Good day, i have replaced one cheap adaptor which was connected via USB to a network one, and it worked without any problems, today i have unplugged old adaptor (which was connected to usb but not used) and starting getting this error on start of the Zigbee2MQTT, which is really strange as i have used ezsp driver (this aliexpress device https://fr.aliexpress.com/item/1005005271016330.html?spm=a2g0o.order_list.order_list_main.99.39065e5b2uZlbe&gatewayAdapt=glo2fra) and then switched to a network coordinator SLZB-06P7
However right now i got this permanent failed errors on Zigbee2MQTT start
[00:35:11] INFO: Preparing to start...
[00:35:11] INFO: Socat not enabled
[00:35:11] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-03-01 00:35:12: Logging to console and directory: '/config/zigbee2mqtt/log/2024-03-01.00-35-12' filename: log.txt
Zigbee2MQTT:info 2024-03-01 00:35:12: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-03-01 00:35:12: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:error 2024-03-01 00:35:12: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-03-01 00:35:12: Failed to start zigbee
Zigbee2MQTT:error 2024-03-01 00:35:12: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-03-01 00:35:12: Exiting...
Zigbee2MQTT:error 2024-03-01 00:35:12: Error: spawn udevadm ENOENT
at Process.ChildProcess._handle.onexit (node:internal/child_process:284:19)
at onErrorNT (node:internal/child_process:477:16)
at processTicksAndRejections (node:internal/process/task_queues:82:21)
To test i have completely removed the Zigbee2MQTT directory and reinstalled the plugings, but without any luck.
Can someone advice me please ?
Thank you
After some time, it was not a typo, two serials are required the configuration in my example was in yaml format, so there is two serials there.
I have finished to completely wiping my home assistant, and started with fresh image, Zigbee2MQTT is not starting with the same error.
I have found the reason, the problem was in spaces in config:
serial:
serial:
port: tcp://192.168.1.188:6638
baudrate: 115200
adapter: zstack
disable_led: false
advanced:
transmit_power: 20
Well, the problem was from the fact that i have copied pasted the configuration from SLZB-06P7, there is a section for Zigbee2MQTT, with fresh empty config i was not able to start the Zigbee2MQTT, but when i edited the text i saw a strange formatting problem so before i had:
Note the “null” here which i have not typed, my gues is that some formatting made Zigbee2MQTT to fail, i have enabled the herman debug, but it was not helping.
I am not sure what was that, i have used a notepad++ to work with configs.
Minimal configuration is working, but maybe i have half broken arms but facing some strange problems i think i am on the edge here, i am not exacly sure what do to next, here is the list:
1: Mosquito do not publish entities, tried to leave it alone, or set password, no effect, no devices under developer tools >States
2: I have two zigbee adapters SLZB-06P (M) and a cheapish usb adapter
The only good news i have is that my Aeotec repeater solved the range problem, so i can use my devices, however without MQTT it is impossible to use home assistant, any ideas what i am missing ?
I see messages from to when i turn my knob 0x54ef441000a054a4
MQTT publish: topic 'zigbee2mqtt/0x54ef441000a054a4
However they are published in zigbee2mqtt topic, and not replicated in home assistant.
I am not sure if the zigbee2mqtt is a correct value for the MQTT topic and there should be 2 of them
homeassistant and zigbee2mqtt.
I continue digging why i dont have any entity in home assistant from zigbee2mqtt integration.
After reading the MQTT i think it is normal that it is not updating as it’s the automation action publishing, but still they should be visible as a entities in home assistant.
Ok so i have found why, but its really strange and i have not touched this part.
So the default credentials created by MQTT integration were wrong and not working
I have found a working credentials under at homeassistant/zigbee2mqtt/configuration.yaml
login: addon
pass:verylongpass
This is not ok right ? I mean its a fresh install i installed MQTT and zigbee2mqtt, left everything at default besides the zigbee2mqtt adaptor configuration.
I have used the vmdk latest image, damn this is not OK
Well at least i have learned how this thing works =)
I just received my SLZB-06. It had the v2.0.18 core firmware. Because I had the same problems, I did an update of core and zibgee firmware. I tried with both connections (ethernet and wifi) and using static IP and generic MDNS SLZB-06.local
info 2024-04-14 19:45:45: Logging to console and directory: '/app/data/log/2024-04-14.19-45-45' filename: log.txt
info 2024-04-14 19:45:45: Starting Zigbee2MQTT version 1.36.1 (commit #ffc2ff1)
info 2024-04-14 19:45:45: Starting zigbee-herdsman (0.40.3)
error 2024-04-14 19:46:05: Error while starting zigbee-herdsman
error 2024-04-14 19:46:05: Failed to start zigbee
error 2024-04-14 19:46:05: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
error 2024-04-14 19:46:05: Exiting...
error 2024-04-14 19:46:05: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
Nothing to do ! It doesn’t solve the problem.
Any idea please?
