badr
(Badr)
January 7, 2025, 4:13pm
1
I’ve created a sensor for offline zigbee2mqtt devices to show in my network dashboard, the sensor relies on pyscript , subscribes to availability topics and counts the offline devices.
pyscript code:
import json
import re
zigbee2mqtt_offline_devices = {}
@state_trigger("sensor.offline_zigbee_devices")
def update_icon():
sensor.offline_zigbee_devices.icon = "mdi:zigbee"
sensor.offline_zigbee_devices.friendly_name = "Offline Zigbee Devices"
sensor.offline_zigbee_devices.state_class = "measurement"
@mqtt_trigger("zigbee2mqtt/+/availability")
@task_unique("zigbee2mqtt_availability", kill_me=True)
def zigbee2mqtt_availability(topic,payload):
offline = 0
offline_devices = []
device = re.search('zigbee2mqtt/(.*)/availability', topic).group(1)
if(json.loads(payload)['state'] == "offline"):
zigbee2mqtt_offline_devices[device] = 1
else:
zigbee2mqtt_offline_devices[device] = 0
for dev in zigbee2mqtt_offline_devices:
if zigbee2mqtt_offline_devices[dev] == 1:
offline_devices.append(dev)
offline += zigbee2mqtt_offline_devices[dev]
sensor.offline_zigbee_devices = offline
sensor.offline_zigbee_devices.devices = offline_devices
Works great. I had to replace
by
if payload == “offline”:
badr
(Badr)
January 10, 2025, 7:04pm
3
Interesting! I’m receiving availability as {'state':'offline'} json.
You might wanna drop import json from your script then.
Why did you choose to monitor an MQTT topic using pyscript? An alternative approach would be to use a MQTT sensor, which is naive to Home Assistant.
Hi everyone,
If this is a duplicate, please let me know. I was just reading and saw multiple questions about adding an availability sensor.
This can easily be achieved!
Step 1
In your z2m configuration, make sure you select MQTT version 5, this is needed for message retention. And make sure you have availability: enabled: true. This is disabled by default.
Restart if needed.
Now z2m publishes the network state (online/offline) of each device in it own topic, for instance: zigbee2mqtt/Kitch…
And then you could make a counter:
{{ integration_entities('mqtt')
| select('search', '_network_state')
| expand
| selectattr('state', 'eq', 'off')
| list
| count }}
badr
(Badr)
January 27, 2025, 2:19pm
5
That would’ve created a separate entity for each device, I have 150+ devices and only need to know which devices are offline. One sensor does the job without cluttering my system.
I also don’t need to add new sensors whenever I add a new device, this way it’s completely dynamic.
sorry for the noob question, but how should I import it into homeassistant for it to work?
badr
(Badr)
September 25, 2025, 8:39am
7
Noob questions are the reason for having this community.
You will need to install pyscript via HACS, then create a python script in <config>/pyscript directory and paste the script in it.
something like <config>/pyscript/z2m_offline_devices.py
Kejserjorn
(Jens Skov Knudsen)
November 25, 2025, 9:56pm
8
This is really great!
It seems to be counting both groups and devices though. Is there a way to filter out groups and only monitor actual devices?
badr
(Badr)
November 26, 2025, 4:22pm
9
Unfortunately, you can’t distinguish groups from devices, however, you can skip counting particular devices/groups by name.
Something like:
if device == 'light_group' or device == 'Coordinator':
return
Kejserjorn
(Jens Skov Knudsen)
November 27, 2025, 7:06am
10
Thank You.
My problem was, that a device called “901” was always shown as offline. I suppose this is a group in z2m called default_bind_group that has the id “901”. But even if i deleted the group in z2m it was still counted and shown as offline.
I was able to exclude the device like this:
if dev == "901":
continue
ddaniel
(Daniel Dekovic)
November 27, 2025, 7:14am
11
You can monitor zgibbe devices using uptime kuma and sent notification on mob using telegram.
badr
(Badr)
November 27, 2025, 7:20am
12
It’s probably better to use mqttexplorer or any similar tool to delete the availability topic.
Kejserjorn
(Jens Skov Knudsen)
November 27, 2025, 7:30am
13
Well, that was a much better solution. Thanks!
Kejserjorn
(Jens Skov Knudsen)
November 27, 2025, 7:44am
14
Didn’t even consider that Uptime Kuma could monitor mqtt devices. I was only using it to monitor Docker containers.
Thank You!
I pasted it inside developer tools template and get:
mqtt:
binary_sensor:
Result type: string
This template does not listen for any events and will not update automatically.
I’m with 2025.12.2 core
Z2M 2.7.1
Of course the availability enabled
