Addon MQTT Explorer new Version
Addon MQTT Explorer new version
I am the creator of the port of MQTT Explorer on NodeJS. So you can use it directly in the browser.
Installation
"Add repository on my Home Assistant"
If you want to do add the repository manually, please follow the procedure highlighted in the Home Assistant website. Use the following URL to add this repository: https://github.com/GollumDom/addon-repository
Usage
  • Install broker addon
  • Install MQTT Explorer
  • Add in your panel
  • Start your addon
  • The host is ready to start
  • Connect with valid login and password
This version works in IOS, Android, Chrome, Firefox and Safari.
External Link
Donate
If the heart tells you
"Buy Me A Coffee"
"Buy Me A Coffee"
Can you say how this version is different from the existing addon?
This version is up to date,
Moreover I am the creator of the port so I will keep the addon in the repository up to date.
And in updates:
  • Fix IOS and Safari
  • Preconfiguration of MQTT explorer adapt to HA
  • Others bug… (button on mobile…)
I only just noticed that the other addon creator cited you as the creator of the docker image he used. Thanks for creating and maintaining your own HA addon…always better to have everything sourced in one place :wink:
Well the addon existed from the beginning but I hadn’t documented it.
Works perfectly…and now I have access to monitor my mqtt streams remotely.
Thanks you sir!
Is it possible to access the webui on another computer on the same LAN or is it only available via the HA web interface? I tried to access via hassioIP:4000 in my browser but nada.
I didn’t share port 4000. But I should put it as an option I can do that :slight_smile:
Update the repository (re-install) THe port can be exosed
This is pretty cool. Thanks! I love the standalone version of this but this is much more functional (I can use it on my iPad for instance)
Works on LAN now so I can add to my Dashy dashboard.
You are the man…have a coffee on me sir!
Thanks for doing this. I’ll reference yours at the top of my post.
I will do the same (And thank you for supporting my port all the time :slight_smile: )
Thank you very much for the donation.
You’re most welcome. I also added a DOCS.md in a PR to your repo.
It’s Merged. Thanks
Sorry for being stupid…. MQTT Explorer Add-on running but how do I share the port and is the 4000 fixed or configurable? V1.0.3. I did reinstall.
In option you can share port 4000 and it’s configurable
It’s on the Configuration tab of the addon
Peek 18-08-2023 22-18
So it is… thank you I don’t know how I missed that. Working.
When editing that port it loses other config info but just had to recreate that
Very useful add-on for ne. Coffee on its way.
K
