Just rebooted my NUC and my lights wont work anymore with Zigbee2Mqtt.
I am using the Latest docker image and commit #52c51b6.
> [email protected] start /app
> node index.js
2018-6-29 15:19:33 INFO Starting zigbee2mqtt version 0.0.0 (commit #52c51b6)
2018-6-29 15:19:33 INFO Starting zigbee-shepherd
2018-6-29 15:19:34 INFO zigbee-shepherd started
2018-6-29 15:19:34 INFO Currently 10 devices are joined:
2018-6-29 15:19:34 INFO dining_rm (0x000b57fffeaff3ec): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
2018-6-29 15:19:34 INFO sitting_rm (0x000b57fffe9b7a5e): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
2018-6-29 15:19:34 INFO unknown (0x000b57fffeaa2748): unkown - undefined unknown (EndDevice)
2018-6-29 15:19:34 INFO side_lamp (0x000b57fffe9db595): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
2018-6-29 15:19:34 INFO corner_lamp (0x000b57fffe9b9c1a): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
2018-6-29 15:19:34 INFO 0x000b57fffeb2d061 (0x000b57fffeb2d061): unkown - undefined unknown (EndDevice)
2018-6-29 15:19:34 INFO dining_lamp (0x90fd9ffffe1fbdaa): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
2018-6-29 15:19:34 INFO cam_bedside (0x90fd9ffffe8cf708): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
2018-6-29 15:19:34 INFO dimmer_small (0x000b57fffe2c5c77): ICTC-G-1 - IKEA TRADFRI wireless dimmer (EndDevice)
2018-6-29 15:19:34 INFO sally_bedside (0x90fd9ffffe897d97): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
2018-6-29 15:19:34 WARN `permit_join` set to `true` in configuration.yaml.
2018-6-29 15:19:34 WARN Allowing new devices to join.
2018-6-29 15:19:34 WARN Set `permit_join` to `false` once you joined all devices.
2018-6-29 15:19:34 INFO Zigbee: allowing new devices to join.
2018-6-29 15:19:34 INFO Connecting to MQTT server at mqtt://192.168.85.5
2018-6-29 15:19:34 INFO zigbee-shepherd ready
2018-6-29 15:19:34 INFO Connected to MQTT server
2018-6-29 15:19:34 INFO MQTT publish, topic: 'zigbee2mqtt/bridge/state', payload: 'online'
2018-6-29 15:19:34 INFO MQTT publish, topic: 'homeassistant/light/0x000b57fffeaff3ec/light/config', payload: '{"brightness":true,"color_temp":true,"platform":"mqtt_json","command_topic":"zigbee2mqtt/dining_rm/set","state_topic":"zigbee2mqtt/dining_rm","availability_topic":"zigbee2mqtt/bridge/state","name":"dining_rm"}'
2018-6-29 15:19:34 INFO MQTT publish, topic: 'homeassistant/light/0x000b57fffe9b7a5e/light/config', payload: '{"brightness":true,"color_temp":true,"platform":"mqtt_json","command_topic":"zigbee2mqtt/sitting_rm/set","state_topic":"zigbee2mqtt/sitting_rm","availability_topic":"zigbee2mqtt/bridge/state","name":"sitting_rm"}'
2018-6-29 15:19:34 INFO MQTT publish, topic: 'homeassistant/light/0x000b57fffe9db595/light/config', payload: '{"brightness":true,"color_temp":true,"platform":"mqtt_json","command_topic":"zigbee2mqtt/side_lamp/set","state_topic":"zigbee2mqtt/side_lamp","availability_topic":"zigbee2mqtt/bridge/state","name":"side_lamp"}'
2018-6-29 15:19:34 INFO MQTT publish, topic: 'homeassistant/light/0x000b57fffe9b9c1a/light/config', payload: '{"brightness":true,"color_temp":true,"platform":"mqtt_json","command_topic":"zigbee2mqtt/corner_lamp/set","state_topic":"zigbee2mqtt/corner_lamp","availability_topic":"zigbee2mqtt/bridge/state","name":"corner_lamp"}'
2018-6-29 15:19:34 INFO MQTT publish, topic: 'homeassistant/light/0x90fd9ffffe1fbdaa/light/config', payload: '{"brightness":true,"color_temp":true,"platform":"mqtt_json","command_topic":"zigbee2mqtt/dining_lamp/set","state_topic":"zigbee2mqtt/dining_lamp","availability_topic":"zigbee2mqtt/bridge/state","name":"dining_lamp"}'
2018-6-29 15:19:34 INFO MQTT publish, topic: 'homeassistant/light/0x90fd9ffffe8cf708/light/config', payload: '{"brightness":true,"color_temp":true,"platform":"mqtt_json","command_topic":"zigbee2mqtt/cam_bedside/set","state_topic":"zigbee2mqtt/cam_bedside","availability_topic":"zigbee2mqtt/bridge/state","name":"cam_bedside"}'
2018-6-29 15:19:34 INFO MQTT publish, topic: 'homeassistant/sensor/0x000b57fffe2c5c77/brightness/config', payload: '{"unit_of_measurement":"brightness","icon":"mdi:brightness-5","value_template":"{{ value_json.brightness }}","json_attributes":[],"state_topic":"zigbee2mqtt/dimmer_small","availability_topic":"zigbee2mqtt/bridge/state","name":"dimmer_small"}'
2018-6-29 15:19:34 INFO MQTT publish, topic: 'homeassistant/light/0x90fd9ffffe897d97/light/config', payload: '{"brightness":true,"color_temp":true,"platform":"mqtt_json","command_topic":"zigbee2mqtt/sally_bedside/set","state_topic":"zigbee2mqtt/sally_bedside","availability_topic":"zigbee2mqtt/bridge/state","name":"sally_bedside"}'
2018-6-29 15:19:35 INFO
{"message":"request unsuccess: 17","stack":"Error: request unsuccess: 17\n at /app/node_modules/zigbee-shepherd/lib/components/zdo.js:46:21\n at CcZnp.<anonymous> (/app/node_modules/cc-znp/lib/ccznp.js:257:13)\n at Object.onceWrapper (events.js:315:30)\n at emitOne (events.js:116:13)\n at CcZnp.emit (events.js:211:7)\n at CcZnp._mtIncomingDataHdlr (/app/node_modules/cc-znp/lib/ccznp.js:357:14)\n at /app/node_modules/cc-znp/lib/ccznp.js:333:22\n at _combinedTickCallback (internal/process/next_tick.js:131:7)\n at process._tickCallback (internal/process/next_tick.js:180:9)"}
2018-6-29 15:19:44 INFO Zigbee publish to '0x000b57fffeaff3ec', genOnOff - on - {} - null
And i cant add any new lights.
Any Help please
