Really loving to get back to my Home Assistant project, but need some help on a recurring issue…
Each time a execute a “Restart” of the Home Assistant several of my zigbee devices become “Unavailable” and do not recover from such state.
The only solution i’ve found so far was to delete them and redo the pairing…
I’d like to get this stright before moving forward with my project, since it can become quite tricky to go over this process everytime I make an update, a reboot of the system or simply the “Restart” via the gui after a configuration.ymal modification…
I don’t really know which kind of information do you need to help me, so please let me know what to serach for
Xiaomi magnet sensor, temperature and humity sensors and also movement sensors (but inly some of them, others are fine).
The most strange thing is that all zigbee devices are connect when I open the “Visualization” !
Which coordinator do you use? Do you have any mains/powered devices?
I have, when I was using ConbeeII, seen that the aqara/xiaomi end devices lost connection to the coordinator, however was stable when connected to a mains/router device. The problem is they are bad at moving between “parents”, and during a reboot the “parent” is gone. I have been using Hue bulbs and Aqara plugs as mains with success, however others mains might be just as good.
My coordinator is the following one:
CC2531, Z-Stack Home 1.2 (build 20201127)
by Texas Instruments
Connected via Texas Instruments CC2531, Z-Stack Home 1.2 (build 20201127)
This is directly connected to the Raspberry pi USB.
Then I have in my network also two IKEA Tradfri lamps (always connected to mains) that take roles of router.
Agree with @nickrout, make sure the coordinator is away from the RPi (USB cable extender, 1m or more) and update the firmware.
Specifically for the aqara sensors. Make sure they are attached through one of the routers, and not the coordinator. Done by only allowing “pairing” through the optimal device and make a rejoin on the device.
I am experiencing the exact same issue. Whenever I reboot or restart my Home Assistant, there is 1 single zigbee device that becomes unresponsive. I need to delete it and re-add it every single time. My other 10+ zigbee devices remain fine. I am using Zigbee2MQTT.
What’s even stranger is that the lone problematic zigbee device is a YooKee smart cover (window blind). I have 5 other identical YooKee smart covers which continue to work fine. The problematic blind is not the furthest from the Sonoff USB zigbee controller and it’s next to a blind that continues to work fine.
