Zigbee2MQTT make me crazy please help
My best advice would be to implement a long (more than 1m) USB extender cable. Even on a stable system. Moving the coordinator far away form any electrical devices.
Good morning, Today I’ll buy one because it stopped again. Do you suggest a 3.0 extension or is a 2.0 ok?
better than a 3.0
2.0 is fine, however do not think it makes a lot of difference.
The suggested USB extension cable is a passive extension cable, NO hub/electronic amplifying or anything.
Just a cable.
Trying to add disable_automatic_update_check option but it does not seemto make any difference. Where do you actuallu add it? I have it in my /root/config/zigbee2mqtt/configuration.yaml which looks like this. But updates available prompt in Settings in HA still says that 3 devices have updates. Any clue how to disable OTA check properly?
homeassistant: true
mqtt:
  server: mqtt://core-mosquitto:1883
  user: addons
  password: REMOVED
serial:
  port: /dev/ttyUSB0
frontend:
  port: 8099
advanced:
  homeassistant_legacy_entity_attributes: false
  legacy_api: false
  legacy_availability_payload: false
device_options:
  legacy: false
devices:
  '0x00158d000882f49e':
    friendly_name: waterleak_kitchensink
  '0x00158d00087973dd':
    friendly_name: waterleak_klk_1
  '0x00158d0008831836':
    friendly_name: waterleak_waterhub_laundry
  '0xe0798dfffeb2be93':
    friendly_name: sonoff_switch_kitchen_underspots
  '0x54ef441000687fa0':
    friendly_name: aqara_plug_kitchen_sage
  '0xe0798dfffec94d09':
    friendly_name: sonoff_switch_upperfloor_lights1
  '0x003c84fffe975348':
    friendly_name: ikea_switch_upperfloor_light1
  '0x54ef4410007ee432':
    friendly_name: aqara_plug_kitchen_freezer
  '0x54ef4410006887ac':
    friendly_name: aqara_plug_kitchen_dishwasher
  '0x00158d000950a80c':
    friendly_name: lk_warmfloor_out_temp
  '0x00158d000950a7e9':
    friendly_name: lk_warmfloor_return_temp
ota:
  disable_automatic_update_check: true
  zigbee_ota_override_index_location: null
  ikea_ota_use_test_url: true
  update_check_interval: 525600
