":"off","state":"OFF","voltage":233}'
Yet, nothing happens in Home Assistant: the MQTT integration remains empty.
If I’m listening to the topic from the Z2M logs, I receive all of the messages in HA that Z2M is sending:
So, I’m kinda lost again why the integration remains empty. Any idea(s)?
