Hi, I have the following problem after upgrade to the version 0.108.5. Vertical and horizontal stack are not working anymore. See attached print screen
Description of the problem:
The entities are displayed in the preview window but are not loaded in the main window
Tested on
a. OSX, Chrome
b. IOS native app
c. Android native app
I tried with different entities but the results were unchanged.
[Later edit] I made more tests and the root cause is the custom component card.
Yup happened to me on several installs (108, 108.3, 108.5). Iāve given up. Seems The google_calendar component has had an undocumented breaking change.
Iāve several addon in the sidebar that I see with an admin user. With a ānormalā user I donāt see a lot of them, but I see some.
Is there a way to hide also these others?
What can I do to help diagnose the system gradually slowing down issue?
Thereās nothing in my logs apart from some components/integrations I havenāt tidied up and my CPU/Memory usage stays pretty stable.
I have 2 broadlink RM Pro. One RM2 PRO and an RM4 Pro. RM2 works perfectly just from the first moment when I used it. After I upgraded HA to the latest version 0.108.6, I am not able to integrate RM4 Pro.
These are my settings from configuration.yaml
Each time when I press Check Config button I receive the following message:
Blockquote
Invalid config for [sensor.broadlink]: [type] is an invalid option for [sensor.broadlink]. Check: sensor.broadlink->type. (See ?, line ?).
Invalid config for [switch.broadlink]: value is not allowed for dictionary value @ data[ātypeā]. Got ārm4_proā. (See ?, line ?).
Can you help me please with some advises? I want to mention that RM4 PRO is already Registered in Broadlink app and has a fix IP.
[Later Edit]
I comment out type line from both blocks of code and I didnāt receive any error when I check the configuration. After reboot, the switch is not available and the sensors return the following state
After waiting for the Broadlink fix I have now found that HA version 108.6 with broadlink integration 13.1 has not fixed the issue of long IR codes not being sent by RM mini 3.
Yep! I was refreshing the damn supervisor page many times today waiting for .6 release to fix the broadlink integrationā¦
Very disappointed that itās not a fix at all, in fact I donāt even think whoever worked on the āfixā tested if it really fixed the problem of long codes not being sentā¦
