Zwave Devolo Danfos Thermostat
Hi Guys,
anyone have a same Radiator?
hvac_modes:
  - heat
min_temp: 7
max_temp: 35
current_temperature: 20.7
temperature: 7
node_id: 13
friendly_name: 'Devolo Home Control Radiator Thermostat: Heating 1'
supported_features: 1
I dont find a right hvac_mode to run it off?
this one doesnt work:
hvac_modes:
  - heat
  - 'off'
min_temp: 7
max_temp: 35
temperature: 7
node_id: 13
To turn it off I just set it to minimum temp which is 7 degrees.
Hi, sorry to dig up this thread again.
I myself use the aforementioned thermostat from Devolo and so far I had it connected to the gateway from Devolo and connected via the appropriate Intigration in Home Assistant.
Now I wanted to connect the thermostat via a Z-Wave stick (ZST10-700). I use Z-Wave JS UI and the Intigration Z-Wave JS WS Server.
Now I notice that the attributes of the thermostat are different:
Login via DEVOLO Intigration:
hvac_modes: heat
min_temp: 4
max_temp: 28
target_temp_step: 0.5
temperature: 22
friendly_name: xyz
Login via Z-Wave JS UI
hvac_modes: heat
min_temp: 7
max_temp: 35
current_temperature: 24.4
temperature: 7
friendly_name: xyz
Now the question is how I can adjust these attributes in Home Assistant. Because when I set the temperature to 4 C via Z-Wave JS UI, the thermostat also takes over the temperature.
But if I try to change the temperature via Entity, I can only set 7 C.
Can anyone tell me where the error lies here? respectively where can I set/correct the attributes in Home Assistant or is this a case for the developers of the integrations?
Thank you in advance for any feedback.
7 and 35 are the default min and max temps if a device does not report anything. You can override the values with customization.yaml.
thank sooo much…
That saves my day :slight_smile: I could have figured that out myself.
It works!
