Is anybody able to get lovelace cast to work with different lovelace panels? When I got to cast.home-assistant.io and log in, I’m not shown the extra lovelace panels. The cast.show_lovelace_view service has a parameter for dashboard-path, but even trying to call the service with that doesn’t work.
Not sure if I’m doing something wrong or it’s just not working (wanted to check before opening a bug report).
Logger: pymodbus.client.asynchronous
Source: components/modbus/__init__.py:6
First occurred: 8:28:35 (1 occurrences)
Last logged: 8:28:35
Not Importing deprecated clients. Dependency Twisted is not Installed
Logger: homeassistant.setup
Source: components/modbus/__init__.py:207
First occurred: 8:28:36 (1 occurrences)
Last logged: 8:28:36
Error during setup of component modbus
File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/modbus/__init__.py", line 139, in async_setup
await hass.async_add_executor_job(start_modbus)
File "/usr/src/homeassistant/homeassistant/components/modbus/__init__.py", line 111, in start_modbus
client.setup()
File "/usr/src/homeassistant/homeassistant/components/modbus/__init__.py", line 207, in setup
loop=self._loop,
File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/serial.py", line 75, in __new__
yieldable = factory_class(framer=framer, port=port, **kwargs)
File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/factory/serial.py", line 104, in async_io_factory
client = AsyncioModbusSerialClient(port, proto_cls, framer, loop, **kwargs)
File "/usr/local/lib/python3.7/site-packages/pymodbus/client/asynchronous/asyncio/__init__.py", line 689, in __init__
self._connected_event = asyncio.Event()
File "/usr/local/lib/python3.7/asyncio/locks.py", line 249, in __init__
self._loop = events.get_event_loop()
File "/usr/local/lib/python3.7/asyncio/events.py", line 644, in get_event_loop
% threading.current_thread().name)
RuntimeError: There is no current event loop in thread 'SyncWorker_4'.
Well I did think the same but over the past 4-6 months I have looked for it several times (because this regularly has been a hot topic) but it has not turned up in my searching. Thanks for the suggestion anyway.
In generat got no issues with HomeAssistant upgrade (doker version). But starting with version 108.1, 108.2 the CPU utilization on Raspberry Pi 3, increased from 10% before, to 30% after upgrade. Anybody noticing the same ?
Thanks.
My broadlink switches also stopped working, except one of them.
After a lot of trying to figure it out I changed the string length of one packet and it started working again and I re-learned for another switch, after about 10 attempts I found one that works again.
It is strange that it doesn’t even send the packets it doesn’t like.
