Another awesome update. Shame the WLED integration is borked and it floods the API on the ESP chip forcing it into a reboot loop. Issues raised on WLED and HA Githubs (by those more knowledgeable than me, I just +1 it)
A
After update to 108.6 Logger: custom_components.hysen.climate
Source: custom_components/hysen/climate.py:891
First occurred: 13:26:47 (1008 occurrences)
Last logged: 21:58:13
Failed to get Data from Broadlink Hysen Device:climate.th1,:name ācalculate_crc16ā is not defined
Failed to get Data from Broadlink Hysen Device:climate.th2,:name ācalculate_crc16ā is not defined
Soā¦ I was using a night theme at night and default theme at day, with automation doing the change with theme selected as: backend-selected.
Now that I updated to 0.108.6, my sidebar background does not turn dark with the themeā¦ and also none of the 3rd party āpanel_iframesā are inheriting the dark theme.
This fixed the sidebar, but as I was searching for the fronted.reload_themes service, I noticed that the combox list background also stays white (and panel_iframes still too).
So although this fixes a part of the issue, it seems that the āLovelace themesā breaking change broke a lot more.
So anyone from the developers made that breaking change can please elaborate on what we can do to make our themes work as before?
True, trueā¦ Corona-times unfortunately destroys my spare/HA time. Will see to it when things normalizeā¦ It could be a modbus problem, but it could also be a problem with the Flexit or climate integration (only thing I use modbus for at the moment).
For what itās worth, I just tested 108.6 on a test system with google calendar and magically it all worked fine.
Tried it on my production system, and all good.
So 108.6 ārestoresā the google_calendar functionality. I suspect by coincidence more than design than anything else - the last change was a breaking change for a bunch of components (#33794).
Anyone else seeing problems with AWS SNS? I noticed that my last text I received was on the day before this was released and I upgraded. I donāt see any errors when I execute an automation with an sns notify, but nothing is coming through to my phone now.
not sure if this tone of voice is getting you anywhere, anytime soonā¦please go with the flow, seek answers to your questions, and post what you find to help others. Itās what gets this project forward, and makes it even more wonderful than it already is.
