May be the only way as I cannot find the elusive topic to publish a null to. I’m on Hassio. Mosquito Broker addon config says there is a mosquitto folder. Mosquitto log says: 1545933123: Saving in-memory database to /data/mosquitto.db.
I can’t seem to find this database so I can delete it. I ssh using root credentials, and browsed through the folders looking using “ls” Doesn’t seem to be anything in the /data folder unless it’s hidden somehow. Also browsed the Samba share looking. Any tips on finding this database so I can delete it? Obviously I’m a little over my head.
Edit:
Tried find . -name "mosquitto.db" and it found nothing.
1 Copy the mqtt configuration in the web gui of hass.io
2 Uninstall mqtt add-on
3 Reinstal mqtt add-on
4 Paste back the config info into the web gui
5 Click save config changes
6 Restart the mqtt plugin
This will kill all the old retained topics and sensors.
Zigbee2mqtt will repopulate all the existing sensors when you restart the zigbee2mqtt add-on
This is tad puzzling: earlier, stopping the gateway had not been enough to get rid of the entity. This latest bit of information would seem to point to the entity disappearing because it is not in the gateway’s database anymore. But if we deleted its database, it wouldn’t even know how to compute a delta and publish a “remove” message, or am I missing something?
I’m using Hassio and I have my Xiaomi aqara sensors paired and I can see mqtt messages as the temperature changes. However I can’t seem to get these sensors displaying in Home Assistant, I’ve tried so many different configurations and I can’t see anything (even in dev-state). Could you share your mqtt sensor config, or are you using some other method for reporting (graphing) temperature?
I have the same problem, can anyone help or suggest me what to do?
A bit of context, I am using the ConBee (deCONZ) zigbee usb dongle in a RPI 3B+ and hassio. I wanted to setup zigbee2mqtt addon to avoid using proprietary gateways.
I have the following problem when starting the add-on:
zigbee2mqtt:error 2019-1-1 18:14:03 Error while starting zigbee-shepherd!
zigbee2mqtt:error 2019-1-1 18:14:03 Press the reset button on the stick (the one closest to the USB) and start again
zigbee2mqtt:error 2019-1-1 18:14:03 Failed to start
{“message”:“request timeout”,“stack”:“Error: request timeout\n at CcZnp. (/zigbee2mqtt-1.0.1/node_modules/cc-znp/lib/ccznp.js:255:22)\n at Object.onceWrapper (events.js:315:30)\n at emitOne (events.js:116:13)\n at CcZnp.emit (events.js:211:7)\n at Timeout. (/zigbee2mqtt-1.0.1/node_modules/cc-znp/lib/ccznp.js:234:18)\n at ontimeout (timers.js:498:11)\n at tryOnTimeout (timers.js:323:5)\n at Timer.listOnTimeout (timers.js:290:5)”}
You are right. I start reading from top the thread and i saw someone had a similar error but apparently due to something else.
Pity that it is not possible to use the deCONZ dongle. Therefore, the only way would be to buy the CC253X chip? Is it enough to buy the chip or do I need to buy any supporting hardware to use it?
Thank you a lot, I am very new in hassio, but I am eager to automate my appliances.
My next challenge will be the roller-shades with Somfy motors where I have only the connexxon bridge and not the Tahoma gateway. I hope to find some support on that
I’m on the fence of buying a Xiaomi Gateway vs putting together a Zigbee2Mqtt and wondered if it’s possible to use a Xiaomi gateway to add non Xiaomi things to e.g. TRADFI bulbs? or is that the advantage of Zigbee2MQTT that it’s vendor agnostic?
You rarely can use another vendor’s gateway (philips hue seems to be compatible with ikea bulbs though). That’s exactly what this project addresses. You can’t use Xiaomi’s gateway with, say, Osram led stripes.
