I’m trying to migrate to Zwave JS given that Zwave will soon be removed from Home assistant, but the migration fails. The migration wizard fails to start zwave JS and when I do that manually, all nodes are there but none except the Zwave stick can be reached.
I think the problem is that I did not have a network key set in the old config (from Yaml) and that breaks the flow. Could that be and how can I fix that?
I have a lot of zwave devices, it will be a lot of work to readd them manually (let alone adapting all my automations and scripts)…
