AndSzy
(Andrew)
1
Im using Home Assistant Green with SkyConnect stick, but cant run the Zigbee2MQTT.
00:01:29] INFO: Preparing to start...
[00:01:30] INFO: Socat not enabled
[00:01:35] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-03-14 00:01:44: Logging to console and directory: '/config/zigbee2mqtt/log/2024-03-14.00-01-44' filename: log.txt
Zigbee2MQTT:info 2024-03-14 00:01:44: Starting Zigbee2MQTT version 1.36.0 (commit #unknown)
Zigbee2MQTT:info 2024-03-14 00:01:44: Starting zigbee-herdsman (0.35.1)
Zigbee2MQTT:error 2024-03-14 00:02:05: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-03-14 00:02:05: Failed to start zigbee
Zigbee2MQTT:error 2024-03-14 00:02:05: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-03-14 00:02:05: Exiting...
Zigbee2MQTT:error 2024-03-14 00:02:05: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
Hardware:
ID_MODEL: SkyConnect_v1.0
ID_MODEL_ENC: SkyConnect\x20v1.0
Any ideas?
Bear in mind that SkyConnect is still “experimental” with Z2M.
AndSzy
(Andrew)
3
after adding adapter: ezsp i have this error:
[00:18:07] INFO: Preparing to start...
[00:18:09] INFO: Socat not enabled
[00:18:14] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-03-14 00:18:23: Logging to console and directory: '/config/zigbee2mqtt/log/2024-03-14.00-18-23' filename: log.txt
Zigbee2MQTT:info 2024-03-14 00:18:23: Starting Zigbee2MQTT version 1.36.0 (commit #unknown)
Zigbee2MQTT:info 2024-03-14 00:18:23: Starting zigbee-herdsman (0.35.1)
Zigbee2MQTT:error 2024-03-14 00:19:34: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-03-14 00:19:34: Failed to start zigbee
Zigbee2MQTT:error 2024-03-14 00:19:34: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-03-14 00:19:34: Exiting...
Zigbee2MQTT:error 2024-03-14 00:19:34: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:373:19)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:163:13)
AndSzy
(Andrew)
5
No, its not.
How can i check the firmware installed on SkyConnect?
Is it listed under hardware?
AndSzy
(Andrew)
7
The SkyConnect is listed there.
Just checked it has multiprotocol installed.
See if you can find something useful here
francisp
(Francis)
9
If multiprotocol is installed , 2 things:
- you can’t use /dev/serial/by-id
- Zigbee2MQTT only works with multiprotocol 2.4.2 or earlier, 2.4.3 and 2.4.4 are not supported
AndSzy
(Andrew)
10
how do i go back to Zigbee firmware ?
I read about Silicon Labs Flasher , but not sure how can i do this on Home Assistant Green.
WallyR
(Wally)
11
Not sure how the SSH flashing is done, but it sounds like the way here.
Edit: The Home Assistant Green does not have the radio builtin, so web flasher is probably the easiest way.
francisp
(Francis)
12
Use Chrome or Edge to access this page:
Dongle needs to be in the computer you use the browser on
AndSzy
(Andrew)
14
Thanks.
Im back to zigbee firmaware, but the error is still the same:
[10:22:20] INFO: Preparing to start...
[10:22:21] INFO: Socat not enabled
[10:22:27] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-03-14 10:22:36: Logging to console and directory: '/config/zigbee2mqtt/log/2024-03-14.10-22-36' filename: log.txt
Zigbee2MQTT:info 2024-03-14 10:22:36: Starting Zigbee2MQTT version 1.36.0 (commit #unknown)
Zigbee2MQTT:info 2024-03-14 10:22:36: Starting zigbee-herdsman (0.35.1)
Zigbee2MQTT:error 2024-03-14 10:23:07: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-03-14 10:23:07: Failed to start zigbee
Zigbee2MQTT:error 2024-03-14 10:23:07: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-03-14 10:23:07: Exiting...
Zigbee2MQTT:error 2024-03-14 10:23:07: Error: Failure to connect
Ill reset the device and start from the beginning. Any advices?
alp-by
(alp)
15
let us UP topic. Any ideas or solutions? I met the same issue
