up to now I have always used a CC2531 coordinator with zStack12 (revision ': 20190608) I have several Hue / ikea lights and xiami and mija sensors everything works discreetly, only occasionally some sensor loses the connection and I have to reset it. I wanted to try a new key with cc2530, programmed as coordinator and with the same firmware, I only change the configuration inherent to the new hardware and leaving unchanged network key and channel, but unfortunately the various peripherals do not connect to the new coordinator, I had to restore the old one cc2531. Is there a way to reset all peripherals from zigbee2mqtt before using new hardware? I read that the Hue are problematic to reset. Or if you have any advice on how to use the new cc2530 usb without having to reset anything I would be grateful.
this is the old config:
I read on another post that itās not advisable to mix ZLL and ZHA devices on the same mesh, yet there are a lot of posts here that suggest people are doing just that. What is the current recommendation? I struggle with poor signal between my mainly Xiaomi sensors so it would be great to add my 5 hue bulbs to the mesh to improve coverage.
If you are using @danielwelchās Zigbee2mqtt Hassio addon, which is tracking the latest version of @Koenkkās Zigbee2mqtt (today at 1.14.1), experimental ConBee support has been added and is worked on since release 1.12.0. If you want to track progress, follow this GitHub issue on Koenās zigbee-herdsman library.
So I would answer : āyesā to your question. However, I was not able to make it work in my config as it looks like the Hassio addon does not want to see my adapter. I might give it another shot if I have time this week to dig further. In the meantime Iām using the ānativeā ZHA integration.
Edit: I might have found why I was not able to make it work, see this GitHub issue.
Thanks for the info. I am using the HassIO addon. I was asking because I was not able to start z2m too using the conbee2 stick. Using a CC2531 works with no problem.
I am guessing same issue with the github issue you linked to.
The PTVO switch does not respond to commands from Hassio.
I get the following error
zigbee2mqtt:error 2020-07-19 09:28:02: Failed to call 'EntityPublish' 'onMQTTMessage' (AssertionError [ERR_ASSERTION]: Endpoint name 'bottom_left' is given but device has no such endpoint
at Zigbee.resolveEntity (/zigbee2mqtt-1.14.1/lib/zigbee.js:202:25)
at EntityPublish.onMQTTMessage (/zigbee2mqtt-1.14.1/lib/extension/publish.js:59:44)
at Controller.callExtensionMethod (/zigbee2mqtt-1.14.1/lib/controller.js:360:44)
at Controller.onMQTTMessage (/zigbee2mqtt-1.14.1/lib/controller.js:254:14)
at MQTT.emit (events.js:315:20)
at MQTT.onMessage (/zigbee2mqtt-1.14.1/lib/mqtt.js:95:14)
at MqttClient.emit (events.js:315:20)
at MqttClient._handlePublish (/zigbee2mqtt-1.14.1/node_modules/mqtt/lib/client.js:1269:12)
at MqttClient._handlePacket (/zigbee2mqtt-1.14.1/node_modules/mqtt/lib/client.js:409:12)
at work (/zigbee2mqtt-1.14.1/node_modules/mqtt/lib/client.js:320:12))
Looking at the MQTT explorer I see no abnormalities
By the way my other IKEA Zigbee devices all function normally
What I have tried so far:
-switch to zigbee2mqtt edge
-remove/reinstall device
-various restarts
I have zigbee2mqtt, HA and mosquitto all running on one computer now but the location isnāt great for the ZigBee network, so I am considering moving zigbee2mqtt to another computer located closer to the battery-powered sensors, or alternatively adding another router.
Two general questions;
Can I migrate zigbee2mqtt to another computer just by moving the CC2531 and copying the config, state and database files over?
Is a RPi 2 good enough to run zigbee2mqtt? The broker will not move. Will I notice the extra latency when controlling from a zigbee button to HA?
I have two automations to: a) change zigbee network joining state on zigbee2mqtt. and; b) change log level. They rely on input_boolean and a input_select helper.
The automations are:
- id: '1595186210127'
alias: ZigBee -- permitir ingresso na rede
description: ''
- entity_id: input_boolean.permitir_o_ingresso_na_rede_zigbee # permit join helper on UI
platform: state
to: 'on'
condition: []
- data: {}
entity_id: timer.zigbee_permit_join
service: timer.start
- data:
payload: 'true'
topic: zigbee2mqtt/bridge/config/permit_join
service: mqtt.publish
- id: '1595188993632'
alias: ZigBee -- mudar o nĆvel de log no gateway
description: ''
- entity_id: input_select.nivel_de_log_do_gateway_zigbee2mqtt # log level helper on UI
platform: state
condition: []
- data:
payload_template: '{{ states(''input_select.nivel_de_log_do_gateway_zigbee2mqtt'')
topic: zigbee2mqtt/bridge/config/log_level
If I permit new devices to join using other way (e.g. Zigbee2MqttAssistant), the UI get out of sync. The same happens on changing log level either on zigbee2mqtt configuration or on Zigbee2MqttAssistant.
Iād like to sync HA internal state (and the UI) to the zigbee2mqtt real state. First, I thought about writing an automation that listen to zigbee2mqtt/bridge/config topic and change the UI accordingly, BUTā¦ changing the UI will trigger the automation, publishing the configuration on the zigbee2mqtt/bridge/config/permit_join or zigbee2mqtt/bridge/config/log_level, that will make zigbee2mqtt publish the new state on zigbee2mqtt/bridge/config, that will trigger the automation to update the UI, that will change the state and a loop is bornā¦
Any idea on how can I accomplish this synchronization?
entities:
- entity: sensor.coordenador_zigbee
- entity: sensor.versao_do_zigbee2mqtt
- entity: sensor.versao_do_coordenador_zigbee
- type: divider
- entity: input_boolean.permitir_o_ingresso_na_rede_zigbee
- entity: timer.zigbee_permit_join
- type: divider
- entity: input_select.nivel_de_log_do_gateway_zigbee2mqtt
- type: divider
- entity: sensor.nivel_de_log_do_coordenador_zigbee # this is the latest value received on zigbee2mqtt/bridge/config
- entity: sensor.permissao_de_ingresso_na_rede_zigbee # this is the latest value received on zigbee2mqtt/bridge/config
show_header_toggle: false
title: Controle do coordenador ZigBee
type: entities
The sensors are defined as
- platform: mqtt
name: NĆvel de log do coordenador ZigBee
state_topic: "zigbee2mqtt/bridge/config"
value_template: "{{ value_json.log_level }}"
- platform: mqtt
name: PermissĆ£o de ingresso na rede ZigBee
value_template: "{{ value_json.permit_join }}"
icon: mdi:location-enter
If I change the loglevel using zigbee2mqttassistant from warn to error, I have the following render for the lovelace card >> https://imgur.com/a/yaHQOt0
If you publish true on the zigbee2mqtt/bridge/config/permit_join topic from other place (e.g. mosquito_pub), the input select changes to the new value, the timer starts, and there is no new message to change join status on the MQTT bus?
As I told first, this is my first idea, but I was afraid of extra messages and a loop on state change. If you tested and there is no loop, Iāll test here
If you publish from outside HA, the input select does not change and the timer does not start. These are HA automations, and unaware of outside manipulations. The only thing that will change is your sensor.
I can understand that the events are decoupled from each other, and that is the problem.
I would like an external event (the sensor state change caused by the message received by MQTT) to change the state of an input_boolean or an input_select in the Home Assistant UI, but this change in the interface (i. e., HA internal state) should not trigger the automation that is associated with changing it. The automation should only be triggered when the input_boolean is manually changed by the user, or by some internal event, but not by an external event.
For your permit_join, to have the UI synchronized with the real state, donāt use an input boolean but a template switch.
For your your input select, I have to think about that.
