Yes, I see errors in the log but I have since rebooted and lost these errors. If the issue pops up again I will copy-paste the errors!
Question to other users. Since the naming was changed (it takes the name of the box and not the one configured in Configuration.yaml) I cannot operate the box via Google Home.
It shows up in Google home but always with the status “Offline” and I cannot do anything with it.
Do others have this problem as well?
Thx
René
It happened again and this is the error:
2020-05-05 19:29:39 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.stb_arris_uhd is taking over 10 seconds
2020-05-05 19:30:33 ERROR (MainThread) [homeassistant.helpers.entity] Update for media_player.stb_arris_uhd fails
File "/usr/local/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py", line 488, in wrap_socket
cnx.do_handshake()
File "/usr/local/lib/python3.7/site-packages/OpenSSL/SSL.py", line 1934, in do_handshake
self._raise_ssl_error(self._ssl, result)
File "/usr/local/lib/python3.7/site-packages/OpenSSL/SSL.py", line 1663, in _raise_ssl_error
raise SysCallError(errno, errorcode.get(errno))
OpenSSL.SSL.SysCallError: (104, 'ECONNRESET')
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 976, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 370, in connect
ssl_context=context,
File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl_.py", line 377, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/local/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py", line 494, in wrap_socket
raise ssl.SSLError("bad handshake: %r" % e)
ssl.SSLError: ("bad handshake: SysCallError(104, 'ECONNRESET')",)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 725, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 439, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='web-api-prod-obo.horizon.tv', port=443): Max retries exceeded with url: /oesp/v3/NL/nld/web/channels (Caused by SSLError(SSLError("bad handshake: SysCallError(104, 'ECONNRESET')")))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 279, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 472, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/config/custom_components/ziggonext/media_player.py", line 57, in update
self.api.load_channels()
File "/usr/local/lib/python3.7/site-packages/ziggonext/ziggonext.py", line 171, in load_channels
response = requests.get(self._api_url_channels)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 514, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='web-api-prod-obo.horizon.tv', port=443): Max retries exceeded with url: /oesp/v3/NL/nld/web/channels (Caused by SSLError(SSLError("bad handshake: SysCallError(104, 'ECONNRESET')")))
With the new update to 0.110 I get the error message below in the log.
What can I do about it?
Logboekdetails (WARNING)
Logger: homeassistant.components.media_player
Source: components/media_player/__init__.py:938
Integration: Mediaspeler (documentation, issues)
First occurred: 15:18:36 (1 occurrences)
Last logged: 15:18:36
MediaPlayerDevice is deprecated, modify ZiggoNextMediaPlayer to extend MediaPlayerEntity
I found it
Renamed entity class names
Just released a new version with that fix. You can update using HACS!
Great, I just tested it and the error is gone.
Thanks for your quick response.
Thanks Rudolf for the support.
Is it also possible to get Netflix (channel 150) or Videoland (channel 151) supported?
That way, a cinema/movie scene can be created.
There’s an attribute that shows the current app name. You can use that attribute for your automation/scene.
I know, but I think I didn’t explain properly.
I would like to see Netflix and Videoland in the source list.
Ah, OK. Please submit a feature request in the repo!
Very cool. I’ve got it working.
I have two mediaboxes-Next at home.
Right now I can only control (and see) 1.
I there something I can add to the config so I see both?
Should work out of the box. I have two myself.
mmmm… unfortunaly I see only 1 mediabox
Are both boxes accessible via https://www.ziggogo.tv? That web app has the same source for the boxes.
Yes when I login in ziggogo.tv I see both media boxes.
The one I see in HA is on the top of the listing ziggogo.tv
Yesterday I updated to version 0.111, unfortunately ziggonext isn’t working any more.
Logboekdetails (ERROR)
Logger: homeassistant.setup
Source: custom_components/ziggonext/__init__.py:30
First occurred: 10:08:25 (1 occurrences)
Last logged: 10:08:25
Error during setup of component ziggonext
File "/usr/src/homeassistant/homeassistant/setup.py", line 190, in _async_setup_component
result = await asyncio.wait_for(task, SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/config/custom_components/ziggonext/__init__.py", line 30, in setup
api.initialize(_LOGGER)
File "/usr/local/lib/python3.7/site-packages/ziggonext/ziggonext.py", line 124, in initialize
self.load_channels()
File "/usr/local/lib/python3.7/site-packages/ziggonext/ziggonext.py", line 189, in load_channels
station["images"][2]["url"],
IndexError: list index out of range
I’ve got the same this morning.
Same here.
Hi, I’ve updated the component. Looks like it was an update of Ziggo that was the culprit. Channel sensors are also up again.
Great thanks. All working again!
