Zigbee pulse counter
My water meter has a magnet attached to one of the dials, so a device which counts pulses to record my water usage should be easy.
However, surprisingly there seem to be very few Zigbee pulse counter devices available, and the ones I’ve found seem very expensive. I’m thinking of using a door/window sensor (which are available for about £2 from Aliexpress), but wondered if anyone had any better suggestions before I go down that route - I would prefer the device itself to count the pulses because just using a window sensor and counting them on Home Assistant means some pulses may go missing over the zigbee network.
This discussion seems to have come up a few times before and people seem to have settled on using ESPHome. However, I’ve settled on Zigbee for home automation stuff and this thing is going to need to be battery powered so I’m a bit uninclined to go in that direction.
You sound on the right track, but a thought. A battery powered sensor that can’t really sleep much, has to broadcast a lot, is going to be hard on batteries. Might have to think about that in the design, use an 18650 passed thru a diode maybe with a door sensor that takes a 3v battery? Just a thought.
Did you find anything? I’m surprised such a thing doesn’t exist. I’m down to trying to find a zigbee module to try and roll my own and even that is non trivial.
@Sir_Goodenough I don’t think it’s that much of a stretch battery wise compared to a temperature sensor running off a CR2032 that lasts 6-12 months fairly easily. It could easily run off couple of AAs for 10x the lifetime or more over a coin cell.
  • Can sleep a lot of the time i.e. when water isn’t used it is idle. No different to a temperature/humidity (which is always regularly measuring - this only needs to wake to count pulses)
  • If it keeps it’s own internal counter it can easily limit transmissions so not transmitting on every pulse e.g. only transmit every 10 pulses or after a set period of time to get fractions of the 10 pulses.
  • What is it “broadcasting” compared to any other Zigbee battery device?
No, haven’t found anything. I’m probably going to go with the window sensor when I get around to it
I have a gas meter with a magnet attached to one of the dials, I wanted to count the pulses but due to my gas company policy I could not use anything mains powered, only battery devices are allowed. So I got a dedicated pulse counter for the gas meter an attached it to this cheap zigbee water leak sensor (about $2 from Aliexpress)
Przechwytywanie
I also have window sensor from that line, and the hardware is basically the same.
Anyway it works surprisingly well, given that the sensor is placed on the outside wall and in a metal box (but there is a zigbee smart plug right on the other side of the wall). I’ve been using this for over a year now, I had to replace the batteries once after a whole year! Every month after making updates to my HA I check the couter with my meter to calibrate it, in the winter months I did loose only about 1% of pulses (about 20 to 30), in the summer maybe 3 or 4 pulses a month!
My experience is that this is a very good and cheap solution to get info from your meter, just make sure you connect it in a place where all the pulses are picked up by the door sesnor. If you want I can paste my code and tell you how I got everything working.
You can use Vaterius GitHub - dontsovcmc/waterius: Передача показаний воды по Wi-Fi. Watermeter Wi-Fi transmitter.
This is what I build: DIY Inductive Zigbee water meter
Hi !
I really want your setup @DominikW . Can you share scripts / pictures of this setup ?
I have a water meter with pulse counter ( mbus output) (sensus HRI B4) and I just want to connect the wires to a pulse counter wireless ( zigbee by exemple)
Your solution seems low cost and smart, so if you can share how you adapt the water leak sensor to a pulse counter I m in !
Nighoa
I had to buy a dedicated reed switch for my gas meter https://api.apator.com/uploads/oferta/gaz/nadajnik-impulsow-ni-3-dtr.pdf
Then I just cut the wire of the reed switch and the water sensor and connected the wires from the water sensor to the green and brown wires. When the magnet closes the connection it is shown as a leak in the water sensor.
Looking at your sensus you can do the same, just cut the wire comming out of the sensor and connect to the water leak sensor.
You can get alot of info and some pictures of how this works from this forum:
https://ai-speaker.discourse.group/t/bezprzewodowy-odczyt-licznika-gazu-metrix-g4-ugt-ai-speaker-home-assistant/2288/1
It is in Polish, but using google translate should work just fine.
Hello everyone,
I’m excited to share a project I’ve been working on: Zigbee Gas Meter.
This is a fully open-source solution for gas metering using Zigbee, designed to integrate seamlessly with Home Assistant. The project addresses several challenges in creating a reliable and efficient gas metering device, and it’s now mature enough to be shared with the community.
While the “counter” functionality is fully implemented and operational, there are still some pending decisions, such as finalizing the best power solution for the unit (e.g., using a LiPo battery or a CR123A battery).
I welcome contributions from other developers who are interested in improving or expanding the project. Your feedback and ideas are also greatly appreciated!
Feel free to check out the GitHub repository for more details.
Looking forward to hearing your thoughts!
Best regards,
Ignacio
Hi Ignacio, nice project there you have.
When fully functional (to your wishes) it could be a candidate to put it in the Share your Projects! subforum (if you want)
How is that ESP32-C6 doing because I have seen some threads (maybe you’ve seen them too) in which ESP & zigbee is not mature yet.
Hi @Nick4
It is already shared! thank you for the advice. Zigbee Gas Counter in ‘Share your projects’ subforum
I haven’t had any issues with the ESP32-C6 and Zigbee. My coordinator is EmberZNet (firmware 8.0.2 [GA]), but this is a separate Zigbee network I set up for development. It only has four devices, as I wanted to keep it isolated from my home network. During the development of the Zigbee2MQTT file, I encountered some stability issues, so I preferred to test in a dedicated environment.
Hey Dominik.
So if I cut the sensor off a water leak sensor like this I can simply pulse two of the wires together to create an input thanks?
Regards Mick
Yep, connect the wires from the leak sensor to the pulse counter and it will work. Mine sensor work without a problem to this day.
Great thanks. The sensor arrived.
How do I program now please thanks?
I have Z2M
https://community.home-assistant.io/t/zigbee-pulse-counter/744171/9?u=dominikw
Just fallow the steps from the link in the post, it is in Polish but you can use google translate.
