@mercenaruss Got two firmware/hardware feature requests for ZigStar if such are OK to post here(?):
First, pls consider adding Zeroconf support to ZigStar LAN Gateway for ZHA network discovery, see:
Secondly, please consider using other USB-to-UART chip with EEPROM on ZigStar USB adapter so can add unique PID (Product ID) or other USB identification strings for automatic USB discovery, see:
Just to be clear; the reaspon for both of those two requests is so can use automatic discovery in ZHA, which is something that has already been added for a few Zigbee gateways and Zigbee USB dongles:
https://www.home-assistant.io/integrations/zha#discovery-via-usb-or-zeroconf
https://www.home-assistant.io/integrations/usb/
PS: The most commonly available USB-to-UART chips are CP2102N by Silabs and FT231 by FTDI.
