I’ve noticed a Home Assistant and Zigbee light group keeps turning on throughout the day for months.
I have the ZBT-2 now, but I had this same issue with the ZBT-1 that I replaced a few weeks ago.
I thought it was because my motion sensor was spotty but that’s not it. I thought maybe another automation was triggering the lights to turn on or that the lights are in multiple Zigbee groups, but that’s not it either.
After a bunch of checking through activity logs, it seems like the Zigbee controller is doing it.
Light Configs
Light Group helper
Here’s the light group helper “Master Bathroom Hallway Lights” (I use helpers as a consistent abstraction layer as I don’t only use Zigbee):
This particular group only has the Zigbee light group.
Zigbee light group
I have two lights in this fixture. Here’s the Zigbee group:
I checked, and these lights aren’t listed in my other Zigbee groups either.
Logs
Home Assistant light group
Looking through the logs, most times, it turns on and off via the automation (correct), but then sometimes, it says “turned on triggered by state of Zigbee Controller”.
For instance, I turned it off manually a while ago, and it came on again! And this wasn’t triggered by my motion sensor as it didn’t go through the automation:
turned on triggered by state of Basement Network Closet Zigbee Controller Master Bathroom Hallway Lights turned on
4:09:47 PM - 8 minutes ago
turned off triggered by action Light: Turn off
3:58:11 PM - 20 minutes ago - [REDACTED my name]
3:24:47 PM - 53 minutes ago
turned off triggered by automation Control Master Bathroom Hallway Lights triggered by state of Master Bathroom Hallway Occupancy Sensors
3:14:01 PM - 1 hour ago
turned on triggered by automation Control Master Bathroom Hallway Lights triggered by state of Master Bathroom Hallway Occupancy Sensors
3:13:14 PM - 1 hour ago
3:10:58 PM - 1 hour ago
3:09:47 PM - 1 hour ago
3:01:38 PM - 1 hour ago
3:01:07 PM - 1 hour ago
Zigbee light group
Looking at the Zigbee light group, I thought I might see more details about how the lights keep turning on, and this is what I saw: “turned on”. It doesn’t tell me why, but it’s clear the group itself is turning on.
turned on
4:09:47 PM - 20 minutes ago
3:58:11 PM - 31 minutes ago - [REDACTED my name]
turned on
3:24:47 PM - 1 hour ago
These logs don’t help either.
Questions
- I know there’s a way to link up Zigbee devices without a controller, but I’ve never done that. Is it possible I have devices linked up that way without realizing?
- Is the controller not getting the correct state of the light group and keeps resetting it to whatever value it wants?
- Is this a Home Assistant Zigbee issue? I found two other instances where this is happening:
It’s only happening to this light group, not the individual lights, so my first guess is something between the Zigbee controller’s state and Home Assistant.
