I have a zigbee2mqtt server running and the proxy addon in HA.
The status of all my zigbee devices alternates between unavailable and the respective entity status. It can be observed that the status changes to unavailable after a while (usually between 1 - 3 hours). After less than a minute (usually only 5 seconds), the correct status is then displayed again.
I run all the components on Proxmox:
HA: HASS-OS in VM
mqtt: lxc
zigbee2mqtt: lxc
zigbeecoordinator: lan-coordinator
Basically, every Zigbee device reports its status correctly. However, I am not sure why the status of the entities is always set to unavailable after some time.
Unfortunately, I have not been able to find any other similar cases in the forum.
True. Add that to my (ever growing) list of things to do.
Oooohhhh that would be nice… However, I can’t remember the last time I had a device drop off my mesh to be honest (finding the biggest wooden thing I can find to knock on lol). But having the notifications wouldn’t hurt either.
I got alerted that my lane gate monitor was unavailable the other day. Its an Aqara contact sensor PCB in a waterproof box. Turns out the battery had fallen out
lmao! I actually just replaced all my SmartThings MP sensors with Aqara ones for kind of the same reason. The battery holder in a few of my MP sensors wore out and the batteries would lose contact sometimes. But, they would only go offline for an hour or two and then reconnect.
The “unavailable” messages also appear when nobody is at home and there is no other activity in the HA.
What I have just noticed is that the “unavailable” messages appear on all devices at exactly the same time.
The message may not even be coming from the communication from the device to z2m, but rather from the mqtt communication.
Strangely enough, I don’t have any of these messages on other devices.
Sorry for the late answer.
I’m still not sure what the problem was, but I’ve managed to solve it in the meantime.
I suspect that the LAN coordinator I was using was the problem. I still had a Sonoff Zigbee stick and have now set up the whole Zigbee network again. Since then, the entities have been working as desired and I no longer have any “not available” messages.
I think I rejoiced too soon.
In the newly set up Zigbee network with the Sonoff zigbee usb stick, I first connected all devices supplied with continuous current (except for the Ikea Tradfri lamps), then the battery-operated devices.
I did not initially connect the Ikea lamps to the network (due to time constraints). I only did that yesterday.
Since the Ikea lights have also been connected to the Zigbee network, I’ve been having the same problems with all the devices going to “unavailable” from time to time, but then reappearing after a short time.
I’m really at a loss now.
