Zigbee2MQTT make me crazy please help
Good morning everyone, I have a problem with Zigbee 2 MQTT that is driving me crazy.
I have been using Home Assistant on a RaspberryPi 3+ For about a year now, I have been running the zigbee network with a Sonoff dongle. During this year it would happen (maximum once a month) that the zigbee devices would stop working, but by rebooting the Raspberry everything would go back to working normally. In the last month these interruptions have become much more frequent until they are several times a day. When I check the status of z2m I see that it has stopped working, if I try to reboot it an error is reported and in the screen it remains “502 bad gateway” but if I reboot HA everything goes back to working normally. However since today even rebooting the raspberry when I check z2m seems to be active, I can see all devices but none are working or reporting data. From the dashboard if I change the status of the devices nothing happens and if I try to load the map it stays indefinitely without showing it.
What could it be? I am literally going crazy having to manage all the automations and lights in the house. Some lights are controllable only this way so I have whole rooms in the dark.
Provide logs.
This is from z2m
Zigbee2MQTT:info  2024-02-29 11:06:31: MQTT publish: topic 'zigbee2mqtt/Porta finestra cucina', payload '{"battery":90,"contact":true,"device_temperature":29,"linkquality":152,"power_outage_count":91,"voltage":2985}'
Zigbee2MQTT:info  2024-02-29 11:06:31: MQTT publish: topic 'zigbee2mqtt/Porta Ingresso', payload '{"battery":100,"contact":true,"device_temperature":19,"linkquality":216,"power_outage_count":929,"voltage":3025}'
Zigbee2MQTT:info  2024-02-29 11:06:31: MQTT publish: topic 'zigbee2mqtt/Cubo', payload '{"action":null,"action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"battery":100,"current":0,"device_temperature":22,"linkquality":236,"power":20494,"power_outage_count":298,"side":3,"voltage":3065}'
Zigbee2MQTT:info  2024-02-29 11:06:31: MQTT publish: topic 'zigbee2mqtt/zigbee plant sensor', payload '{"battery":60,"battery_state":"medium","linkquality":172,"soil_moisture":0,"temperature":24,"temperature_unit":null}'
Zigbee2MQTT:info  2024-02-29 11:06:34: MQTT publish: topic 'zigbee2mqtt/knob', payload '{"action":null,"action_rate":null,"action_step_size":null,"action_transition_time":null,"battery":100,"linkquality":176,"operation_mode":"command","voltage":3000}'
Zigbee2MQTT:info  2024-02-29 11:06:39: MQTT publish: topic 'zigbee2mqtt/Presa smart', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":216,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":77,"latest_version":192,"state":"available"},"update_available":null,"voltage":203}'
Zigbee2MQTT:info  2024-02-29 11:06:42: MQTT publish: topic 'zigbee2mqtt/temp hum esterno', payload '{"battery":77,"humidity":78.45,"linkquality":148,"power_outage_count":925,"pressure":973.2,"temperature":22.28,"voltage":2965}'
Zigbee2MQTT:info  2024-02-29 11:06:42: MQTT publish: topic 'zigbee2mqtt/Cantinetta12', payload '{"battery":100,"humidity":80.17,"linkquality":232,"power_outage_count":1504,"pressure":975.8,"temperature":14.4,"voltage":3075}'
Zigbee2MQTT:info  2024-02-29 11:06:43: MQTT publish: topic 'zigbee2mqtt/Cantientta8', payload '{"battery":100,"humidity":87.19,"linkquality":152,"power_outage_count":33957,"pressure":975.9,"temperature":14.76,"voltage":3095}'
Zigbee2MQTT:info  2024-02-29 11:06:43: MQTT publish: topic 'zigbee2mqtt/0xa4c138badd5aef36', payload '{"action":null,"action_rate":null,"action_step_size":null,"action_transition_time":null,"battery":83,"linkquality":248,"operation_mode":"event","voltage":2900}'
Zigbee2MQTT:info  2024-02-29 11:06:43: MQTT publish: topic 'zigbee2mqtt/door cantinetta 12', payload '{"battery":null,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":null}'
Zigbee2MQTT:info  2024-02-29 11:06:43: MQTT publish: topic 'zigbee2mqtt/PIR salotto', payload '{"battery":100,"device_temperature":26,"illuminance":3,"illuminance_lux":3,"linkquality":236,"occupancy":false,"power_outage_count":45,"voltage":3015}'
Zigbee2MQTT:info  2024-02-29 11:06:43: MQTT publish: topic 'zigbee2mqtt/Finestra camera', payload '{"battery":90,"contact":true,"device_temperature":27,"linkquality":140,"power_outage_count":925,"voltage":2985}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Lavatrice', payload '{"child_lock":"UNLOCK","current":0.04,"energy":112.92,"indicator_mode":"off/on","linkquality":152,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":77,"latest_version":192,"state":"available"},"update_available":null,"voltage":238}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Lavastoviglie', payload '{"child_lock":"UNLOCK","current":0,"energy":200.15,"indicator_mode":"off/on","linkquality":112,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":77,"latest_version":192,"state":"available"},"update_available":null,"voltage":237}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Pir Camera da Letto', payload '{"battery":100,"detection_interval":30,"device_temperature":24,"illuminance":0,"linkquality":152,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":3002}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Telecomando Hue Camera da Letto', payload '{"action":null,"action_duration":null,"battery":100,"linkquality":140,"update":{"installed_version":1107324829,"latest_version":1107324829,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Hue white letto', payload '{"brightness":231,"linkquality":144,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16784922,"latest_version":16785162,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Bottone cabina armadio', payload '{"action":null,"battery":100,"device_temperature":27,"linkquality":104,"power_outage_count":0,"voltage":3005}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Pir cabin armadio', payload '{"battery":56,"detection_interval":30,"device_temperature":23,"illuminance":0,"linkquality":148,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":2934}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Hue armadio', payload '{"brightness":254,"linkquality":144,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16784922,"latest_version":16785162,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/hue ambient 1 letto', payload '{"brightness":231,"color_mode":"color_temp","color_temp":318,"linkquality":148,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16786688,"latest_version":16786688,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Hue ambient 2 letto', payload '{"brightness":231,"color_mode":"color_temp","color_temp":318,"linkquality":140,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16786688,"latest_version":16786688,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/TempHum Salotto', payload '{"battery":100,"humidity":63.86,"linkquality":228,"power_outage_count":16,"pressure":980.3,"temperature":22.19,"voltage":3015}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/0xdc8e95fffec394b4', payload '{"action":null,"battery":100,"linkquality":255,"update":{"installed_version":570492465,"latest_version":604241926,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Bottone hue bagno', payload '{"action":null,"battery":100,"linkquality":144,"update":{"installed_version":33566472,"latest_version":33566472,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Hue specchio', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"linkquality":132,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16784922,"latest_version":16785162,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Hue bagno', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"linkquality":124,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16785162,"latest_version":16785162,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Pir bagno', payload '{"battery":100,"detection_interval":30,"device_temperature":24,"illuminance":31,"linkquality":124,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":3002}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Hue Ensis UP', payload '{"brightness":177,"color":{"x":0.4369,"y":0.4041},"color_mode":"color_temp","color_temp":333,"linkquality":192,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16785154,"latest_version":16785412,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Hue Ensis DOWN', payload '{"brightness":177,"color":{"x":0.4369,"y":0.4041},"color_mode":"color_temp","color_temp":333,"linkquality":236,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16785154,"latest_version":16785412,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Telecomando Hue Salotto', payload '{"action":null,"action_duration":null,"battery":100,"linkquality":124,"update":{"installed_version":1107324829,"latest_version":1107324829,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/PIR cucina', payload '{"battery":100,"detection_interval":30,"device_temperature":24,"illuminance":0,"linkquality":144,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":3026}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Hue cucina', payload '{"brightness":254,"linkquality":124,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16784922,"latest_version":16785162,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Bottone cucina', payload '{"action":null,"battery":100,"device_temperature":25,"linkquality":160,"power_outage_count":18,"voltage":3025}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Sensore perdite ', payload '{"battery":100,"battery_low":false,"device_temperature":29,"linkquality":160,"power_outage_count":8,"tamper":false,"voltage":3025,"water_leak":false}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Finestra scrivania', payload '{"battery":100,"contact":true,"device_temperature":28,"linkquality":148,"power_outage_count":10,"voltage":3005}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Finestra ingresso', payload '{"battery":90,"contact":true,"device_temperature":29,"linkquality":128,"power_outage_count":22,"voltage":2985}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Porta finestra salotto', payload '{"battery":100,"contact":true,"device_temperature":21,"linkquality":196,"power_outage_count":6076,"voltage":3045}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Finestra colonna', payload '{"battery":100,"contact":true,"device_temperature":23,"linkquality":132,"power_outage_count":10,"voltage":3025}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Finestra bagno ', payload '{"battery":100,"contact":true,"device_temperature":27,"linkquality":128,"power_outage_count":14,"voltage":3005}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Porta finestra cucina', payload '{"battery":90,"contact":true,"device_temperature":29,"linkquality":152,"power_outage_count":91,"voltage":2985}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Porta Ingresso', payload '{"battery":100,"contact":true,"device_temperature":19,"linkquality":216,"power_outage_count":929,"voltage":3025}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Cubo', payload '{"action":null,"action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"battery":100,"current":0,"device_temperature":22,"linkquality":236,"power":20494,"power_outage_count":298,"side":3,"voltage":3065}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/zigbee plant sensor', payload '{"battery":60,"battery_state":"medium","linkquality":172,"soil_moisture":0,"temperature":24,"temperature_unit":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/knob', payload '{"action":null,"action_rate":null,"action_step_size":null,"action_transition_time":null,"battery":100,"linkquality":176,"operation_mode":"command","voltage":3000}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Presa smart', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":216,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":77,"latest_version":192,"state":"available"},"update_available":null,"voltage":203}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/temp hum esterno', payload '{"battery":77,"humidity":78.45,"linkquality":148,"power_outage_count":925,"pressure":973.2,"temperature":22.28,"voltage":2965}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Cantinetta12', payload '{"battery":100,"humidity":80.17,"linkquality":232,"power_outage_count":1504,"pressure":975.8,"temperature":14.4,"voltage":3075}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/Cantientta8', payload '{"battery":100,"humidity":87.19,"linkquality":152,"power_outage_count":33957,"pressure":975.9,"temperature":14.76,"voltage":3095}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/0xa4c138badd5aef36', payload '{"action":null,"action_rate":null,"action_step_size":null,"action_transition_time":null,"battery":83,"linkquality":248,"operation_mode":"event","voltage":2900}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/door cantinetta 12', payload '{"battery":null,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":null}'
Zigbee2MQTT:info  2024-02-29 11:15:12: MQTT publish: topic 'zigbee2mqtt/PIR salotto', payload '{"battery":100,"device_temperature":26,"illuminance":3,"illuminance_lux":3,"linkquality":236,"occupancy":false,"power_outage_count":45,"voltage":3015}'
Zigbee2MQTT:info  2024-02-29 11:15:13: MQTT publish: topic 'zigbee2mqtt/Finestra camera', payload '{"battery":90,"contact":true,"device_temperature":27,"linkquality":140,"power_outage_count":925,"voltage":2985}'
Zigbee2MQTT:info  2024-02-29 11:15:42: Starting network scan (includeRoutes 'false')
Zigbee2MQTT:info  2024-02-29 11:22:20: Removing device '0xa4c138e914ec8606' (block: false, force: true)
Zigbee2MQTT:info  2024-02-29 11:22:20: MQTT publish: topic 'zigbee2mqtt/0xa4c138e914ec8606', payload ''
Zigbee2MQTT:info  2024-02-29 11:22:20: Successfully removed device '0xa4c138e914ec8606' (block: false, force: true)
Zigbee2MQTT:info  2024-02-29 11:22:22: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/remove', payload '{"data":{"block":false,"force":true,"id":"0xa4c138e914ec8606"},"status":"ok","transaction":"jj0dh-1"}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/Lavatrice', payload '{"child_lock":"UNLOCK","current":0.04,"energy":112.92,"indicator_mode":"off/on","linkquality":152,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":77,"latest_version":192,"state":"available"},"update_available":null,"voltage":238}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/Lavastoviglie', payload '{"child_lock":"UNLOCK","current":0,"energy":200.15,"indicator_mode":"off/on","linkquality":112,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":77,"latest_version":192,"state":"available"},"update_available":null,"voltage":237}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/Pir Camera da Letto', payload '{"battery":100,"detection_interval":30,"device_temperature":24,"illuminance":0,"linkquality":152,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":3002}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/Telecomando Hue Camera da Letto', payload '{"action":null,"action_duration":null,"battery":100,"linkquality":140,"update":{"installed_version":1107324829,"latest_version":1107324829,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/Hue white letto', payload '{"brightness":231,"linkquality":144,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16784922,"latest_version":16785162,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/Bottone cabina armadio', payload '{"action":null,"battery":100,"device_temperature":27,"linkquality":104,"power_outage_count":0,"voltage":3005}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/Pir cabin armadio', payload '{"battery":56,"detection_interval":30,"device_temperature":23,"illuminance":0,"linkquality":148,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":2934}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/Hue armadio', payload '{"brightness":254,"linkquality":144,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16784922,"latest_version":16785162,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:13: MQTT publish: topic 'zigbee2mqtt/hue ambient 1 letto', payload '{"brightness":231,"color_mode":"color_temp","color_temp":318,"linkquality":148,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16786688,"latest_version":16786688,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Hue ambient 2 letto', payload '{"brightness":231,"color_mode":"color_temp","color_temp":318,"linkquality":140,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16786688,"latest_version":16786688,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/TempHum Salotto', payload '{"battery":100,"humidity":63.86,"linkquality":228,"power_outage_count":16,"pressure":980.3,"temperature":22.19,"voltage":3015}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/0xdc8e95fffec394b4', payload '{"action":null,"battery":100,"linkquality":255,"update":{"installed_version":570492465,"latest_version":604241926,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Bottone hue bagno', payload '{"action":null,"battery":100,"linkquality":144,"update":{"installed_version":33566472,"latest_version":33566472,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Hue specchio', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"linkquality":132,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16784922,"latest_version":16785162,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Hue bagno', payload '{"brightness":254,"color_mode":"color_temp","color_temp":200,"linkquality":124,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16785162,"latest_version":16785162,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Pir bagno', payload '{"battery":100,"detection_interval":30,"device_temperature":24,"illuminance":31,"linkquality":124,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":3002}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Hue Ensis UP', payload '{"brightness":177,"color":{"x":0.4369,"y":0.4041},"color_mode":"color_temp","color_temp":333,"linkquality":192,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16785154,"latest_version":16785412,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Hue Ensis DOWN', payload '{"brightness":177,"color":{"x":0.4369,"y":0.4041},"color_mode":"color_temp","color_temp":333,"linkquality":236,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16785154,"latest_version":16785412,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Telecomando Hue Salotto', payload '{"action":null,"action_duration":null,"battery":100,"linkquality":124,"update":{"installed_version":1107324829,"latest_version":1107324829,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/PIR cucina', payload '{"battery":100,"detection_interval":30,"device_temperature":24,"illuminance":0,"linkquality":144,"motion_sensitivity":"medium","occupancy":false,"power_outage_count":0,"trigger_indicator":false,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":3026}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Hue cucina', payload '{"brightness":254,"linkquality":124,"power_on_behavior":null,"state":"OFF","update":{"installed_version":16784922,"latest_version":16785162,"state":"available"},"update_available":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Bottone cucina', payload '{"action":null,"battery":100,"device_temperature":25,"linkquality":160,"power_outage_count":18,"voltage":3025}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Sensore perdite ', payload '{"battery":100,"battery_low":false,"device_temperature":29,"linkquality":160,"power_outage_count":8,"tamper":false,"voltage":3025,"water_leak":false}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Finestra scrivania', payload '{"battery":100,"contact":true,"device_temperature":28,"linkquality":148,"power_outage_count":10,"voltage":3005}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Finestra ingresso', payload '{"battery":90,"contact":true,"device_temperature":29,"linkquality":128,"power_outage_count":22,"voltage":2985}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Porta finestra salotto', payload '{"battery":100,"contact":true,"device_temperature":21,"linkquality":196,"power_outage_count":6076,"voltage":3045}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Finestra colonna', payload '{"battery":100,"contact":true,"device_temperature":23,"linkquality":132,"power_outage_count":10,"voltage":3025}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Finestra bagno ', payload '{"battery":100,"contact":true,"device_temperature":27,"linkquality":128,"power_outage_count":14,"voltage":3005}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Porta finestra cucina', payload '{"battery":90,"contact":true,"device_temperature":29,"linkquality":152,"power_outage_count":91,"voltage":2985}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Porta Ingresso', payload '{"battery":100,"contact":true,"device_temperature":19,"linkquality":216,"power_outage_count":929,"voltage":3025}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Cubo', payload '{"action":null,"action_angle":null,"action_from_side":null,"action_side":null,"action_to_side":null,"battery":100,"current":0,"device_temperature":22,"linkquality":236,"power":20494,"power_outage_count":298,"side":3,"voltage":3065}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/zigbee plant sensor', payload '{"battery":60,"battery_state":"medium","linkquality":172,"soil_moisture":0,"temperature":24,"temperature_unit":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/knob', payload '{"action":null,"action_rate":null,"action_step_size":null,"action_transition_time":null,"battery":100,"linkquality":176,"operation_mode":"command","voltage":3000}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Presa smart', payload '{"child_lock":"UNLOCK","current":0,"energy":0.98,"indicator_mode":"off/on","linkquality":216,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":77,"latest_version":192,"state":"available"},"update_available":null,"voltage":203}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/temp hum esterno', payload '{"battery":77,"humidity":78.45,"linkquality":148,"power_outage_count":925,"pressure":973.2,"temperature":22.28,"voltage":2965}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Cantinetta12', payload '{"battery":100,"humidity":80.17,"linkquality":232,"power_outage_count":1504,"pressure":975.8,"temperature":14.4,"voltage":3075}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Cantientta8', payload '{"battery":100,"humidity":87.19,"linkquality":152,"power_outage_count":33957,"pressure":975.9,"temperature":14.76,"voltage":3095}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/0xa4c138badd5aef36', payload '{"action":null,"action_rate":null,"action_step_size":null,"action_transition_time":null,"battery":83,"linkquality":248,"operation_mode":"event","voltage":2900}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/door cantinetta 12', payload '{"battery":null,"battery_low":false,"contact":true,"linkquality":255,"tamper":false,"voltage":null}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/PIR salotto', payload '{"battery":100,"device_temperature":26,"illuminance":3,"illuminance_lux":3,"linkquality":236,"occupancy":false,"power_outage_count":45,"voltage":3015}'
Zigbee2MQTT:info  2024-02-29 11:26:14: MQTT publish: topic 'zigbee2mqtt/Finestra camera', payload '{"battery":90,"contact":true,"device_temperature":27,"linkquality":140,"power_outage_count":925,"voltage":2985}'
This is from supervisor:
24-02-29 11:00:27 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:00:29 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping homeassistant application
24-02-29 11:00:30 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
24-02-29 11:01:07 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning homeassistant application
24-02-29 11:01:08 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
24-02-29 11:01:09 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version 2024.2.5
24-02-29 11:01:09 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
24-02-29 11:01:31 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
24-02-29 11:01:46 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-29 11:01:49 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-29 11:01:50 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:01:50 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:01:50 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:03:46 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:03:46 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:03:46 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:04:53 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:04:53 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:04:53 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:05:02 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:05:02 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:05:02 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:05:25 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:05:25 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:05:25 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:05:33 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
24-02-29 11:05:33 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
24-02-29 11:05:33 INFO (MainThread) [supervisor.homeassistant.core] Successfully started Home Assistant 2024.2.5
24-02-29 11:05:35 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.2.1']
24-02-29 11:06:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:06:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:06:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:07:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:07:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:07:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:08:23 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-02-29 11:08:40 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:08:40 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:08:40 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:09:20 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.7.1']
24-02-29 11:09:51 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:09:51 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:09:51 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:11:51 INFO (SyncWorker_1) [supervisor.docker.manager] Restarting homeassistant
24-02-29 11:11:55 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
24-02-29 11:12:33 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
24-02-29 11:12:54 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
24-02-29 11:13:07 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-29 11:13:09 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-29 11:13:10 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:13:10 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:13:10 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:14:38 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
24-02-29 11:14:38 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
24-02-29 11:15:37 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:15:37 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:15:37 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:16:49 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:16:49 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:16:49 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:18:15 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:18:15 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:18:15 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:22:03 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:22:03 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:22:03 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:22:24 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:22:24 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:22:24 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:22:41 INFO (SyncWorker_6) [supervisor.docker.manager] Restarting homeassistant
24-02-29 11:22:46 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
24-02-29 11:23:20 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-29 11:23:24 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-29 11:23:24 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-29 11:23:25 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-29 11:23:25 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-29 11:23:30 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
24-02-29 11:23:51 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
24-02-29 11:24:05 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-29 11:24:09 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-29 11:24:10 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:24:10 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:24:10 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:25:37 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
24-02-29 11:25:37 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
24-02-29 11:25:50 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:25:50 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:25:50 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:26:11 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:26:11 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:26:11 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:26:45 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:26:45 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:26:45 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:29:13 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:29:13 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:29:13 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:34:13 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:34:13 WARNING (MainThread) [supervisor.addons.options] Unknown option 'version' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-29 11:34:13 WARNING (MainThread) [supervisor.addons.options] Unknown option 'include_device_information' for Zigbee2MQTT (45df7312_zigbee2mqtt)
This is from mosquitto broker
2024-02-29 10:11:03: New connection from 172.30.32.2:35880 on port 1883.
2024-02-29 10:11:03: Client <unknown> closed its connection.
2024-02-29 10:13:03: New connection from 172.30.32.2:52906 on port 1883.
2024-02-29 10:13:03: Client <unknown> closed its connection.
2024-02-29 10:15:03: New connection from 172.30.32.2:41482 on port 1883.
2024-02-29 10:15:03: Client <unknown> closed its connection.
2024-02-29 10:17:03: New connection from 172.30.32.2:44246 on port 1883.
2024-02-29 10:17:03: Client <unknown> closed its connection.
2024-02-29 10:19:03: New connection from 172.30.32.2:35740 on port 1883.
2024-02-29 10:19:03: Client <unknown> closed its connection.
2024-02-29 10:21:03: New connection from 172.30.32.2:35760 on port 1883.
2024-02-29 10:21:03: Client <unknown> closed its connection.
2024-02-29 10:23:03: New connection from 172.30.32.2:32940 on port 1883.
2024-02-29 10:23:03: Client <unknown> closed its connection.
2024-02-29 10:25:03: New connection from 172.30.32.2:45094 on port 1883.
2024-02-29 10:25:03: Client <unknown> closed its connection.
2024-02-29 10:26:33: Saving in-memory database to /data//mosquitto.db.
2024-02-29 10:27:03: New connection from 172.30.32.2:51552 on port 1883.
2024-02-29 10:27:03: Client <unknown> closed its connection.
2024-02-29 10:29:03: New connection from 172.30.32.2:53908 on port 1883.
2024-02-29 10:29:03: Client <unknown> closed its connection.
2024-02-29 10:31:03: New connection from 172.30.32.2:47922 on port 1883.
2024-02-29 10:31:03: Client <unknown> closed its connection.
2024-02-29 10:33:03: New connection from 172.30.32.2:58158 on port 1883.
2024-02-29 10:33:03: Client <unknown> closed its connection.
2024-02-29 10:35:03: New connection from 172.30.32.2:40782 on port 1883.
2024-02-29 10:35:03: Client <unknown> closed its connection.
2024-02-29 10:37:03: New connection from 172.30.32.2:51818 on port 1883.
2024-02-29 10:37:03: Client <unknown> closed its connection.
2024-02-29 10:39:03: New connection from 172.30.32.2:43090 on port 1883.
2024-02-29 10:39:03: Client <unknown> closed its connection.
2024-02-29 10:41:03: New connection from 172.30.32.2:36738 on port 1883.
2024-02-29 10:41:03: Client <unknown> closed its connection.
2024-02-29 10:43:03: New connection from 172.30.32.2:56920 on port 1883.
2024-02-29 10:43:03: Client <unknown> closed its connection.
2024-02-29 10:45:03: New connection from 172.30.32.2:58900 on port 1883.
2024-02-29 10:45:03: Client <unknown> closed its connection.
2024-02-29 10:47:03: New connection from 172.30.32.2:46496 on port 1883.
2024-02-29 10:47:03: Client <unknown> closed its connection.
2024-02-29 10:49:03: New connection from 172.30.32.2:59574 on port 1883.
2024-02-29 10:49:03: Client <unknown> closed its connection.
2024-02-29 10:51:03: New connection from 172.30.32.2:46288 on port 1883.
2024-02-29 10:51:03: Client <unknown> closed its connection.
2024-02-29 10:53:03: New connection from 172.30.32.2:48446 on port 1883.
2024-02-29 10:53:03: Client <unknown> closed its connection.
2024-02-29 10:55:03: New connection from 172.30.32.2:43838 on port 1883.
2024-02-29 10:55:03: Client <unknown> closed its connection.
2024-02-29 10:56:34: Saving in-memory database to /data//mosquitto.db.
2024-02-29 10:57:03: New connection from 172.30.32.2:48076 on port 1883.
2024-02-29 10:57:03: Client <unknown> closed its connection.
2024-02-29 10:59:03: New connection from 172.30.32.2:60726 on port 1883.
2024-02-29 10:59:03: Client <unknown> closed its connection.
2024-02-29 11:00:59: Client 2olLYEdlzhPsiS9ao2m681 closed its connection.
2024-02-29 11:01:03: New connection from 172.30.32.2:33504 on port 1883.
2024-02-29 11:01:03: Client <unknown> closed its connection.
2024-02-29 11:02:17: New connection from 172.30.32.1:41667 on port 1883.
2024-02-29 11:02:17: New client connected from 172.30.32.1:41667 as 4YDR42OodgWgUgLUSB3uJy (p2, c1, k60, u'homeassistant').
2024-02-29 11:03:03: New connection from 172.30.32.2:53202 on port 1883.
2024-02-29 11:03:03: Client <unknown> closed its connection.
2024-02-29 11:05:03: New connection from 172.30.32.2:56182 on port 1883.
2024-02-29 11:05:03: Client <unknown> closed its connection.
2024-02-29 11:07:03: New connection from 172.30.32.2:56806 on port 1883.
2024-02-29 11:07:03: Client <unknown> closed its connection.
2024-02-29 11:09:03: New connection from 172.30.32.2:53202 on port 1883.
2024-02-29 11:09:08: Client <unknown> closed its connection.
2024-02-29 11:11:03: New connection from 172.30.32.2:57916 on port 1883.
2024-02-29 11:11:03: Client <unknown> closed its connection.
2024-02-29 11:12:24: Client 4YDR42OodgWgUgLUSB3uJy closed its connection.
2024-02-29 11:13:03: New connection from 172.30.32.2:49520 on port 1883.
2024-02-29 11:13:03: Client <unknown> closed its connection.
2024-02-29 11:13:39: New connection from 172.30.32.1:41993 on port 1883.
2024-02-29 11:13:39: New client connected from 172.30.32.1:41993 as 5QTW0CSHwrJDEJPsqDDYnp (p2, c1, k60, u'homeassistant').
2024-02-29 11:15:03: New connection from 172.30.32.2:60012 on port 1883.
2024-02-29 11:15:03: Client <unknown> closed its connection.
2024-02-29 11:17:03: New connection from 172.30.32.2:52174 on port 1883.
2024-02-29 11:17:03: Client <unknown> closed its connection.
2024-02-29 11:19:03: New connection from 172.30.32.2:37896 on port 1883.
2024-02-29 11:19:03: Client <unknown> closed its connection.
2024-02-29 11:21:03: New connection from 172.30.32.2:37600 on port 1883.
2024-02-29 11:21:03: Client <unknown> closed its connection.
2024-02-29 11:23:03: New connection from 172.30.32.2:59834 on port 1883.
2024-02-29 11:23:03: Client <unknown> closed its connection.
2024-02-29 11:23:22: Client 5QTW0CSHwrJDEJPsqDDYnp closed its connection.
2024-02-29 11:24:38: New connection from 172.30.32.1:45175 on port 1883.
2024-02-29 11:24:38: New client connected from 172.30.32.1:45175 as 6oUBfVB78CtW2GWvA5ilLR (p2, c1, k60, u'homeassistant').
2024-02-29 11:25:03: New connection from 172.30.32.2:37972 on port 1883.
2024-02-29 11:25:03: Client <unknown> closed its connection.
2024-02-29 11:26:35: Saving in-memory database to /data//mosquitto.db.
2024-02-29 11:27:03: New connection from 172.30.32.2:39370 on port 1883.
2024-02-29 11:27:03: Client <unknown> closed its connection.
2024-02-29 11:29:03: New connection from 172.30.32.2:34716 on port 1883.
2024-02-29 11:29:03: Client <unknown> closed its connection.
2024-02-29 11:31:03: New connection from 172.30.32.2:53116 on port 1883.
2024-02-29 11:31:03: Client <unknown> closed its connection.
2024-02-29 11:33:03: New connection from 172.30.32.2:41328 on port 1883.
2024-02-29 11:33:03: Client <unknown> closed its connection.
2024-02-29 11:35:03: New connection from 172.30.32.2:40366 on port 1883.
2024-02-29 11:35:03: Client <unknown> closed its connection.
2024-02-29 11:37:03: New connection from 172.30.32.2:33068 on port 1883.
2024-02-29 11:37:03: Client <unknown> closed its connection.
Can you show your config too?
Yes sure, which one?
Zigbee2MQTT. Are the logs from when you had trouble? They seem very recent and doesn’t look like there’s any errors in both the Z2M and the MQTT logs.
    "commit": "unknown",
    "config": {
        "advanced": {
            "adapter_concurrent": null,
            "adapter_delay": null,
            "availability_blacklist": [],
            "availability_blocklist": [],
            "availability_passlist": [],
            "availability_whitelist": [],
            "cache_state": true,
            "cache_state_persistent": true,
            "cache_state_send_on_startup": true,
            "channel": 11,
            "elapsed": false,
            "ext_pan_id": [
                221,
                221,
                221,
                221,
                221,
                221,
                221,
                221
            "homeassistant_legacy_entity_attributes": false,
            "last_seen": "disable",
            "legacy_api": false,
            "legacy_availability_payload": false,
            "log_directory": "/config/zigbee2mqtt/log/%TIMESTAMP%",
            "log_file": "log.txt",
            "log_level": "info",
            "log_output": [
                "console",
                "file"
            "log_rotation": true,
            "log_symlink_current": false,
            "log_syslog": {},
            "output": "json",
            "pan_id": 6754,
            "report": false,
            "soft_reset_timeout": 0,
            "timestamp_format": "YYYY-MM-DD HH:mm:ss"
        "blocklist": [],
        "device_options": {
            "legacy": false
        "devices": {
            "0x00158d0002015ebf": {
                "friendly_name": "Bottone cabina armadio"
            "0x00158d0002043ba4": {
                "friendly_name": "Bottone cucina"
            "0x00158d00022cc3c5": {
                "friendly_name": "Cantinetta12"
            "0x00158d00026e9935": {
                "friendly_name": "Cubo"
            "0x00158d0002789b07": {
                "friendly_name": "Cantientta8"
            "0x00158d0002b48584": {
                "friendly_name": "PIR salotto"
            "0x00158d00044d2f01": {
                "friendly_name": "temp hum esterno"
            "0x00158d0008d0af03": {
                "friendly_name": "Sensore perdite "
            "0x00158d0008d8c05e": {
                "friendly_name": "Finestra camera"
            "0x00158d0008d9384e": {
                "friendly_name": "Finestra colonna"
            "0x00158d0008d9386c": {
                "friendly_name": "Finestra scrivania"
            "0x00158d0008d938a3": {
                "friendly_name": "Porta Ingresso"
            "0x00158d0008e006a0": {
                "friendly_name": "Finestra bagno "
            "0x00158d0008e01de2": {
                "friendly_name": "Finestra ingresso"
            "0x00158d0008e024a8": {
                "friendly_name": "TempHum Salotto"
            "0x00158d0008e0fa3e": {
                "friendly_name": "Porta finestra salotto"
            "0x00158d0008f1044c": {
                "friendly_name": "Porta finestra cucina"
            "0x0017880103e5565f": {
                "friendly_name": "Telecomando Hue Salotto"
            "0x0017880103e60704": {
                "friendly_name": "Telecomando Hue Camera da Letto"
            "0x001788010615d298": {
                "friendly_name": "hue ambient 1 letto"
            "0x001788010615d2a9": {
                "friendly_name": "Hue ambient 2 letto"
            "0x001788010896c084": {
                "friendly_name": "Bottone hue bagno"
            "0x001788010ba4d647": {
                "friendly_name": "Hue bagno"
            "0x001788010ba4e7d6": {
                "friendly_name": "Hue specchio"
            "0x001788010bd56642": {
                "friendly_name": "Hue armadio"
            "0x001788010c349e7f": {
                "friendly_name": "Hue white letto"
            "0x001788010d1a9ad5": {
                "friendly_name": "Hue Ensis DOWN"
            "0x001788010d1aac33": {
                "friendly_name": "Hue Ensis UP"
            "0x001788010d2cb51d": {
                "friendly_name": "Hue cucina"
            "0x54ef441000774b38": {
                "friendly_name": "Pir bagno"
            "0x54ef441000775c0e": {
                "friendly_name": "PIR cucina"
            "0x54ef441000775cc3": {
                "friendly_name": "Pir cabin armadio"
            "0x54ef4410007993d8": {
                "friendly_name": "Pir Camera da Letto"
            "0x70ac08fffe2646dc": {
                "friendly_name": "knob"
            "0xa4c1381621ddfdf7": {
                "friendly_name": "Lavastoviglie"
            "0xa4c1382c376a0c2e": {
                "friendly_name": "door cantinetta 12"
            "0xa4c1383c043ffe6b": {
                "friendly_name": "zigbee plant sensor"
            "0xa4c13861083f6f3c": {
                "friendly_name": "Presa smart"
            "0xa4c1386642f59f65": {
                "friendly_name": "Lavatrice"
            "0xa4c138badd5aef36": {
                "friendly_name": "0xa4c138badd5aef36"
            "0xa4c138e914ec8606": {
                "friendly_name": "0xa4c138e914ec8606"
            "0xdc8e95fffec394b4": {
                "friendly_name": "0xdc8e95fffec394b4"
        "external_converters": [],
        "frontend": {
            "port": 8099
        "groups": {},
        "homeassistant": {
            "discovery_topic": "homeassistant",
            "legacy_entity_attributes": false,
            "legacy_triggers": true,
            "status_topic": "hass/status"
        "map_options": {
            "graphviz": {
                "colors": {
                    "fill": {
                        "coordinator": "#e04e5d",
                        "enddevice": "#fff8ce",
                        "router": "#4ea3e0"
                    "font": {
                        "coordinator": "#ffffff",
                        "enddevice": "#000000",
                        "router": "#ffffff"
                    "line": {
                        "active": "#009900",
                        "inactive": "#994444"
        "mqtt": {
            "base_topic": "zigbee2mqtt",
            "force_disable_retain": false,
            "include_device_information": false,
            "server": "mqtt://core-mosquitto",
            "user": "mosquitto"
        "ota": {
            "disable_automatic_update_check": false,
            "update_check_interval": 1440
        "passlist": [],
        "permit_join": false,
        "serial": {
            "adapter": "ezsp",
            "disable_led": false,
            "port": "/dev/ttyACM0"
    "config_schema": {
        "definitions": {
            "device": {
                "properties": {
                    "debounce": {
                        "description": "Debounces messages of this device",
                        "title": "Debounce",
                        "type": "number"
                    "debounce_ignore": {
                        "description": "Protects unique payload values of specified payload properties from overriding within debounce time",
                        "examples": [
                            "action"
                        "items": {
                            "type": "string"
                        "title": "Ignore debounce",
                        "type": "array"
                    "disabled": {
                        "description": "Disables the device (excludes device from network scans, availability and group state updates)",
                        "requiresRestart": true,
                        "title": "Disabled",
                        "type": "boolean"
                    "filtered_attributes": {
                        "description": "Filter attributes with regex from published payload.",
                        "examples": [
                            "^temperature$",
                            "^battery$",
                            "^action$"
                        "items": {
                            "type": "string"
                        "title": "Filtered publish attributes",
                        "type": "array"
                    "filtered_cache": {
                        "description": "Filter attributes with regex from being added to the cache, this prevents the attribute from being in the published payload when the value didn't change.",
                        "examples": [
                            "^input_actions$"
                        "items": {
                            "type": "string"
                        "title": "Filtered attributes from cache",
                        "type": "array"
                    "filtered_optimistic": {
                        "description": "Filter attributes with regex from optimistic publish payload when calling /set. (This has no effect if optimistic is set to false).",
                        "examples": [
                            "^color_(mode|temp)$",
                            "color"
                        "items": {
                            "type": "string"
                        "title": "Filtered optimistic attributes",
                        "type": "array"
                    "friendly_name": {
                        "description": "Used in the MQTT topic of a device. By default this is the device ID",
                        "readOnly": true,
                        "title": "Friendly name",
                        "type": "string"
                    "homeassistant": {
                        "properties": {
                            "name": {
                                "description": "Name of the device in Home Assistant",
                                "title": "Home Assistant name",
                                "type": "string"
                        "title": "Home Assistant",
                        "type": [
                            "object",
                            "null"
                    "icon": {
                        "description": "The user-defined device icon for the frontend. It can be a full URL link to an image (e.g. https://SOME.SITE/MODEL123.jpg) (you cannot use a path to a local file) or base64 encoded data URL (e.g. image/svg+xml;base64,PHN2ZyB3aW....R0aD)",
                        "title": "Icon",
                        "type": "string"
                    "optimistic": {
                        "default": true,
                        "description": "Publish optimistic state after set",
                        "title": "Optimistic",
                        "type": "boolean"
                    "qos": {
                        "description": "QoS level for MQTT messages of this device",
                        "title": "QoS",
                        "type": "number"
                    "retain": {
                        "description": "Retain MQTT messages of this device",
                        "title": "Retain",
                        "type": "boolean"
                    "retention": {
                        "description": "Sets the MQTT Message Expiry in seconds, Make sure to set mqtt.version to 5",
                        "title": "Retention",
                        "type": "number"
                "required": [
                    "friendly_name"
                "type": "object"
            "group": {
                "properties": {
                    "devices": {
                        "items": {
                            "type": "string"
                        "type": "array"
                        "items": {
                            "type": "string"
                        "type": "array"
                    "friendly_name": {
                        "type": "string"
                    "off_state": {
                        "default": "auto",
                        "description": "Control when to publish state OFF for a group. 'all_members_off': only publish state OFF when all group members are in state OFF, 'last_member_state': publish state OFF whenever one of its members changes to OFF",
                        "enum": [
                            "all_members_off",
                            "last_member_state"
                        "title": "Group off state",
                        "type": [
                            "string"
                    "optimistic": {
                        "type": "boolean"
                    "qos": {
                        "type": "number"
                    "retain": {
                        "type": "boolean"
                "required": [
                    "friendly_name"
                "type": "object"
        "properties": {
            "advanced": {
                "properties": {
                    "adapter_concurrent": {
                        "description": "Adapter concurrency (e.g. 2 for CC2531 or 16 for CC26X2R1) (default: null, uses recommended value)",
                        "title": "Adapter concurrency",
                        "type": [
                            "number",
                            "null"
                    "adapter_delay": {
                        "description": "Adapter delay",
                        "title": "Adapter delay",
                        "type": [
                            "number",
                            "null"
                    "cache_state": {
                        "default": true,
                        "description": "MQTT message payload will contain all attributes, not only changed ones. Has to be true when integrating via Home Assistant",
                        "title": "Cache state",
                        "type": "boolean"
                    "cache_state_persistent": {
                        "default": true,
                        "description": "Persist cached state, only used when cache_state: true",
                        "title": "Persist cache state",
                        "type": "boolean"
                    "cache_state_send_on_startup": {
                        "default": true,
                        "description": "Send cached state on startup, only used when cache_state: true",
                        "title": "Send cached state on startup",
                        "type": "boolean"
                    "channel": {
                        "default": 11,
                        "description": "Zigbee channel, changing requires repairing all devices! (Note: use a ZLL channel: 11, 15, 20, or 25 to avoid Problems)",
                        "examples": [
                            15,
                            20,
                            25
                        "maximum": 26,
                        "minimum": 11,
                        "title": "ZigBee channel",
                        "type": "number"
                    "elapsed": {
                        "default": false,
                        "description": "Add an elapsed attribute to MQTT messages, contains milliseconds since the previous msg",
                        "title": "Elapsed",
                        "type": "boolean"
                    "ext_pan_id": {
                        "description": "Zigbee extended pan ID, changing requires repairing all devices!",
                        "oneOf": [
                                "title": "Extended pan ID (string)",
                                "type": "string"
                                "items": {
                                    "type": "number"
                                "title": "Extended pan ID (array)",
                                "type": "array"
                        "title": "Ext Pan ID"
                    "last_seen": {
                        "default": "disable",
                        "description": "Add a last_seen attribute to MQTT messages, contains date/time of last Zigbee message",
                        "enum": [
                            "disable",
                            "ISO_8601",
                            "ISO_8601_local",
                            "epoch"
                        "title": "Last seen",
                        "type": "string"
                    "legacy_api": {
                        "default": true,
                        "description": "Disables the legacy api (false = disable)",
                        "title": "Legacy API",
                        "type": "boolean"
                    "legacy_availability_payload": {
                        "default": true,
                        "description": "Payload to be used for device availability and bridge/state topics. true = text, false = JSON",
                        "title": "Legacy availability payload",
                        "type": "boolean"
                    "log_directory": {
                        "description": "Location of log directory",
                        "examples": [
                            "data/log/%TIMESTAMP%"
                        "title": "Log directory",
                        "type": "string"
                    "log_file": {
                        "default": "log.txt",
                        "description": "Log file name, can also contain timestamp",
                        "examples": [
                            "zigbee2mqtt_%TIMESTAMP%.log"
                        "title": "Log file",
                        "type": "string"
                    "log_level": {
                        "default": "info",
                        "description": "Logging level",
                        "enum": [
                            "info",
                            "warn",
                            "error",
                            "debug"
                        "title": "Log level",
                        "type": "string"
                    "log_output": {
                        "description": "Output location of the log, leave empty to suppress logging",
                        "items": {
                            "enum": [
                                "console",
                                "file",
                                "syslog"
                            "type": "string"
                        "title": "Log output",
                        "type": "array"
                    "log_rotation": {
                        "default": true,
                        "description": "Log rotation",
                        "title": "Log rotation",
                        "type": "boolean"
                    "log_symlink_current": {
                        "default": false,
                        "description": "Create symlink to current logs in the log directory",
                        "title": "Log symlink current",
                        "type": "boolean"
                    "log_syslog": {
                        "properties": {
                            "app_name": {
                                "default": "Zigbee2MQTT",
                                "description": "The name of the application (Default: Zigbee2MQTT).",
                                "title": "Localhost",
                                "type": "string"
                            "eol": {
                                "default": "/n",
                                "description": "The end of line character to be added to the end of the message (Default: Message without modifications).",
                                "title": "eol",
                                "type": "string"
                            "host": {
                                "default": "localhost",
                                "description": "The host running syslogd, defaults to localhost.",
                                "title": "Host",
                                "type": "string"
                            "localhost": {
                                "description": "Host to indicate that log messages are coming from (Default: localhost).",
                                "type": "string"
                            "path": {
                                "default": "/dev/log",
                                "description": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                                "examples": [
                                    "/var/run/syslog"
                                "title": "Path",
                                "type": "string"
                            "pid": {
                                "default": "process.pid",
                                "description": "PID of the process that log messages are coming from (Default process.pid).",
                                "title": "PID",
                                "type": "string"
                            "port": {
                                "default": 514,
                                "description": "The port on the host that syslog is running on, defaults to syslogd's default port.",
                                "title": "Port",
                                "type": "number"
                            "protocol": {
                                "default": "udp4",
                                "description": "The network protocol to log over (e.g. tcp4, udp4, tls4, unix, unix-connect, etc).",
                                "examples": [
                                    "udp4",
                                    "tls4",
                                    "unix",
                                    "unix-connect"
                                "title": "Protocol",
                                "type": "string"
                            "type": {
                                "default": "5424",
                                "description": "The type of the syslog protocol to use (Default: BSD, also valid: 5424).",
                                "title": "Type",
                                "type": "string"
                        "title": "syslog",
                        "type": "object"
                    "network_key": {
                        "description": "Network encryption key, changing requires repairing all devices!",
                        "oneOf": [
                                "title": "Network key(string)",
                                "type": "string"
                                "items": {
                                    "type": "number"
                                "title": "Network key(array)",
                                "type": "array"
                        "title": "Network key"
                    "output": {
                        "description": "Examples when 'state' of a device is published json: topic: 'zigbee2mqtt/my_bulb' payload '{\"state\": \"ON\"}' attribute: topic 'zigbee2mqtt/my_bulb/state' payload 'ON' attribute_and_json: both json and attribute (see above)",
                        "enum": [
                            "attribute_and_json",
                            "attribute",
                            "json"
                        "title": "MQTT output type",
                        "type": "string"
                    "pan_id": {
                        "description": "ZigBee pan ID, changing requires repairing all devices!",
                        "oneOf": [
                                "title": "Pan ID (string)",
                                "type": "string"
                                "title": "Pan ID (number)",
                                "type": "number"
                        "title": "Pan ID"
                    "timestamp_format": {
                        "description": "Log timestamp format",
                        "examples": [
                        "title": "Timestamp format",
                        "type": "string"
                    "transmit_power": {
                        "description": "Transmit power of adapter, only available for Z-Stack (CC253*/CC2652/CC1352) adapters, CC2652 = 5dbm, CC1352 max is = 20dbm (5dbm default)",
                        "title": "Transmit power",
                        "type": [
                            "number",
                            "null"
                "title": "Advanced",
                "type": "object"
            "availability": {
                "description": "Checks whether devices are online/offline",
                "oneOf": [
                        "title": "Availability (simple)",
                        "type": "boolean"
                        "properties": {
                            "active": {
                                "description": "Options for active devices (routers/mains powered)",
                                "properties": {
                                    "timeout": {
                                        "default": 10,
                                        "description": "Time after which an active device will be marked as offline in minutes",
                                        "title": "Timeout",
                                        "type": "number"
                                "title": "Active",
                                "type": "object"
                            "passive": {
                                "description": "Options for passive devices (mostly battery powered)",
                                "properties": {
                                    "timeout": {
                                        "default": 1500,
                                        "description": "Time after which an passive device will be marked as offline in minutes",
                                        "title": "Timeout",
                                        "type": "number"
                                "title": "Passive",
                                "type": "object"
                        "title": "Availability (advanced)",
                        "type": "object"
                "title": "Availability"
            "ban": {
                "items": {
                    "type": "string"
                "readOnly": true,
                "title": "Ban (deprecated, use blocklist)",
                "type": "array"
            "blocklist": {
                "description": "Block devices from the network (by ieeeAddr)",
                "items": {
                    "type": "string"
                "title": "Blocklist",
                "type": "array"
            "device_options": {
                "title": "Options that are applied to all devices",
                "type": "object"
            "devices": {
                "patternProperties": {
                        "$ref": "#/definitions/device"
                "propertyNames": {
                    "pattern": "^0x[\\d\\w]{16}$"
                "type": "object"
            "external_converters": {
                "description": "You can define external converters to e.g. add support for a DiY device",
                "examples": [
                    "DIYRuZ_FreePad.js"
                "items": {
                    "type": "string"
                "title": "External converters",
                "type": "array"
            "frontend": {
                "oneOf": [
                        "title": "Frontend (simple)",
                        "type": "boolean"
                        "properties": {
                            "auth_token": {
                                "description": "Enables authentication, disabled by default",
                                "title": "Auth token",
                                "type": [
                                    "string",
                                    "null"
                            "host": {
                                "description": "Frontend binding host. Binds to a unix socket when an absolute path is given instead.",
                                "examples": [
                                    "127.0.0.1",
                                    "::1",
                                    "/run/zigbee2mqtt/zigbee2mqtt.sock"
                                "title": "Bind host",
                                "type": [
                                    "string",
                                    "null"
                            "port": {
                                "default": 8080,
                                "description": "Frontend binding port. Ignored when using a unix domain socket",
                                "title": "Port",
                                "type": "number"
                            "ssl_cert": {
                                "description": "SSL Certificate file path for exposing HTTPS. The sibling property 'ssl_key' must be set for HTTPS to be activated.",
                                "title": "Certificate file path",
                                "type": [
                                    "string",
                                    "null"
                            "ssl_key": {
                                "description": "SSL key file path for exposing HTTPS. The sibling property 'ssl_cert' must be set for HTTPS to be activated.",
                                "title": "key file path",
                                "type": [
                                    "string",
                                    "null"
                            "url": {
                                "description": "URL on which the frontend can be reached, currently only used for the Home Assistant device configuration page",
                                "title": "URL",
                                "type": [
                                    "string",
                                    "null"
                        "title": "Frontend (advanced)",
                        "type": "object"
                "title": "Frontend"
            "groups": {
                        "$ref": "#/definitions/group"
                "propertyNames": {
                    "pattern": "^[\\w].*$"
                "type": "object"
            "homeassistant": {
                "default": false,
                "description": "Home Assistant integration (MQTT discovery)",
                "oneOf": [
                        "title": "Home Assistant (simple)",
                        "type": "boolean"
                        "properties": {
                            "discovery_topic": {
                                "description": "Home Assistant discovery topic",
                                "examples": [
                                    "homeassistant"
                                "title": "Homeassistant discovery topic",
                                "type": "string"
                            "legacy_entity_attributes": {
                                "default": true,
                                "description": "Home Assistant legacy entity attributes, when enabled Zigbee2MQTT will add state attributes to each entity, additional to the separate entities and devices it already creates",
                                "title": "Home Assistant legacy entity attributes",
                                "type": "boolean"
                            "legacy_triggers": {
                                "default": true,
                                "description": "Home Assistant legacy triggers, when enabled Zigbee2mqt will send an empty 'action' or 'click' after one has been send. A 'sensor_action' and 'sensor_click' will be discoverd",
                                "title": "Home Assistant legacy triggers",
                                "type": "boolean"
                            "status_topic": {
                                "description": "Home Assistant status topic",
                                "examples": [
                                    "homeassistant/status"
                                "title": "Home Assistant status topic",
                                "type": "string"
                        "title": "Home Assistant (advanced)",
                        "type": "object"
                "title": "Home Assistant integration"
            "map_options": {
                "properties": {
                    "graphviz": {
                        "properties": {
                            "colors": {
                                "properties": {
                                    "fill": {
                                        "properties": {
                                            "coordinator": {
                                                "type": "string"
                                            "enddevice": {
                                                "type": "string"
                                            "router": {
                                                "type": "string"
                                        "type": "object"
                                    "font": {
                                        "properties": {
                                            "coordinator": {
                                                "type": "string"
                                            "enddevice": {
                                                "type": "string"
                                            "router": {
                                                "type": "string"
                                        "type": "object"
                                    "line": {
                                        "properties": {
                                            "active": {
                                                "type": "string"
                                            "inactive": {
                                                "type": "string"
                                        "type": "object"
                                "type": "object"
                        "type": "object"
                "title": "Networkmap",
                "type": "object"
            "mqtt": {
                "properties": {
                    "base_topic": {
                        "default": "zigbee2mqtt",
                        "description": "MQTT base topic for Zigbee2MQTT MQTT messages",
                        "examples": [
                            "zigbee2mqtt"
                        "title": "Base topic",
                        "type": "string"
                    "ca": {
                        "description": "Absolute path to SSL/TLS certificate of CA used to sign server and client certificates",
                        "examples": [
                            "/etc/ssl/mqtt-ca.crt"
                        "title": "Certificate authority",
                        "type": "string"
                    "cert": {
                        "description": "Absolute path to SSL/TLS certificate for client-authentication",
                        "examples": [
                            "/etc/ssl/mqtt-client.crt"
                        "title": "SSL/TLS certificate",
                        "type": "string"
                    "client_id": {
                        "description": "MQTT client ID",
                        "examples": [
                            "MY_CLIENT_ID"
                        "title": "Client ID",
                        "type": "string"
                    "force_disable_retain": {
                        "default": false,
                        "description": "Disable retain for all send messages. ONLY enable if you MQTT broker doesn't support retained message (e.g. AWS IoT core, Azure IoT Hub, Google Cloud IoT core, IBM Watson IoT Platform). Enabling will break the Home Assistant integration",
                        "title": "Force disable retain",
                        "type": "boolean"
                    "include_device_information": {
                        "default": false,
                        "description": "Include device information to mqtt messages",
                        "title": "Include device information",
                        "type": "boolean"
                    "keepalive": {
                        "default": 60,
                        "description": "MQTT keepalive in second",
                        "title": "Keepalive",
                        "type": "number"
                    "key": {
                        "description": "Absolute path to SSL/TLS key for client-authentication",
                        "examples": [
                            "/etc/ssl/mqtt-client.key"
                        "title": "SSL/TLS key",
                        "type": "string"
                    "password": {
                        "description": "MQTT server authentication password",
                        "examples": [
                            "ILOVEPELMENI"
                        "title": "Password",
                        "type": "string"
                    "reject_unauthorized": {
                        "default": true,
                        "description": "Disable self-signed SSL certificate",
                        "title": "Reject unauthorized",
                        "type": "boolean"
                    "server": {
                        "description": "MQTT server URL (use mqtts:// for SSL/TLS connection)",
                        "examples": [
                            "mqtt://localhost:1883"
                        "title": "MQTT server",
                        "type": "string"
                    "user": {
                        "description": "MQTT server authentication user",
                        "examples": [
                            "johnnysilverhand"
                        "title": "User",
                        "type": "string"
                    "version": {
                        "default": 4,
                        "description": "MQTT protocol version",
                        "examples": [
                            5
                        "title": "Version",
                        "type": [
                            "number",
                            "null"
                "required": [
                    "server"
                "title": "MQTT",
                "type": "object"
            "ota": {
                "properties": {
                    "disable_automatic_update_check": {
                        "default": false,
                        "description": "Zigbee devices may request a firmware update, and do so frequently, causing Zigbee2MQTT to reach out to third party servers. If you disable these device initiated checks, you can still initiate a firmware update check manually.",
                        "title": "Disable automatic update check",
                        "type": "boolean"
                    "ikea_ota_use_test_url": {
                        "default": false,
                        "description": "Use IKEA TRADFRI OTA test server, see OTA updates documentation",
                        "title": "IKEA TRADFRI OTA use test url",
                        "type": "boolean"
                    "update_check_interval": {
                        "default": 1440,
                        "description": "Your device may request a check for a new firmware update. This value determines how frequently third party servers may actually be contacted to look for firmware updates. The value is set in minutes, and the default is 1 day.",
                        "title": "Update check interval",
                        "type": "number"
                    "zigbee_ota_override_index_location": {
                        "description": "Location of override OTA index file",
                        "examples": [
                            "index.json"
                        "title": "OTA index override file name",
                        "type": [
                            "string",
                            "null"
                "title": "OTA updates",
                "type": "object"
            "passlist": {
                "description": "Allow only certain devices to join the network (by ieeeAddr). Note that all devices not on the passlist will be removed from the network!",
                "items": {
                    "type": "string"
                "title": "Passlist",
                "type": "array"
            "permit_join": {
                "default": false,
                "description": "Allow new devices to join (re-applied at restart)",
                "title": "Permit join",
                "type": "boolean"
            "serial": {
                "properties": {
                    "adapter": {
                        "default": "auto",
                        "description": "Adapter type, not needed unless you are experiencing problems",
                        "enum": [
                            "deconz",
                            "zstack",
                            "zigate",
                            "ezsp",
                            "auto"
                        "title": "Adapter",
                        "type": [
                            "string"
                    "baudrate": {
                        "description": "Baud rate speed for serial port, this can be anything firmware support but default is 115200 for Z-Stack and EZSP, 38400 for Deconz, however note that some EZSP firmware need 57600",
                        "examples": [
                            38400,
                            57600,
                            115200
                        "title": "Baudrate",
                        "type": "number"
                    "disable_led": {
                        "default": false,
                        "description": "Disable LED of the adapter if supported",
                        "title": "Disable led",
                        "type": "boolean"
                    "port": {
                        "description": "Location of the adapter. To autodetect the port, set null",
                        "examples": [
                            "/dev/ttyACM0"
                        "title": "Port",
                        "type": [
                            "string",
                            "null"
                    "rtscts": {
                        "description": "RTS / CTS Hardware Flow Control for serial port",
                        "title": "RTS / CTS",
                        "type": "boolean"
                "title": "Serial",
                "type": "object"
            "whitelist": {
                "items": {
                    "type": "string"
                "readOnly": true,
                "title": "Whitelist (deprecated, use passlist)",
                "type": "array"
        "required": [
            "mqtt"
        "type": "object"
    "coordinator": {
        "ieee_address": "0xdc8e95fffe00af22",
        "meta": {
            "maintrel": "3 ",
            "majorrel": "6",
            "minorrel": "10",
            "product": 8,
            "revision": "6.10.3.0 build 297"
        "type": "EZSP v8"
    "network": {
        "channel": 11,
        "extended_pan_id": 221,
        "pan_id": 6754
    "restart_required": false,
    "version": "1.35.3",
    "zigbee_herdsman": {
        "version": "0.33.8"
    "zigbee_herdsman_converters": {
        "version": "18.28.3"
Paste the contents of configuration.yaml in the zigbee2mqtt folder (not the regular configuration.yaml in the config folder). Also, edited my previous post with a question.
Sorry I did not understand what I should do.
The logs are everything I see right now, maybe because i’ve recently updated and rebooted?
The useful info in the logs will be in the time frame leading up to when you experience problems. Zigbee2MQTT stores these in the logs folder, and on the Home Assistant side you might find the info in the .log.1 file in the config folder.
I have only these folders
Yes, that’s the timestamps. Inside the folders you will find the log file.
I attach the log of today. by the way after different reboot it worked for 10 minutes and now again i get the 502 bad gateway error in z2m web interface.
LOG: info 2024-02-29 12:30:50: Logging to console and directory: '/config/zigbee2mqt - Pastebin.com
"error 2024-02-29 12:34:46: Publish 'set' 'state' to 'Hue armadio' failed: 'Error: Command 0x001788010bd56642/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (sendZclFrameToEndpointInternal error)'
error 2024-02-29 12:34:46: Adapter disconnected, stopping"
is 12:34 when you had the error last? Seems your adapter disconnected.
No i still have it also later. I’ve rebooter the last 2 times and worked for like one minute and then stopped
check the logs for adapter disconnected. If there’s more of that, try reseating it, or a different port. You can also verify this by looking in the hardware section in HA when it is not working, if it really is disconnected it will not show up in the hardware list
Make sure you have dev/serial/by-id/* configured if you change the port, not dev/tty*
I’ve already tried but nothing changed.
This is the new log from mosquitto broker
2024-02-29 12:05:03: Client <unknown> closed its connection.
2024-02-29 12:05:13: New connection from 172.30.32.1:36093 on port 1883.
2024-02-29 12:05:13: New client connected from 172.30.32.1:36093 as 1iTbksUKUvNitq6R30tYG0 (p2, c1, k60, u'homeassistant').
2024-02-29 12:06:43: Client mqtt-explorer-4585a7cf disconnected.
2024-02-29 12:06:43: New connection from 172.30.32.1:55278 on port 1883.
2024-02-29 12:06:43: New client connected from 172.30.32.1:55278 as mqtt-explorer-4585a7cf (p2, c1, k60, u'mosquitto').
2024-02-29 12:07:03: New connection from 172.30.32.2:48752 on port 1883.
2024-02-29 12:07:03: Client <unknown> closed its connection.
2024-02-29 12:08:55: Client 1iTbksUKUvNitq6R30tYG0 closed its connection.
2024-02-29 12:09:03: New connection from 172.30.32.2:54678 on port 1883.
2024-02-29 12:09:04: Client <unknown> closed its connection.
2024-02-29 12:10:11: New connection from 172.30.32.1:33897 on port 1883.
2024-02-29 12:10:11: New client connected from 172.30.32.1:33897 as 0tjxYh8Su65koZkdYWqajk (p2, c1, k60, u'homeassistant').
2024-02-29 12:11:04: New connection from 172.30.32.2:43188 on port 1883.
2024-02-29 12:11:04: Client <unknown> closed its connection.
2024-02-29 12:13:04: New connection from 172.30.32.2:49120 on port 1883.
2024-02-29 12:13:04: Client <unknown> closed its connection.
2024-02-29 12:14:05: Client 0tjxYh8Su65koZkdYWqajk closed its connection.
2024-02-29 12:15:04: New connection from 172.30.32.2:51674 on port 1883.
2024-02-29 12:15:04: Client <unknown> closed its connection.
2024-02-29 12:15:18: New connection from 172.30.32.1:49925 on port 1883.
2024-02-29 12:15:18: New client connected from 172.30.32.1:49925 as 5Oed9Wra7DmJH7Tchcfn8m (p2, c1, k60, u'homeassistant').
2024-02-29 12:17:04: New connection from 172.30.32.2:36402 on port 1883.
2024-02-29 12:17:04: Client <unknown> closed its connection.
2024-02-29 12:18:24: New connection from 172.30.33.4:50050 on port 1883.
2024-02-29 12:18:24: New client connected from 172.30.33.4:50050 as mqttjs_a6a1fd2f (p2, c1, k60, u'mosquitto').
2024-02-29 12:18:30: Saving in-memory database to /data//mosquitto.db.
2024-02-29 12:19:04: New connection from 172.30.32.2:33712 on port 1883.
2024-02-29 12:19:04: Client <unknown> closed its connection.
2024-02-29 12:21:04: New connection from 172.30.32.2:44640 on port 1883.
2024-02-29 12:21:04: Client <unknown> closed its connection.
2024-02-29 12:23:04: New connection from 172.30.32.2:46640 on port 1883.
2024-02-29 12:23:04: Client <unknown> closed its connection.
2024-02-29 12:25:05: New connection from 172.30.32.2:36446 on port 1883.
2024-02-29 12:25:05: Client <unknown> closed its connection.
2024-02-29 12:25:19: Client mqttjs_a6a1fd2f closed its connection.
2024-02-29 12:26:15: New connection from 172.30.33.4:51404 on port 1883.
2024-02-29 12:26:15: New client connected from 172.30.33.4:51404 as mqttjs_2768622c (p2, c1, k60, u'mosquitto').
2024-02-29 12:27:05: New connection from 172.30.32.2:41938 on port 1883.
2024-02-29 12:27:06: Client <unknown> closed its connection.
2024-02-29 12:27:41: Client mqttjs_2768622c disconnected.
2024-02-29 12:29:05: New connection from 172.30.32.2:36884 on port 1883.
2024-02-29 12:29:05: Client <unknown> closed its connection.
2024-02-29 12:29:42: New connection from 172.30.33.4:34534 on port 1883.
2024-02-29 12:29:43: New client connected from 172.30.33.4:34534 as mqttjs_9b173b40 (p2, c1, k60, u'mosquitto').
2024-02-29 12:30:01: Client mqttjs_9b173b40 closed its connection.
2024-02-29 12:31:05: New connection from 172.30.32.2:47364 on port 1883.
2024-02-29 12:31:05: Client <unknown> closed its connection.
2024-02-29 12:31:15: New connection from 172.30.33.4:33460 on port 1883.
2024-02-29 12:31:15: New client connected from 172.30.33.4:33460 as mqttjs_edd11b37 (p2, c1, k60, u'mosquitto').
time="2024-02-29T12:31:26+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": read tcp 127.0.0.1:42552->127.0.0.1:80: read: connection reset by peer"
time="2024-02-29T12:32:21+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-02-29 12:33:07: New connection from 172.30.32.2:52274 on port 1883.
2024-02-29 12:33:07: Client <unknown> closed its connection.
2024-02-29 12:34:03: Client mqttjs_edd11b37 disconnected.
2024-02-29 12:35:08: New connection from 172.30.32.2:38974 on port 1883.
2024-02-29 12:35:08: Client <unknown> closed its connection.
2024-02-29 12:37:08: New connection from 172.30.32.2:51478 on port 1883.
2024-02-29 12:37:08: Client <unknown> closed its connection.
2024-02-29 12:37:19: New connection from 172.30.33.4:43896 on port 1883.
2024-02-29 12:37:19: New client connected from 172.30.33.4:43896 as mqttjs_354de10b (p2, c1, k60, u'mosquitto').
2024-02-29 12:37:49: Client 5Oed9Wra7DmJH7Tchcfn8m closed its connection.
2024-02-29 12:39:08: New connection from 172.30.32.1:36259 on port 1883.
2024-02-29 12:39:08: New connection from 172.30.32.2:53578 on port 1883.
2024-02-29 12:39:08: New client connected from 172.30.32.1:36259 as 2ptyebQIYuHhJvWrz8aNCh (p2, c1, k60, u'homeassistant').
2024-02-29 12:39:08: Client <unknown> closed its connection.
2024-02-29 12:41:08: New connection from 172.30.32.2:47506 on port 1883.
2024-02-29 12:41:08: Client <unknown> closed its connection.
2024-02-29 12:43:08: New connection from 172.30.32.2:35842 on port 1883.
2024-02-29 12:43:08: Client <unknown> closed its connection.
2024-02-29 12:43:54: Client mqttjs_354de10b closed its connection.
2024-02-29 12:44:45: New connection from 172.30.33.4:48102 on port 1883.
2024-02-29 12:44:46: New client connected from 172.30.33.4:48102 as mqttjs_e76b72af (p2, c1, k60, u'mosquitto').
2024-02-29 12:45:08: New connection from 172.30.32.2:44584 on port 1883.
2024-02-29 12:45:10: Client <unknown> closed its connection.
2024-02-29 12:46:49: Client mqttjs_e76b72af closed its connection.
2024-02-29 12:47:10: New connection from 172.30.32.2:32928 on port 1883.
2024-02-29 12:47:10: Client <unknown> closed its connection.
2024-02-29 12:47:56: New connection from 172.30.33.4:33718 on port 1883.
2024-02-29 12:47:56: New client connected from 172.30.33.4:33718 as mqttjs_dec54f98 (p2, c1, k60, u'mosquitto').
time="2024-02-29T12:48:08+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-02-29 12:48:19: Client mqttjs_dec54f98 closed its connection.
2024-02-29 12:48:31: Saving in-memory database to /data//mosquitto.db.
2024-02-29 12:49:10: New connection from 172.30.32.2:54422 on port 1883.
2024-02-29 12:49:10: Client <unknown> closed its connection.
2024-02-29 12:50:13: New connection from 172.30.33.4:50902 on port 1883.
2024-02-29 12:50:13: New client connected from 172.30.33.4:50902 as mqttjs_71513dee (p2, c1, k60, u'mosquitto').
2024-02-29 12:51:10: New connection from 172.30.32.2:57644 on port 1883.
2024-02-29 12:51:11: Client <unknown> closed its connection.
2024-02-29 12:51:37: Client mqttjs_71513dee closed its connection.
2024-02-29 12:53:06: New connection from 172.30.33.4:36892 on port 1883.
2024-02-29 12:53:06: New client connected from 172.30.33.4:36892 as mqttjs_944e3b92 (p2, c1, k60, u'mosquitto').
2024-02-29 12:53:10: Client mqttjs_944e3b92 closed its connection.
2024-02-29 12:53:10: New connection from 172.30.32.2:54446 on port 1883.
2024-02-29 12:53:10: Client <unknown> closed its connection.
2024-02-29 12:54:24: New connection from 172.30.33.4:60768 on port 1883.
2024-02-29 12:54:31: New client connected from 172.30.33.4:60768 as mqttjs_c1516b3d (p2, c1, k60, u'mosquitto').
2024-02-29 12:55:01: Client mqttjs_c1516b3d closed its connection.
2024-02-29 12:55:10: New connection from 172.30.32.2:52584 on port 1883.
2024-02-29 12:55:11: Client <unknown> closed its connection.
Seems like if it connects and then disconnects after a few seconds.
This is the parallel log of z2m
[12:53:34] INFO: Preparing to start...
[12:53:37] INFO: Socat not enabled
[12:53:42] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2024-02-29 12:54:05: Logging to console and directory: '/config/zigbee2mqtt/log/2024-02-29.12-54-04' filename: log.txt
Zigbee2MQTT:info  2024-02-29 12:54:05: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info  2024-02-29 12:54:05: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:info  2024-02-29 12:54:16: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2024-02-29 12:54:16: Coordinator firmware version: '{"meta":{"maintrel":"3 ","majorrel":"6","minorrel":"10","product":8,"revision":"6.10.3.0 build 297"},"type":"EZSP v8"}'
Zigbee2MQTT:info  2024-02-29 12:54:16: Currently 41 devices are joined:
Zigbee2MQTT:info  2024-02-29 12:54:16: Lavatrice (0xa4c1386642f59f65): A1Z - Nous Smart plug (with power monitoring) (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Lavastoviglie (0xa4c1381621ddfdf7): A1Z - Nous Smart plug (with power monitoring) (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Pir Camera da Letto (0x54ef4410007993d8): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Telecomando Hue Camera da Letto (0x0017880103e60704): 324131092621 - Philips Hue dimmer switch (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Hue white letto (0x001788010c349e7f): 9290030211 - Philips Hue white Candle bulb E14 bluetooth (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Bottone cabina armadio (0x00158d0002015ebf): WXKG11LM - Aqara Wireless mini switch (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Pir cabin armadio (0x54ef441000775cc3): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Hue armadio (0x001788010bd56642): 929002469202 - Philips Hue white A60 bulb E27 1050lm with Bluetooth (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: hue ambient 1 letto (0x001788010615d298): 8718696695203 - Philips Hue white ambiance E14 (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Hue ambient 2 letto (0x001788010615d2a9): 8718696695203 - Philips Hue white ambiance E14 (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: TempHum Salotto (0x00158d0008e024a8): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: 0xdc8e95fffec394b4 (0xdc8e95fffec394b4): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Bottone hue bagno (0x001788010896c084): 8718699693985 - Philips Hue smart button (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Hue specchio (0x001788010ba4e7d6): 9290024684 - Philips Hue white ambiance E27 1100lm with Bluetooth (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Hue bagno (0x001788010ba4d647): 9290024684 - Philips Hue white ambiance E27 1100lm with Bluetooth (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Pir bagno (0x54ef441000774b38): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Hue Ensis UP (0x001788010d1aac33): 4090330P9 - Philips Hue Ensis (black) (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Hue Ensis DOWN (0x001788010d1a9ad5): 4090330P9 - Philips Hue Ensis (black) (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Telecomando Hue Salotto (0x0017880103e5565f): 324131092621 - Philips Hue dimmer switch (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: PIR cucina (0x54ef441000775c0e): RTCGQ14LM - Aqara Motion sensor P1 (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Hue cucina (0x001788010d2cb51d): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: Bottone cucina (0x00158d0002043ba4): WXKG11LM - Aqara Wireless mini switch (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Sensore perdite  (0x00158d0008d0af03): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Finestra scrivania (0x00158d0008d9386c): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Finestra ingresso (0x00158d0008e01de2): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Porta finestra salotto (0x00158d0008e0fa3e): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Finestra colonna (0x00158d0008d9384e): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Finestra bagno  (0x00158d0008e006a0): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Porta finestra cucina (0x00158d0008f1044c): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Porta Ingresso (0x00158d0008d938a3): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Cubo (0x00158d00026e9935): MFKZQ01LM - Aqara Cube (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: zigbee plant sensor (0xa4c1383c043ffe6b): TS0601_soil - TuYa Soil sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: knob (0x70ac08fffe2646dc): ERS-10TZBVK-AA - TuYa Smart knob (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Presa smart (0xa4c13861083f6f3c): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
Zigbee2MQTT:info  2024-02-29 12:54:16: temp hum esterno (0x00158d00044d2f01): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Cantinetta12 (0x00158d00022cc3c5): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Cantientta8 (0x00158d0002789b07): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: 0xa4c138badd5aef36 (0xa4c138badd5aef36): ERS-10TZBVK-AA - TuYa Smart knob (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: door cantinetta 12 (0xa4c1382c376a0c2e): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: PIR salotto (0x00158d0002b48584): RTCGQ11LM - Aqara Motion sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Finestra camera (0x00158d0008d8c05e): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
Zigbee2MQTT:info  2024-02-29 12:54:16: Zigbee: disabling joining new devices.
Zigbee2MQTT:info  2024-02-29 12:54:17: Connecting to MQTT server at mqtt://core-mosquitto
connects and disconnects in the mqtt log are normal. have you searched the all the z2m-logs for adapter disconnects? There’s no errors in the z2m log you pasted now.
