Yes, it worked wonderfully! Thanks!
I updated Zigbee2Mqtt and Home Assistant Core and now only one click works. Is it just me?
Does not work when using Input Select: Next to cycle through scenes. Normal operations on the a regular light bulb work for me. Iâm able to cycle through the scene entities using a separate automation as shown below:
alias: test
description: ""
- platform: device
domain: mqtt
device_id: some_device_ID
type: action
subtype: 3_single
discovery_id: some_device_ID action_3_single
condition: []
- service: input_select.select_next
entity_id: input_select.scene_entities
cycle: true
- service: scene.turn_on
entity_id: "{{ states('input_select.scene_entities')}}"
mode: single
Edit: It doesnât look like you can have more than a single action per press (i.e. you canât call Light Bulb 1: Toggle and Light Bulb 2: Toggle. Only Light Bulb 1: Toggle will work)
Hi Guy,
Iâm new in Home Assistant and I try to use a TS0044 button, my mqtt setup and Zigbee2MQTT setup seems to be ok because I successfully pairing my button and my roller.
Regarding my roller all is OK, but I have an issue with my button x4 TS0044
I can see in equipement event âbutton 1 singleâ âbutton 2 singleâ âbutton 1 doubleâ but nothing is working in blueprint script.
When I excute manualy automation I was an error with
command: â{{ trigger.to_state.state }}â
I changed it as I saw in forum by :
command: â{{ trigger.payload_json }}â
Now I donât get error with manual execution but when I push a button nothing
Can you help me?
I give you screenshots
Thank you so much for your help
I can only get single click to work as well.
hello,
what is that blueprint good for? as its natively supported by haas?
thanks!
