Probably the api published the cost excluding taxes etc?
But to cut a long story short, Why not use the HA energy dashboard instead? It will do this for you, all thats required is a production/consumption sensor and a current price sensor. All of which the zonneplan api provides.
That’s true, but I would also like to place the costs on my own dashboards with power and solar panels information which I use more than the Energy dashboard. But maybe I’ll just use the Energy dashboard for this indeed.
I don’t have Zonneplan but i have a Solis Inverter. But if you are a bit handy you can change the sensors. Don’t look a the code it’s still a bit messy and a lot of things double :).
Not sure this is the right place to ask but I seem to have some trouble after installation. Except, there are no errors.
What happens is I do not get the P1 readings. I only see Zonneplan Yield Total Zonneplan P1 electricity consumption today Zonneplan P1 electricity returned today
I do have a working P1 connector that shows data using the DSMR Slimme meter integration. Enabling or disabling this integration does not make a difference fot this Zonneplan integration.
Cannot find this issue but perhaps I’m not as good in finding it. Please help.
No I haven’t. The P1 cable is from the Pi to the ‘slimme meter’. So I guess I also need DSMR slimme meter to read the P1 output. To me the Zonneplan ONE documentation was a little confusing because of this direct connection between my pi and the meter. Thought your software could read the ‘standard’ P1 output and combine it. My bad. I think I have it running now with these 5 sensors in combination with DSMR
Bedankt voor de code.
Nog wel een opmerking
Als je op tijd (de laagste prijs) een automatisering wilt starten werkt deze sensor niet.
Mijn weergave is 4:00 ipv 04:00
Nu is dat geen probleem maar ik wil op 04:00 een automatisering starten.
alvast bedankt voor het meedenken.
gr Nico
Voor het laden van de auto heb ik laagste prijs+0,5cnt waardoor hij alleen laadt op de goedkope tijden. Voor de vloerverwarmingen doe ik hetzelfde. Ik wil dat nog een keer spe
Het tijd schakelen heb ik inderdaad nog niet gebruikt. De vaat, was, en droger hebben uitgestelde tijd functie en zijn helaas nog niet smart.
Ik zal dit weekend de tijd optie uitproberen.
Dank voor je antwoord,
Je kunt het volgende met de vaatwasser of wasmachine proberen. Bij mij werkt dat.
Kies het programma wat je wilt op de vaat of wasmachine
Schakel de switch die de vaat of wasmachine onder spanning zet uit op je dashboard van Home assistant.
Als in de automatisering de juiste tijd langs komt gaat de switch aan.
Dus niet schakelen op prijs… maar op tijd.
Kan zijn dat jouw vaatwasser het ingestelde programma wist indien hij wordt uitgezet… is simpel te testen… door het instellen en daarna uit en 5 min wachten en dan aanzetten… staat het progr er nog in… dan werkt de automatisering.
Dank voor je inzet…
Gr . Nico
is het gelukt met de laagste prijs?
Ik zal vanavond nog een keer de apparaten bij langs maar ze zijn digitaal dus denk dat bij uitschakelen het geheugen weer gereset wordt.
Overigens wel meer werk, switch inschakelen, apparaat aanschakelen, instellen, apparaat uitschakelen en switch uitschakelen. Het is al heel wat dat mn vrouw de uitgestelde tijd wil instellen.
Mijn vaatwassen en wasmachine zijn ook digitaal.
En de vrouw is alleen te bewegen indien je zegt het is goedkoper en je kunt er na 2 jaar van op vakantie. Het is een leerproces. Ze houden niet zo van automatisering.
Even terug naar het probleem… het gaat om de sensor die moet tijd en of datum code in de data hebben staan. bv (2024-03-01T07:00:00+00:00)
in de zonneplan sensor staat die wel ( [sensor.zonneplan_current_electricity_tariff](
datetime: ‘2024-02-29T11:00:00.000000Z’
onderstaande code moet dan kunnen werken.
Om {{ as_timestamp(states(‘sensor.zonneplan_goedkoopste_tijd’)) | timestamp_custom(‘%H:%M’) }} uur is/was laagste energie tijd
