Absolutely @francisp I wanted to see if this was software by illimation.
I’ve moved them all back now perhaps a little too soon though. Some of the devices weren’t supported to well, and still I lost one of the devices, but it was strange. This one Aurora Aone dummer, has a back light, and a control for the lights. The backlight still worked, but the dimmer ‘switch’ didn’t.
So now I am all back on Z22M. Network issues continue. I am on the ZZH stick on a different USB and extension.
Today the network slowed then fell over, Z2M no longer recognised the ZZH stick which needed to be physically pulled and reinserted to start again.
I am continually seeing messages for devices like " Accepting joining not in blocklist device ‘0x84b4dbfffe089599’ ", which are then often followed by a " Failed to read state of " message.
Is there a good way to share a debug log, other than a short part like below?
The only thing that is coming to mind now is the Tigo Solar optimisers, when the network was on channel 11, the optimisers caused such severe interferance that it would cause a number of devices to reset them selves (in the case of some sockets, would power off, and lights power on), this is why I moved to channel 15, where the issue didn’t seem to happen. I wonder if I need to move channel again perhaps - but I am not sure where to go ![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=10)
debug 2023-08-19 12:18:27: Device 'Office Top Light' announced itself
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"Office Top Light","ieee_address":"0x84b4dbfffe0bcc2c"},"type":"device_announce"}'
debug 2023-08-19 12:18:27: Received Zigbee message from 'Dining Room Presence 2', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,1,143],"type":"Buffer"},"datatype":2,"dp":9}],"seq":13824}' from endpoint 1 with groupID 0
debug 2023-08-19 12:18:27: Received Zigbee message from 'DiningRoomDoubleSocket1', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"fileVersion":22,"imageType":5129,"manufacturerCode":4636}' from endpoint 1 with groupID 0
debug 2023-08-19 12:18:27: Device 'DiningRoomDoubleSocket1' requested OTA
debug 2023-08-19 12:18:27: Received Zigbee message from 'Kitchen Motion Sensor', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":16676}' from endpoint 2 with groupID 0
info 2023-08-19 12:18:27: Accepting joining not in blocklist device '0x0017880108676250'
info 2023-08-19 12:18:27: Accepting joining not in blocklist device '0x84b4dbfffe089593'
debug 2023-08-19 12:18:27: Device 'Dining Room Lights 1' announced itself
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"Dining Room Lights 1","ieee_address":"0x84b4dbfffe089593"},"type":"device_announce"}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Dining Room Presence 2', payload '{"cli":" ","detection_delay":0.1,"fading_time":5,"illuminance_lux":2000,"linkquality":98,"maximum_range":6,"minimum_range":0.6,"presence":true,"radar_sensitivity":8,"self_test":"check_success","target_distance":3.96}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Monitor', payload '{"energy":0.01,"linkquality":94,"power":34,"state":"ON"}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Dishwasher', payload '{"energy":0.03,"linkquality":58,"power":1,"state":"ON"}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/AC1P', payload '{"energy":0.07,"linkquality":65,"power":2,"state":"ON"}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Dining Room Presence 2', payload '{"cli":" ","detection_delay":0.1,"fading_time":5,"illuminance_lux":2000,"linkquality":98,"maximum_range":6,"minimum_range":0.6,"presence":true,"radar_sensitivity":8,"self_test":"check_success","target_distance":4}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Living Room Motion Sensor', payload '{"battery":100,"illuminance":10108,"illuminance_lux":10,"led_indication":null,"linkquality":76,"motion_sensitivity":"high","occupancy":true,"occupancy_timeout":0,"temperature":23.89,"update":{"installed_version":1107323831,"latest_version":1107323831,"state":"idle"},"update_available":null}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Kitchen Motion Sensor', payload '{"battery":100,"illuminance":16676,"illuminance_lux":47,"led_indication":true,"linkquality":98,"motion_sensitivity":"high","occupancy":true,"occupancy_timeout":0,"temperature":22.11,"update":{"installed_version":1107323831,"latest_version":1107323831,"state":"idle"},"update_available":false}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Landing Motion Sensor', payload '{"battery":100,"illuminance":11563,"illuminance_lux":14,"led_indication":true,"linkquality":72,"motion_sensitivity":"high","occupancy":true,"occupancy_timeout":0,"temperature":21.9,"update":{"installed_version":1107323831,"latest_version":1107323831,"state":"idle"},"update_available":false}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Dining Room Presence 2', payload '{"cli":" ","detection_delay":0.1,"fading_time":5,"illuminance_lux":2000,"linkquality":98,"maximum_range":6,"minimum_range":0.6,"presence":true,"radar_sensitivity":8,"self_test":"check_success","target_distance":4.03}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Dining Room Presence 2', payload '{"cli":" ","detection_delay":0.1,"fading_time":5,"illuminance_lux":2000,"linkquality":98,"maximum_range":6,"minimum_range":0.6,"presence":true,"radar_sensitivity":8,"self_test":"check_success","target_distance":4.04}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Microwave', payload '{"energy":0.09,"linkquality":36,"power":0,"state":"OFF"}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Washing Machine', payload '{"energy":0.01,"linkquality":72,"power":0,"state":"ON"}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Dining Room Presence 2', payload '{"cli":" ","detection_delay":0.1,"fading_time":5,"illuminance_lux":2000,"linkquality":98,"maximum_range":6,"minimum_range":0.6,"presence":true,"radar_sensitivity":8,"self_test":"check_success","target_distance":3.99}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Bathroom Top Light', payload '{"brightness":76,"color_mode":"color_temp","color_temp":301,"linkquality":54,"power_on_behavior":"previous","state":"OFF","update":{"installed_version":16785666,"latest_version":16785666,"state":"idle"},"update_available":false}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Landing Motion Sensor', payload '{"battery":100,"illuminance":11563,"illuminance_lux":14,"led_indication":true,"linkquality":72,"motion_sensitivity":"high","occupancy":false,"occupancy_timeout":0,"temperature":21.9,"update":{"installed_version":1107323831,"latest_version":1107323831,"state":"idle"},"update_available":false}'
info 2023-08-19 12:18:27: MQTT publish: topic 'zigbee2mqtt/Kitchen Motion Sensor', payload '{"battery":100,"illuminance":16676,"illuminance_lux":47,"led_indication":true,"linkquality":98,"motion_sensitivity":"high","occupancy":false,"occupancy_timeout":0,"temperature":22.11,"update":{"installed_version":1107323831,"latest_version":1107323831,"state":"idle"},"update_available":false}'
debug 2023-08-19 12:18:28: Retrieving state of 'Bedroom Top Light' after reconnect
debug 2023-08-19 12:18:29: Retrieving state of 'Dining Room Lights 2' after reconnect
debug 2023-08-19 12:18:29: Retrieving state of 'Office Top Light' after reconnect
debug 2023-08-19 12:18:29: Retrieving state of 'Dining Room Lights 1' after reconnect
debug 2023-08-19 12:18:32: Received Zigbee message from 'Dining Room Presence 2', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,1,146],"type":"Buffer"},"datatype":2,"dp":9}],"seq":14080}' from endpoint 1 with groupID 0
info 2023-08-19 12:18:32: MQTT publish: topic 'zigbee2mqtt/Dining Room Presence 2', payload '{"cli":" ","detection_delay":0.1,"fading_time":5,"illuminance_lux":2000,"linkquality":98,"maximum_range":6,"minimum_range":0.6,"presence":true,"radar_sensitivity":8,"self_test":"check_success","target_distance":4.02}'
info 2023-08-19 12:18:32: MQTT publish: topic 'zigbee2mqtt/Dining Room Presence 2', payload '{"cli":" ","detection_delay":0.1,"fading_time":5,"illuminance_lux":2000,"linkquality":98,"maximum_range":6,"minimum_range":0.6,"presence":true,"radar_sensitivity":8,"self_test":"check_success","target_distance":4.01}'
info 2023-08-19 12:18:32: MQTT publish: topic 'zigbee2mqtt/Living Room Motion Sensor', payload '{"battery":100,"illuminance":10108,"illuminance_lux":10,"led_indication":null,"linkquality":72,"motion_sensitivity":"high","occupancy":false,"occupancy_timeout":0,"temperature":23.89,"update":{"installed_version":1107323831,"latest_version":1107323831,"state":"idle"},"update_available":null}'
debug 2023-08-19 12:18:32: Received Zigbee message from 'Living Room Motion Sensor', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":0}' from endpoint 2 with groupID 0
error 2023-08-19 12:18:33: Failed to read state of 'Bedroom Top Light' after reconnect (Read 0x84b4dbfffe08a63a/1 genOnOff(["onOff"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
error 2023-08-19 12:18:39: Failed to read state of 'Dining Room Lights 2' after reconnect (Read 0x84b4dbfffe089599/1 genOnOff(["onOff"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
error 2023-08-19 12:18:45: Failed to read state of 'Office Top Light' after reconnect (Read 0x84b4dbfffe0bcc2c/1 genOnOff(["onOff"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
error 2023-08-19 12:18:51: Failed to read state of 'Dining Room Lights 1' after reconnect (Read 0x84b4dbfffe089593/1 genOnOff(["onOff"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms))
