I have an automation that I have deleted from the UI and automation.yaml but it keeps resurrecting itself like a zombie.
The Setup
I am using a blueprint
ZHA, deCONZ, Zigbee2MQTT - Ikea E1743 On/Off Switch & Dimmer Universal blueprint - all actions + double click events - control lights, media players and more with Hooks.
What I do
When I create an automation with this blueprint and only choose the first two items, that I"m using ZHA and choose which device is the controller. Everything is fine.
The Problem
But, when I add the first automation then the zombie returns. By zombie, I mean that I see an error in the logs that has text and actions from an automation I deleted weeks ago for that blueprint.
Here is that log:
Logger: homeassistant.components.automation
Source: components/automation/__init__.py:628
Integration: Automation (documentation, issues)
First occurred: May 6, 2021, 8:36:00 AM (4 occurrences)
Last logged: 3:13:51 PM
Blueprint Controller - IKEA E1743 On/Off Switch & Dimmer generated invalid automation with inputs OrderedDict([('integration', 'ZHA'), ('controller_device', '24092ae49411026bba2401479195a7f1'), ('action_button_up_short', [OrderedDict([('service', 'input_boolean.turn_off'), ('target', OrderedDict([('entity_id', 'input_boolean.guest_mode')]))]), OrderedDict([('service', 'notify.alexa_media'), ('data', OrderedDict([('message', 'Guest mode off.'), ('data', OrderedDict([('target', ['media_player.alexa_media_living_room_echo_dot', 'media_player.alexa_media_family_room_echo_dot'])]))]))])]), ('action_button_up_long', [OrderedDict([('service', 'input_boolean.turn_off'), ('target', OrderedDict([('entity_id', 'input_boolean.guest_mode')]))]), OrderedDict([('service', 'notify.alexa_media'), ('message', 'Guest mode off.'), ('data', OrderedDict([('type', 'tts')])), ('target', ['media_player.alexa_media_living_room_echo_dot', 'media_player.alexa_media_family_room_echo_dot'])])]), ('action_button_down_short', [OrderedDict([('service', 'input_boolean.turn_on'), ('target', OrderedDict([('entity_id', 'input_boolean.guest_mode')]))]), OrderedDict([('service', 'notify.alexa_media'), ('message', 'Guest mode on for 30 minutes.'), ('data', OrderedDict([('type', 'tts')])), ('target', ['media_player.alexa_media_living_room_echo_dot', 'media_player.alexa_media_family_room_echo_dot'])]), OrderedDict([('delay', OrderedDict([('hours', 0), ('minutes', 29), ('seconds', 0), ('milliseconds', 0)]))]), OrderedDict([('service', 'notify.alexa_media'), ('message', 'Guest mode will turn off in 1 minute. Press the green button to add 30 minutes.'), ('data', OrderedDict([('type', 'tts')])), ('target', ['media_player.alexa_media_living_room_echo_dot', 'media_player.alexa_media_family_room_echo_dot'])]), OrderedDict([('delay', OrderedDict([('hours', 0), ('minutes', 1), ('seconds', 0), ('milliseconds', 0)]))]), OrderedDict([('service', 'input_boolean.turn_off'), ('target', OrderedDict([('entity_id', 'input_boolean.guest_mode')]))])]), ('action_button_down_long', [OrderedDict([('service', 'input_boolean.turn_on'), ('target', OrderedDict([('entity_id', 'input_boolean.guest_mode')]))]), OrderedDict([('service', 'notify.alexa_media'), ('message', 'Guest mode on. Remember to press the red button when you leave.'), ('data', OrderedDict([('type', 'tts')])), ('target', ['media_player.alexa_media_living_room_echo_dot', 'media_player.alexa_media_family_room_echo_dot'])])])]): expected a dictionary for dictionary value @ data['action'][1]['choose'][1]['sequence'][2]['repeat']['sequence'][1]['target']. Got None extra keys not allowed @ data['action'][1]['choose'][1]['sequence'][2]['repeat']['sequence'][1]['message']. Got None
Blueprint Controller - IKEA E1743 On/Off Switch & Dimmer generated invalid automation with inputs OrderedDict([('integration', 'ZHA'), ('controller_device', '24092ae49411026bba2401479195a7f1'), ('action_button_up_short', [OrderedDict([('service', 'input_boolean.turn_off'), ('target', OrderedDict([('entity_id', 'input_boolean.guest_mode')]))]), OrderedDict([('service', 'notify.alexa_media'), ('message', 'Guest mode off.'), ('data', OrderedDict([('type', 'tts')])), ('target', ['media_player.alexa_media_living_room_echo_dot', 'media_player.alexa_media_family_room_echo_dot'])])]), ('action_button_up_long', [OrderedDict([('service', 'input_boolean.turn_off'), ('target', OrderedDict([('entity_id', 'input_boolean.guest_mode')]))]), OrderedDict([('service', 'notify.alexa_media'), ('message', 'Guest mode off.'), ('data', OrderedDict([('type', 'tts')])), ('target', ['media_player.alexa_media_living_room_echo_dot', 'media_player.alexa_media_family_room_echo_dot'])])])]): expected a dictionary for dictionary value @ data['action'][1]['choose'][0]['sequence'][0]['choose'][0]['sequence'][0]['default'][4]['default'][1]['target']. Got None expected a dictionary for dictionary value @ data['action'][1]['choose'][0]['sequence'][0]['default'][1]['default'][1]['target']. Got None extra keys not allowed @ data['action'][1]['choose'][0]['sequence'][0]['choose'][0]['sequence'][0]['default'][4]['default'][1]['message']. Got None extra keys not allowed @ data['action'][1]['choose'][0]['sequence'][0]['default'][1]['default'][1]['message']. Got None
Here is the automation that I created with the blueprint:
- id: '1620677465985'
alias: 'Button: Ikea on/off Guest Mode'
description: ''
use_blueprint:
path: EPMatt/ikea_e1743.yaml
input:
integration: ZHA
controller_device: 24092ae49411026bba2401479195a7f1
action_button_up_short:
- service: input_boolean.turn_off
entity_id: input_boolean.guest_mode
- service: notify.alexa_media
message: Guest mode off.
type: tts
- media_player.alexa_media_living_room_echo_dot
- media_player.alexa_media_family_room_echo_dot
action_button_up_long:
type: tts
Now… take a look at the log in the first error message (line 7) and you’ll see a reference to a message Guest mode will turn off in 1 minute. Press the green button to add 30 minutes. that is sent to media_player.alexa_media. Now look at the automation above. That’s not in there!
I did used to have that message in an old version of the Automation, but I deleted it and have restarted many times since then.
Also, when I add an action to the blueprint automation and save the automation, the UI shows the automation greyed out. But, before I add an action it is not greyed out.
Also, notice the name in the screenshot is different from the alias in the above blueprint automation
Button: Ikea on/off Guest Mode.
What I’ve tried
I’ve tried restarting, I’ve tried removing blueprint automation from the UI and the automations.yaml and restarting.
I’m at a loss
I’m really not sure where to look to find this zombie automation that keeps reappearing.
