Zigbee2MQTT - Control Alarmo via keypad
Yeah I have. It looks correct to me (see example output):
Zigbee2MQTT:info  2022-09-07 09:22:57: MQTT publish: topic 'zigbee2mqtt/Kitchen Door Keypad', payload '{"action":"arm_all_zones","action_code":"1234","action_zone":23,"battery":100,"battery_low":false,"contact":true,"linkquality":0,"occupancy":false,"tamper":false,"temperature":20,"voltage":6300}'
Great work.
Do you have entry delay working?
Got it more or less all working except the entry delay.
As said in my original post:
This is what I am seeing.
Ofcourse you should have set up Alarmo to have an entry delay as well.
Ok yes…
I did not know it went in more detail in the sensor option.
Works great. Thanks
Thank you @neliss! I was just attempting to rewrite the blueprint from @AndrejDelany with alarmo and came across this post. I am using this with an XFINITY XHK1-UE and noticed that your blueprint didn’t include a night mode. I attempted to add it to your blueprint and it works well as long as you don’t have an exit_delay set for night mode in alarmo… Not sure why setting the alarm_night_zones doesn’t clear the exit_delay… not sure if it is a device issue or a z2m issue, or if it’s me. I thought I’d share my edits:
blueprint:
  name: Alarmo Keypad Sync (gremblin)
  description: Xfinity XHK1-UE Keypad sync with Alarmo edited by gremblin
  domain: automation
  input:
    state_topic:
      name: MQTT State Topic of your Zigbee2MQTT Keypad
      description: 'The State Topic is composed of your Zigbee2MQTT base_topic (see
        your Z2M Addon Configuration) and the Friendly Name of your keypad in Z2M.
        Example: zigbee2mqtt/Keypad'
      selector:
        text: {}
    set_topic:
      name: MQTT Set Topic of your Zigbee2MQTT Keypad
      description: 'This is the same as your State Topic, with the addition of /set.
        Example: zigbee2mqtt/Keypad/set'
      selector:
        text: {}
    entity:
      description: An alarm control panel entity from alarmo.
      selector:
        entity:
          domain: alarm_control_panel
          integration: alarmo
          multiple: false
- platform: state
  entity_id: !input entity
  to: disarmed
- platform: state
  to: arming
- platform: state
  to: armed_away
- platform: state
  to: armed_home
- platform: state
  to: armed_night
- platform: state
  to: armed_vacation
- platform: state
  to: armed_custom_bypass
- platform: state
  to: pending
- platform: state
  to: triggered
- platform: mqtt
  topic: !input state_topic
- platform: event
  event_type: alarmo_failed_to_arm
- platform: event
  event_type: alarmo_command_success
condition: []
- choose:
  - conditions:
    - condition: trigger
    sequence:
    - service: mqtt.publish
      data_template:
        topic: !input set_topic
        payload: "{\n  \"arm_mode\": \n  {\n    \"mode\": \"disarm\"\n  }\n}"
  - conditions:
    sequence:
      data_template:
        payload: "{\n  \"arm_mode\": \n  {\n    \"mode\": \"exit_delay\"\n  }\n}"
  - conditions:
    sequence:
      data_template:
        payload: "{\n  \"arm_mode\": \n  {\n    \"mode\": \"arm_all_zones\"\n  }\n}"
  - conditions:
    sequence:
      data_template:
        payload: "{\n  \"arm_mode\": \n  {\n    \"mode\": \"arm_day_zones\"\n  }\n}"
  - conditions:
    sequence:
      data_template:
        payload: "{\n  \"arm_mode\": \n  {\n    \"mode\": \"arm_night_zones\"\n  }\n}"
  - conditions:
    sequence:
      data_template:
        payload: "{\n  \"arm_mode\": \n  {\n    \"mode\": \"entry_delay\"\n  }\n}"
  - conditions:
    sequence:
      data_template:
        payload: "{\n  \"arm_mode\": \n  {\n    \"mode\": \"in_alarm\"\n  }\n}"
  - conditions:
    sequence:
    - choose:
      - conditions:
        - condition: template
          value_template: '{{ trigger.payload_json.action == "disarm"  }}'
        sequence:
        - service: alarmo.disarm
            code: '{{ trigger.payload_json.action_code }}'
            context_id: '{{ trigger.payload_json.action_transaction }}'
      - conditions:
          value_template: '{{ trigger.payload_json.action == "arm_all_zones"  }}'
        sequence:
        - service: alarmo.arm
            mode: away
      - conditions:
          value_template: '{{ trigger.payload_json.action == "arm_day_zones"  }}'
        sequence:
            mode: home
      - conditions:
          value_template: '{{ trigger.payload_json.action == "arm_night_zones"  }}'
        sequence:
            mode: night
  - conditions:
    sequence:
    - choose:
      - conditions:
          value_template: '{{ trigger.event.data.reason == ''invalid_code'' }}'
        sequence:
          data_template:
            payload: "{\n  \"arm_mode\": \n  {\n    \"transaction\": {{ trigger.event.data.context_id
              }},\n    \"mode\": \"invalid_code\"\n  }\n}"
      - conditions:
          value_template: '{{ trigger.event.data.reason == ''open_sensors'' }}'
        sequence:
        # `not_ready` doesnt do anything, so modifying behavor to beep for 1 sec, then disarm
          data_template:
            payload: >-
              {\n \"arm_mode\": \n {\n \"transaction\": {{ trigger.event.data.context_id }},\n \"mode\": \"entry_delay\"\n}\n}
        - delay: 1
          data_template:
            payload: >-
              {\n \"arm_mode\": \n {\n \"transaction\": {{ trigger.event.data.context_id }},\n \"mode\": \"disarm\"\n }\n}
      - conditions:
          value_template: '{{ trigger.event.data.reason == ''not_allowed'' }}'
          value_template: '{{ trigger.event.data.command|lower == ''disarm'' }}'
        sequence:
          data_template:
            payload: >-
              {\n \"arm_mode\": \n {\n \"transaction\": {{ trigger.event.data.context_id }},\n \"mode\": \"already_disarmed\"\n }\n}
  - conditions:
    sequence:
    - choose:
      - conditions:
          value_template: '{{ trigger.event.data.action == ''arm'' }}'
          value_template: '{{ trigger.event.data.context_id != null }}'
          value_template: '{{ trigger.event.data.mode == ''away'' }}'
        sequence:
          data_template:
            payload: >-
              {\n \"arm_mode\": \n {\n \"transaction\": {{ trigger.event.data.context_id }},\n \"mode\": \"arm_all_zones\"\n }\n}
      - conditions:
          value_template: '{{ trigger.event.data.mode == ''home'' }}'
        sequence:
          data_template:
            payload: >-
              {\n \"arm_mode\": \n {\n \"transaction\": {{ trigger.event.data.context_id }},\n \"mode\": \"arm_day_zones\"\n }\n}
      - conditions:
          value_template: '{{ trigger.event.data.mode == ''night'' }}'
        sequence:
          data_template:
            payload: >-
              {\n \"arm_mode\": \n {\n \"transaction\": {{ trigger.event.data.context_id }},\n    \"mode\": \"arm_night_zones\"\n  }\n}
      - conditions:
          value_template: '{{ trigger.event.data.action == ''disarm'' }}'
        sequence:
          data_template:
            payload: >-
mode: parallel
max: 10
If you scroll a few posts back you will find another version modified for the XHK1-UE as well: Zigbee2MQTT - Control Alarmo via keypad - #16 by jsdphilly.
I’m intending to make an update to my original blueprint to achieve a one-fits-all but I must admit I didn’t take the effort yet…
Thanks for pointing that out. I missed that post. I just tested it and it is acting goofy on my XHK1-UE. When disarmed, the keypad temporally goes into arm_night_zones, and I think it went into that mode briefly when arming away.
your edit is what i was looking for. I don’t mine not setting an exit delay for night mode.
This blueprint works great for me, but my Alarmo state is not represented on my Xfinity XHK1-UE keypad. Are you on the dev branch of z2m
no. I’m on the main production branch of z2m… I just updated the blueprint with some tweeks I did. It shouldn’t fix your problem though. Yours should sync in it’s previous state.
This works on the Centralite 3400 keypad, but it never lets the keypad know that it is indeed armed.
For example, the keypad remains with 2 green lights (disarmed state), and doesn’t have any of the armed mode buttons lit.
The keypad is able to arm/disarm Alarmo though.
Any idea what could be wrong?
Same. I can arm/disarm the alarm from the keypad, but the keypad always shows green LED’s like it’s disarmed. I’m not sure if Z2M has the ability to manage the ā€œstateā€ of the keypad. Anyone else figure this out? I know Centralite 3400 keypad works fine under ST and Hubitat, but not HomeAssistant… HA is supposed to be better, but it fails to work with a ridiculously old keypad, kinda sad.
My keypad (KEYZB-110 from Frient/Develco) works - but not always. I also see a lot of errors which I believe come from this blueprint (or are the result of a wrong configuration somewhere?).
My set-up:
  • HA, zigbee2mqtt, mosquitto: all running in docker (so no HA supervised). Should all be latest versions.
  • Alarmo set-up and running
I have the feeling it was running more stable when on HA supervised - but that might just be a feeling…
A subset of the errors. Anyone can give me ideas where to look at?
2023-03-08 16:22:31.682 WARNING (MainThread) [homeassistant.components.mqtt.mixins] Erroneous JSON: pending
2023-03-08 16:22:31.683 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.battery }}'
2023-03-08 16:22:31.685 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.voltage }}'
2023-03-08 16:22:31.687 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.action_code }}'
2023-03-08 16:22:31.689 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.action_transaction }}'
2023-03-08 16:22:31.691 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.action_zone }}'
2023-03-08 16:22:31.693 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.action }}'
2023-03-08 16:22:31.695 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.linkquality }}'
2023-03-08 16:22:31.697 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.last_seen }}'
2023-03-08 16:22:31.699 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.battery_low }}'
2023-03-08 16:22:31.701 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'value_json' is undefined (value: pending, template: {{ value_json.battery_low }})
2023-03-08 16:22:31.703 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'value_json' is undefined when rendering '{{ value_json.tamper }}'
2023-03-08 16:22:31.704 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'value_json' is undefined (value: pending, template: {{ value_json.tamper }})
2023-03-08 16:22:31.706 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'value_json' is undefined (value: pending, template: {{ value_json['update']['state'] == "available" }})
2023-03-08 16:22:31.708 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'value_json' is undefined (value: pending, template: {{ value_json['update']['installed_version'] }})
2023-03-08 16:22:31.709 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'value_json' is undefined (value: pending, template: {{ value_json['update']['latest_version'] }})
2023-03-08 16:22:31.723 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'payload_json' when rendering '{{ trigger.payload_json.action == "disarm"  }}'
2023-03-08 16:22:31.726 WARNING (MainThread) [homeassistant.helpers.script] Error in 'choose[0]' evaluation: In 'template' condition: UndefinedError: 'dict object' has no attribute 'payload_json'
2023-03-08 16:22:31.729 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'payload_json' when rendering '{{ trigger.payload_json.action == "arm_all_zones"  }}'
2023-03-08 16:22:31.731 WARNING (MainThread) [homeassistant.helpers.script] Error in 'choose[0]' evaluation: In 'template' condition: UndefinedError: 'dict object' has no attribute 'payload_json'
2023-03-08 16:22:31.732 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'payload_json' when rendering '{{ trigger.payload_json.action == "arm_day_zones"  }}'
2023-03-08 16:22:31.736 WARNING (MainThread) [homeassistant.helpers.script] Error in 'choose[0]' evaluation: In 'template' condition: UndefinedError: 'dict object' has no attribute 'payload_json'
2023-03-08 16:22:45.220 WARNING (MainThread) [custom_components.alarmo.alarm_control_panel] Wrong code provided.
2023-03-08 16:22:51.608 WARNING (MainThread) [homeassistant.components.mqtt.mixins] Erroneous JSON: triggered
2023-03-08 16:22:51.613 WARNING (MainThread) [homeassistant.components.mqtt.mixins] Erroneous JSON: triggered
2023-03-08 16:22:51.617 WARNING (MainThread) [homeassistant.components.mqtt.mixins] Erroneous JSON: triggered
2023-03-08 16:22:51.619 WARNING (MainThread) [homeassistant.components.mqtt.mixins] Erroneous JSON: triggered
2023-03-08 16:22:51.620 WARNING (MainThread) [homeassistant.components.mqtt.mixins] Erroneous JSON: triggered
2023-03-08 16:22:51.621 WARNING (MainThread) [homeassistant.components.mqtt.mixins] Erroneous JSON: triggered
I just started using this (bought a new zigbee dongle just to be able to add linkind kp as zigbee2mqtt).
Two nice features would be:
  • to have the delay in/out bips - I made them with a speaker, but not the same thing
  • to have the device light up once the delay entry is triggered
Do you know if there is a current keyboard that works with this blueprint? I can’t find any for sale.
Thanks.
Hive KEYPAD001 works well
Thanks for the warning, I’ve been looking for it but it’s not sold in Europe, let’s see if one appears on AliExpress.
I bought mine from Ebay a few days ago. Only cost me £19
It’s amazing, no zigbee keyboard is sold in Europe! I am looking for one too…
Plenty of Hive KEYPAD001’s on eBay …
