The Devolo you linked and my zipato are all similar. 99% sure I linked the correct manual.
Matches the device serial sticker.
Think this is the dioagnostic file for the device
"id": 13,
"name": "",
"loc": "",
"values": [
"id": "13-37-0-currentValue",
"nodeId": 13,
"commandClass": 37,
"commandClassName": "Binary Switch",
"endpoint": 0,
"property": "currentValue",
"propertyName": "currentValue",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Current value",
"stateless": false,
"commandClassVersion": 1,
"list": false,
"value": false,
"isCurrentValue": true,
"targetValue": "37-0-targetValue",
"lastUpdate": 1656601679707,
"newValue": false
"id": "13-37-0-targetValue",
"nodeId": 13,
"commandClass": 37,
"endpoint": 0,
"property": "targetValue",
"propertyName": "targetValue",
"type": "boolean",
"readable": true,
"writeable": true,
"label": "Target value",
"stateless": false,
"list": false,
"value": false,
"lastUpdate": 1656601678665,
"newValue": false
"id": "13-48-0-General Purpose",
"nodeId": 13,
"commandClass": 48,
"commandClassName": "Binary Sensor",
"endpoint": 0,
"property": "General Purpose",
"propertyName": "General Purpose",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "General Purpose",
"ccSpecific": {
"sensorType": 1
"stateless": false,
"commandClassVersion": 2,
"list": false,
"value": false,
"lastUpdate": 1656601678674,
"newValue": false
"id": "13-48-0-Tamper",
"nodeId": 13,
"commandClass": 48,
"endpoint": 0,
"property": "Tamper",
"propertyName": "Tamper",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Tamper",
"ccSpecific": {
"sensorType": 8
"stateless": false,
"list": false,
"value": false,
"lastUpdate": 1656599958042,
"newValue": false
"id": "13-112-0-7-8",
"nodeId": 13,
"commandClass": 112,
"commandClassName": "Configuration",
"endpoint": 0,
"property": 7,
"propertyName": "Disable Sound",
"propertyKey": 8,
"type": "number",
"readable": true,
"writeable": true,
"description": "Prevents audio from the siren - leaving only the strobe function.",
"label": "Disable Sound",
"default": 1,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"allowManualEntry": true,
"states": [
"text": "Enables Sound",
"value": 0
"text": "Disables Sound",
"value": 1
"value": 0,
"lastUpdate": 1656625358055,
"newValue": 0
"id": "13-112-0-7-16",
"nodeId": 13,
"endpoint": 0,
"property": 7,
"propertyName": "Notification Type",
"propertyKey": 16,
"type": "number",
"readable": true,
"writeable": true,
"description": "Notification event type to use for trigger events",
"label": "Notification Type",
"default": 0,
"stateless": false,
"min": 0,
"max": 1,
"list": true,
"states": [
"text": "Notification Report",
"value": 0
"text": "Sensor Binary Report",
"value": 1
"value": 0,
"lastUpdate": 1656625358056,
"newValue": 0
"id": "13-112-0-29",
"nodeId": 13,
"endpoint": 0,
"property": 29,
"propertyName": "Disable Alarm",
"type": "number",
"readable": true,
"writeable": true,
"description": "Disables the alarm function entierly, including any tamper detection.",
"label": "Disable Alarm",
"default": 0,
"stateless": false,
"min": 0,
"max": 1,
"list": false,
"value": 0,
"newValue": 0
"id": "13-112-0-31",
"nodeId": 13,
"endpoint": 0,
"property": 31,
"propertyName": "Alarm Duration",
"type": "number",
"readable": true,
"writeable": true,
"label": "Alarm Duration",
"default": 6,
"stateless": false,
"min": 0,
"max": 127,
"unit": "30 seconds",
"list": true,
"states": [
"text": "Never stop",
"value": 0
"value": 6,
"newValue": 6
"id": "13-113-0-Home Security-Cover status",
"nodeId": 13,
"commandClass": 113,
"commandClassName": "Notification",
"endpoint": 0,
"property": "Home Security",
"propertyName": "Home Security",
"propertyKey": "Cover status",
"propertyKeyName": "Cover status",
"type": "number",
"readable": true,
"writeable": false,
"label": "Cover status",
"ccSpecific": {
"notificationType": 7
"stateless": false,
"commandClassVersion": 4,
"min": 0,
"max": 255,
"list": true,
"states": [
"text": "idle",
"value": 0
"text": "Tampering, product cover removed",
"value": 3
"value": 0,
"newValue": 0
"id": "13-114-0-manufacturerId",
"nodeId": 13,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"endpoint": 0,
"property": "manufacturerId",
"propertyName": "manufacturerId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 305,
"newValue": 305
"id": "13-114-0-productType",
"nodeId": 13,
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 4,
"newValue": 4
"id": "13-114-0-productId",
"nodeId": 13,
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"stateless": false,
"min": 0,
"max": 65535,
"list": false,
"value": 10,
"newValue": 10
"id": "13-134-0-libraryType",
"nodeId": 13,
"commandClass": 134,
"commandClassName": "Version",
"endpoint": 0,
"property": "libraryType",
"propertyName": "libraryType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"stateless": false,
"list": true,
"states": [
"text": "Unknown",
"value": 0
"text": "Static Controller",
"value": 1
"text": "Controller",
"value": 2
"text": "Enhanced Slave",
"value": 3
"text": "Slave",
"value": 4
"text": "Installer",
"value": 5
"text": "Routing Slave",
"value": 6
"text": "Bridge Controller",
"value": 7
"text": "Device under Test",
"value": 8
"text": "N/A",
"value": 9
"text": "AV Remote",
"value": 10
"text": "AV Device",
"value": 11
"value": 3,
"lastUpdate": 1656599958043,
"newValue": 3
"id": "13-134-0-protocolVersion",
"nodeId": 13,
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version",
"stateless": false,
"list": false,
"value": "4.38",
"newValue": "4.38"
"id": "13-134-0-firmwareVersions",
"nodeId": 13,
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions",
"stateless": false,
"list": false,
"value": [
"1.15",
"1.8"
"newValue": [
"1.15",
"1.8"
"id": "13-134-0-hardwareVersion",
"nodeId": 13,
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"type": "number",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version",
"stateless": false,
"list": false,
"value": 1,
"newValue": 1
"groups": [
"text": "LifeLine",
"endpoint": 0,
"value": 1,
"maxNodes": 8,
"isLifeline": true,
"multiChannel": false
"neighbors": [],
"ready": true,
"available": true,
"hassDevices": {},
"failed": false,
"inited": true,
"eventsQueue": [
"time": "2022-06-30T14:39:18.035Z",
"event": "alive",
"args": [
0
"time": "2022-06-30T14:39:18.044Z",
"event": "ready",
"args": []
"time": "2022-06-30T15:07:56.680Z",
"event": "value updated",
"args": [
"commandClass": 37,
"endpoint": 0,
"newValue": true,
"prevValue": false,
"time": "2022-06-30T15:07:56.681Z",
"args": [
"endpoint": 0,
"commandClass": 37,
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": true,
"valueChangeOptions": [
"transitionDuration"
"value": false,
"newValue": true,
"prevValue": false
"time": "2022-06-30T15:07:56.692Z",
"args": [
"commandClass": 48,
"endpoint": 0,
"newValue": true,
"prevValue": false,
"time": "2022-06-30T15:07:57.721Z",
"args": [
"commandClass": 37,
"endpoint": 0,
"newValue": true,
"prevValue": true,
"time": "2022-06-30T15:07:58.665Z",
"args": [
"commandClass": 37,
"endpoint": 0,
"newValue": false,
"prevValue": true,
"time": "2022-06-30T15:07:58.666Z",
"args": [
"nodeId": 13,
"commandClass": 37,
"endpoint": 0,
"newValue": false,
"prevValue": true,
"time": "2022-06-30T15:07:58.674Z",
"args": [
"commandClass": 48,
"endpoint": 0,
"newValue": false,
"prevValue": true,
"time": "2022-06-30T15:07:59.707Z",
"args": [
"commandClass": 37,
"endpoint": 0,
"newValue": false,
"prevValue": false,
"time": "2022-06-30T21:37:48.681Z",
"args": [
"endpoint": 0,
"property": 7,
"propertyKey": 16,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 1,
"default": 0,
"format": 0,
"states": {
"0": "Notification Report",
"1": "Sensor Binary Report"
"isFromConfig": true
"value": 0,
"newValue": 1,
"prevValue": 0
"time": "2022-06-30T21:37:49.725Z",
"args": [
"property": 7,
"propertyKey": 8,
"newValue": 0,
"prevValue": 0,
"args": [
"property": 7,
"propertyKey": 16,
"newValue": 1,
"prevValue": 1,
"time": "2022-06-30T21:42:37.014Z",
"args": [
"endpoint": 0,
"property": 7,
"propertyKey": 16,
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"valueSize": 1,
"min": 0,
"max": 1,
"default": 0,
"format": 0,
"states": {
"value": 1,
"newValue": 0,
"prevValue": 1
"time": "2022-06-30T21:42:38.055Z",
"args": [
"property": 7,
"propertyKey": 8,
"newValue": 0,
"prevValue": 0,
"time": "2022-06-30T21:42:38.056Z",
"args": [
"property": 7,
"propertyKey": 16,
"newValue": 0,
"prevValue": 0,
"hexId": "0x0131-0x0004-0x000a",
"dbLink": "https://devices.zwave-js.io/?jumpTo=0x0131:0x0004:0x000a:1.15",
"manufacturerId": 305,
"productId": 10,
"productType": 4,
"deviceConfig": {
"filename": "/usr/src/app/store/.config-db/devices/0x0131/ph-pse02.json",
"isEmbedded": true,
"manufacturer": "Zipato",
"label": "PH-PSE02",
"description": "Multisound Indoor Siren",
"devices": [
"productType": 4,
"productId": 10
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"paramInformation": {
"_map": {}
"productLabel": "PH-PSE02",
"productDescription": "Multisound Indoor Siren",
"firmwareVersion": "1.15",
"protocolVersion": 3,
"zwavePlusVersion": 1,
"zwavePlusNodeType": 0,
"zwavePlusRoleType": 5,
"nodeType": 1,
"endpointsCount": 0,
"endpointIndizes": [],
"isSecure": false,
"security": "None",
"supportsSecurity": false,
"supportsBeaming": true,
"isControllerNode": false,
"isListening": true,
"isFrequentListening": false,
"isRouting": true,
"keepAwake": false,
"maxDataRate": 100000,
"deviceClass": {
"basic": 4,
"generic": 16,
"specific": 5
"deviceId": "305-10-4",
"status": "Alive",
"interviewStage": "Complete",
"statistics": {
"commandsTX": 10,
"commandsRX": 6,
"commandsDroppedRX": 0,
"commandsDroppedTX": 0,
"timeoutResponse": 0,
"rtt": 26.1
"lastActive": 1656625358295,
"_name": "NodeID_13"
