I’m having this issue too, driving me nuts because it’s messing with my HomeKit automations.
It’s especially bad when I go to lock my door by hand, this used to immediately update in Home Assistant and HomeKit, now either it just doesn’t work or is severely delayed.
After removing and re-adding my lock it worked perfectly for about 5 minutes then went back to acting up
I have similar problem. Previouslt everything was superfast. My lock is updating status, but does not respond to commands from HA. It looks like Z-wave network is having issues after update. Lights also respond 5-15 sec. Previously it was instant.
I use Danalock V3 Z-wave lock and USB Aeotec gen5 zwave stick.
I really hope someone finds solution.
I had this issues as well. I switched switch to zwavejstomqtt and all is good now. I noticed that a lot of my nodes were not routing correctly, even after a heal. I switched to zwavejstomqtt and they are all routing correctly and I’m able to see a network map. Not saying this is a solve but this helped for my situation.
