@mercenaruss How can I flash router firmware on UZG-01 0.3 (with PoE?). I flashed the FW File âCC1352P2_CC2652P_launchpad_router_20221102.zipâ successfully 2-3 times using HA Addon (but at the end I see âURL NOT FOUNDâ in the console) and 2 times using Flash Programmer 2, yet I canât pair the UZG-01 to my other one which is working fine as a coordinator - it doesnât show up. I flashed back to coordinator âLast Koenkk Firmware - CC1352P7_coordinator_*.zipâ but I donât see a CC1352P7 router.
Edit: More info:
Using Zigbee2MQTT with 1 UZG 0.3 as coordinator
Have two extra UZG 0.3s (I mean the sticker on the back says 0.3 but in the Status page of the coordinator and 1 router, it says CC2652P version CC2652PP1FRGZR and the MACs of the coordinator and 1 router are about the same, the other says CC2652P version: CC2652P and the mac is completely different)
I have tried both launchpad_router and other_router, on both my extra UZGs, I permit join in Zigbee2MQTT - I canât see them
from UZG-01 0.2 and up,chip used is CC2652P7.
So when flash in addon select CC2651P7 and auto-bootloader.
Router firmware is still not available for CC2652P7,kinda expensive device for a router .
Will update when router firmware will be available for CC2652P7.
Hmm well It does say in the Elecrow page as well as the UZG website it can be used as a router in several places. Expensive or not it is advertised as such, I expect it to be possible. Would appreciate the router FW as soon as itâs out thanks.
Hi, if i order the device from here UZG Gateway - ZigStar UZG (zig-star.com) - how i know which HW version and chipset is used i cannot select the version anywhere â thanks.
Thanks, for now I successfully built my own and itâs working fine so far - paired to Coordinator and paired 1 temp sensor to it for test - so far all is good. Of course when the âofficialâ one comes out I might check it out as well.
I looked and manually applied the patches from Koenkk in the same files and same code spots ( they all matched ) as it was done for CC1352P2 router (also looking at what he used to make the firmware for coordinator P7 and relevant setting from there if they differ from router) on top of the example app zr_genericapp_LP_CC1352P7_4_tirtos7_ticlang. I donât know if they are complete, correct or missing something but i have paired two devices so far and all is looking good (even using UZG-01 in Zigbee To Wifi mode right now for testing as itâs too late to patch the necessary cables to get my poe working at the right spot):
Anyway here is the firmware TEST VERSION, use at your own risk, I canât really offer support as of this point I donât understand the code much, and why Koenkk arrived at the patches that are already done, I got the basic version of the TI example router app, and applied Koenkkâs patches - that is all:
Your HA add-on but Flash Programmer 2 should also work from my experience trying stuff in the previous days. Multi-tool doesnât work with P7 it seems.
EDIT: @mercenaruss I tested and I can confirm it works with Flash Programmer 2. But you need the firmware in bin format instead of hex. You can either convert it using some tool, or you can download the bin file that I configured the Code Compose Studio build to additionally convert using its own tools here â
Just tested flashing with bin file and programmer over USB (much, much faster than the web tool) and I used the Router Reconnect button, it worked too.
I run zigbee2mqtt on a different PC than my HA PC.
Likewise for MQTT.
My existing setup is of about 130 devices (many routers) with another 70+ to be added.
Current Sonoff Dongle -E is acting up with the 130 devices.
So I have bought the UZG-01 as it is advertised to support up to 300 devices.
I plan to start a new zigbee2mqtt network and slowly migrate my devices.
Hope that the UZG-01 will up to the task with my 200 or so devices.
My Sonoff Dongle -E was fine with about 100 devices. After that it was very hard to add new devices to the network. I lost track when but now I have 130 devices and I cant add any more devices at all.
I hope also ,take in consideration this is still first revision of firmware from Koenkk.
By default this is double RAM and FLASH memory that CC2652P2 so should be much better on handling large networks.
Be very carefull when you migrate from ezsp to znp type of chip.
Make all possible backups, nvram ,z2m or zha depending on what you use. To be on safe side.
