This is a fork of @frenck’s work found here. The functionality should be exactly the same, except we’re just using the action
attribute of a sensor created by Zigbee2MQTT.
In my example, my IKEA 5 button remote is called Office Remote. When you load the blueprint, select the sensor related to your remote. Mine’s called sensor.office_remote_action
A quote from the original:
It was specially created for use with (any) light(s). As the basic light controls are already mapped in this blueprint.
The middle “on” button, toggle the lights on/off to the last set brightness (unless the force brightness is toggled on in the blueprint). Dim up/down buttons will change the brightness smoothly and can be pressed and hold until the brightness is satisfactory.
The “left” and “right” buttons can be assigned to a short and long button press action. This allows you to assign, e.g., a scene or anything else.
Blueprint
Import the blueprint by using the forum topic URL! Or use the button.
blueprint:
name: Z2M - IKEA five button remote for lights
description: |
Control lights with an IKEA five button remote (the round ones).
The middle "on" button, toggle the lights on/off to the last set brightness
The "left" and "right" buttons can be assigned to a short and long button
This is a fork of @Frenck's blueprint for ZHA found here https://community.home-assistant.io/t/zha-ikea-five-button-remote-for-lights/253804
domain: automation
input:
remote:
description: IKEA remote to use
selector:
entity:
domain: sensor
light:
description: The light(s) to control
selector:
entity:
domain: light
force_brightness:
name: Force turn on brightness
description: >
Force the brightness to the set level below, when the "on" button on
the remote is pushed and lights turn on.
default: false
selector:
boolean:
brightness:
description: Brightness of the light(s) when turning on
default: 50
selector:
number:
min: 0
max: 100
mode: slider
step: 1
unit_of_measurement: "%"
button_left_short:
name: Left button - short press
description: Action to run on short left button press
default: []
selector:
button_left_long:
name: Left button - long press
description: Action to run on long left button press
default: []
selector:
button_right_short:
name: Right button - short press
description: Action to run on short right button press
default: []
selector:
button_right_long:
name: Right button - long press
description: Action to run on long right button press
default: []
selector:
mode: restart
max_exceeded: silent
variables:
force_brightness: !input force_brightness
- platform: state
entity_id: !input remote
attribute: action
- variables:
command: "{{ trigger.to_state.state }}"
- choose:
- conditions:
- "{{ command == 'toggle' }}"
sequence:
- choose:
- conditions: "{{ force_brightness }}"
sequence:
- service: light.toggle
target: !input light
transition: 1
brightness_pct: !input brightness
default:
transition: 1
- conditions:
- "{{ command == 'brightness_up_click' }}"
sequence:
- service: light.turn_on
brightness_step_pct: 10
transition: 1
- conditions:
- "{{ command == 'brightness_up_hold' }}"
sequence:
- repeat:
until:
- condition: state
state: brightness_up_release
attribute: action
sequence:
transition: 1
- delay: '1'
- conditions:
- "{{ command == 'brightness_down_click' }}"
sequence:
brightness_step_pct: -10
transition: 1
- conditions:
- "{{ command == 'brightness_down_hold' }}"
sequence:
- repeat:
until:
- condition: state
state: brightness_down_release
attribute: action
sequence:
transition: 1
- delay: '1'
- conditions:
- "{{ command == 'arrow_left_click' }}"
sequence: !input button_left_short
- conditions:
- "{{ command == 'arrow_left_hold' }}"
sequence: !input button_left_long
- conditions:
- "{{ command == 'arrow_right_click' }}"
sequence: !input button_right_short
- conditions:
- "{{ command == 'arrow_right_hold' }}"
sequence: !input button_right_long
And a screenshot from my example:
