I updated the blueprint to work with IKEA E1524 (looks the same).
The action of E1524 is not updated into the âactionâ attribute. Instead we use the primary state of the entity.
Is thisthread still active? I installed blueprint and managed to work it only for on/off function.
I am using it to control 3 same Tadfri light bulbs at the same (in one ceiling light) time but dimming is not working properly. Every bulb reacts differently. When dimming down f.e. one press of dimm button lower brightness in bulb one for 50 units, bulb 75 units, bulb 3 100 units, after 3 presses remote stops working because bulb 3 is max dimmed. Than I go back (up), its the same and after while bulbs brigtness is complete mess, every bulb has another brightness. I have to restart them.
Any solution to this?
So this actually works if I have a sky connect? Iâve tried to install the zigbee2mqtt add on but can only add the girhub repo, then I still canât find the add on for some reason
Hey, had the same issue too. Manually reloading the page did the trick for me. You need Mosquitto (MQTT broker) as well. There are tons of guides on YouTube or in written form. Just make sure to use a somewhat recent one.
The âminâ and âmaxâ values are specific to the bulbs I am using - I got them from maually maxing out and minimizing the color temp slider for the bulbs and watching the dev>template valuesâŚ
