Zwave dual relay switch status
HI
i am using zwave dual relay switch, Problem dual relay maunal way on/off dont update status in HA
same topis somebody already opened but no body reply is there no solution for such things
https://community.home-assistant.io/t/enerwave-rsm2-zwave-relay-status-update-issue/13186
any one please help us.
thanks
Hi
here is log on zwave plus that change status whe i try to on/off switch according to state below if zwave panel log on 2 different switch on dual relay with manual on/off
2017-04-03 14:15:09.329 Detail, Node003,   Received: 0x01, 0x0d, 0x00, 0x04, 0x04, 0x03, 0x07, 0x60, 0x0a, 0x01, 0x10, 0x01, 0x20, 0x25, 0x89
2017-04-03 14:15:09.330 Detail,
2017-04-03 14:15:09.330 Info, Node003, Received MultiChannelCapabilityReport from node 3 for endpoint 1
2017-04-03 14:15:09.330 Info, Node003,     Endpoint is not dynamic, and is a Binary Power Switch
2017-04-03 14:15:09.330 Info, Node003,     Command classes supported by the endpoint are:
2017-04-03 14:15:09.330 Info, Node003,         COMMAND_CLASS_BASIC
2017-04-03 14:15:09.330 Info, Node003,         COMMAND_CLASS_SWITCH_BINARY
2017-04-03 14:15:09.336 Detail, Node003,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x25, 0x03, 0xff, 0x2b
2017-04-03 14:15:09.338 Detail,
2017-04-03 14:15:09.338 Info, Node003, Received SwitchBinary report from node 3: level=On
2017-04-03 14:15:09.338 Detail, Node003, Refreshed Value: old value=false, new value=true, type=bool
2017-04-03 14:15:09.339 Detail, Node003, Changes to this value are not verified
2017-04-03 14:15:09.339 Detail, Node003, Notification: ValueChanged
2017-04-03 14:15:09.339 Info, Notification: Value Changed Home 0x0184d90c Node 3 Genre user Class SWITCH BINARY Instance 1 Index 0 Type bool
2017-04-03 14:15:10.462 Detail, Node003,   Received: 0x01, 0x0d, 0x00, 0x04, 0x04, 0x03, 0x07, 0x60, 0x0a, 0x01, 0x10, 0x01, 0x20, 0x25, 0x89
2017-04-03 14:15:10.463 Error, Node003, Received a Unsolicited MultiChannelEncap when we are not in QueryState_Instances
2017-04-03 14:15:10.468 Detail, Node003,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x25, 0x03, 0x00, 0xd4
2017-04-03 14:15:10.469 Detail,
2017-04-03 14:15:10.469 Info, Node003, Received SwitchBinary report from node 3: level=Off
2017-04-03 14:15:10.469 Detail, Node003, Refreshed Value: old value=true, new value=false, type=bool
2017-04-03 14:15:10.469 Detail, Node003, Changes to this value are not verified
2017-04-03 14:15:10.469 Detail, Node003, Notification: ValueChanged
2017-04-03 14:15:10.469 Info, Notification: Value Changed Home 0x0184d90c Node 3 Genre user Class SWITCH BINARY Instance 1 Index 0 Type bool
so how can i can get new state of switch ?
@rajkiran
Refer to my last post on the following thread:
The configuration I posted there should resolve the problem.
Hi
yes problem Solved
thanks
Hi
after update 0.42.4 its stop working any idea ?
I have not update to 0.42.4 yet … Not sure what happened … You should check the logs …
Here is Zwvae log its look ok but HA not chnaging status on GUI
2017-04-21 07:08:11.954 Info, Node003, Received SwitchBinary report from node 3: level=Off
2017-04-21 07:08:11.954 Detail, Node003, Refreshed Value: old value=true, new value=false, type=bool
2017-04-21 07:08:11.954 Detail, Node003, Changes to this value are not verified
2017-04-21 07:08:11.955 Detail, Node003, Notification: ValueChanged
Hi
yes solved i wrong something in setting now it working as old way.
thnks
