0.110: Speed! OpenZWave beta, HomeKit Cameras, ONVIF, Calendars
yeah, if you click on an plugin, its on the top right, but seems the button is missing …
you need to click on an invisible button, just scroll to top right , then you see your mouse icon changing
I have the same problem in firefox.
In the android app the icons are displayed.
I’m seeing the same issue in Firefox on Windows 10. Clearing site data, cached content and restarting the browser doesn’t appear to have any impact.
Please. tell me what i am doing wrong with internal and external link config? I have this config:
homeassistant:
  customize: !include include/customize.yaml
  external_url: "https://xxxxxxxxx.net:8123"
  internal_url: "http://192.168.51.3:8123"
http:
  ssl_certificate: ssl/fullchain.pem
  ssl_key: ssl/privkey.pem
There is ext and int link and ssl in http section. But internal link doesn’t work.
Thanks for help!
Don’t see such thing?
No issues with icons in latest Firefox on Ubuntu 18.04
Running 0.110.x since a few days (beta).
They where to small in some custom-cards (button-card, power-wheel) but this is fixed by the authors.
should be here :
Wow excellent upgrade - but I wonder where my Top panel has gone ? Now I only have a default panel view with “NO” additional panel in the top? Oh no - that’s huge work to recreate. Configuring default panel has also gone.
Ha! Brilliant. Thanks man!
Look one post up. :smiley:
I’m not using Custom Header - but might have installed the plugin
I fixed it, by unticking ‘Always use private browsing mode’ in Firefox.
OK, sticking with 0.109.6 until a finger gets pulled out from somewhere and changing icon/icon color dynamically is supported in the core now that this release breaks the (now deprecated) customizer integration that allows it
I fixed it by unticking ‘Always use private browsing mode’ in Firefox.
There’s a fix for custom-ui in this thread by @Mariusthvdb
Indeed after deactivating private browsing it correctly displays all icons.
However it is still kind of strange that i have to turn off private browsing for using the interface. In 0.109 this was no problem.
I click on update and a error occur:
Error: Unknown Error, see logs
Nothing in logs lol
What can i do to update?
Check the supervisor logs
Supervisor -> system -> logs
ERROR (SyncWorker_7) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.110.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on 127.0.0.53:53: read udp 127.0.0.1:32770->127.0.0.53:53: i/o timeout”).
Thanks.
What to do?
Too many problems with this new release:
A lot of error messages that I have to investigate and without notice !!!
Roomba is not working at all…
No possibility to go back to version 0.109.6… HA is not starting anymore !!!
Very annoying
2020-05-20 23:04:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experien$
2020-05-20 23:04:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experi$
2020-05-20 23:04:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for config_check which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you $
2020-05-20 23:04:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for customizer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you ex$
2020-05-20 23:04:02 WARNING (MainThread) [homeassistant.components.http] The 'base_url' option (with value '<mynetwork>') is deprecated, please remove it from your configuration
2020-05-20 23:04:05 ERROR (MainThread) [homeassistant.core] Error doing job: Unclosed client session
2020-05-20 23:04:07 ERROR (MainThread) [homeassistant.core] Error doing job: Unclosed client session
2020-05-20 23:04:14 ERROR (SyncWorker_9) [homeassistant.util.package] Unable to install package av==7.0.1: Failed building wheel for av
Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-rk_lufi0/av/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __fi$
2020-05-20 23:04:14 ERROR (MainThread) [homeassistant.setup] Setup failed for stream: Requirements for stream not found: ['av==7.0.1'].
2020-05-20 23:04:14 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for average which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you exper$
2020-05-20 23:04:15 ERROR (SyncWorker_19) [roomba.roomba] Error: [Errno 104] Connection reset by peer
2020-05-20 23:04:15 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for rpi_power which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you exp$
2020-05-20 23:04:16 ERROR (MainThread) [homeassistant.components.roomba] Timeout expired
2020-05-20 23:04:16 WARNING (MainThread) [homeassistant.config_entries] Config entry for roomba not ready yet. Retrying in 5 seconds.
2020-05-20 23:04:25 ERROR (SyncWorker_19) [roomba.roomba] Error: [Errno 104] Connection reset by peer
2020-05-20 23:04:26 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform mqtt is taking over 10 seconds.
2020-05-20 23:04:27 ERROR (MainThread) [homeassistant.components.camera] The onvif platform for the camera integration does not support platform setup. Please remove it from your config.
2020-05-20 23:04:38 ERROR (SyncWorker_11) [roomba.roomba] Error: [Errno 111] Connection refused
2020-05-20 23:04:38 ERROR (SyncWorker_11) [roomba.roomba] Unable to connect to 192.168.2.80
2020-05-20 23:04:38 ERROR (MainThread) [homeassistant.components.roomba] Error to connect to vacuum
2020-05-20 23:04:38 WARNING (MainThread) [homeassistant.config_entries] Config entry for roomba not ready yet. Retrying in 10 seconds.
2020-05-20 23:04:49 ERROR (SyncWorker_8) [roomba.roomba] Error: [Errno 111] Connection refused
2020-05-20 23:04:49 ERROR (SyncWorker_8) [roomba.roomba] Unable to connect to 192.168.2.80
2020-05-20 23:04:49 ERROR (MainThread) [homeassistant.components.roomba] Error to connect to vacuum
2020-05-20 23:04:49 WARNING (MainThread) [homeassistant.config_entries] Config entry for roomba not ready yet. Retrying in 20 seconds.
2020-05-20 23:05:10 ERROR (SyncWorker_12) [roomba.roomba] Error: [Errno 111] Connection refused
2020-05-20 23:05:10 ERROR (SyncWorker_12) [roomba.roomba] Unable to connect to 192.168.2.80
2020-05-20 23:05:10 ERROR (MainThread) [homeassistant.components.roomba] Error to connect to vacuum
2020-05-20 23:05:10 WARNING (MainThread) [homeassistant.config_entries] Config entry for roomba not ready yet. Retrying in 40 seconds.
2020-05-20 23:05:16 WARNING (SyncWorker_10) [homeassistant.components.tplink.switch] Could not read state for 192.168.2.61: Communication error
2020-05-20 23:05:17 ERROR (MainThread) [frontend.js.latest.202005190] <mynetwork>/hacsfiles/custom-header/custom-header.js:1:16344 Uncaught TypeError: Cannot read property 'style' of null
2020-05-20 23:05:35 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error in data received
  File "/usr/lib/python3.7/asyncio/sslproto.py", line 526, in data_received
    ssldata, appdata = self._sslpipe.feed_ssldata(data)
  File "/usr/lib/python3.7/asyncio/sslproto.py", line 207, in feed_ssldata
    self._sslobj.unwrap()
  File "/usr/lib/python3.7/ssl.py", line 767, in unwrap
    return self._sslobj.shutdown()
ssl.SSLError: [SSL: KRB5_S_INIT] application data after close notify (_ssl.c:2609)
2020-05-20 23:05:48 ERROR (MainThread) [frontend.js.latest.202005190] <mynetwork>/hacsfiles/custom-header/custom-header.js:1:16344 Uncaught TypeError: Cannot read property 'style' of null
2020-05-20 23:05:51 ERROR (SyncWorker_18) [roomba.roomba] Error: [Errno 111] Connection refused
2020-05-20 23:05:51 ERROR (SyncWorker_18) [roomba.roomba] Unable to connect to 192.168.2.80
2020-05-20 23:05:51 ERROR (MainThread) [homeassistant.components.roomba] Error to connect to vacuum
2020-05-20 23:05:51 WARNING (MainThread) [homeassistant.config_entries] Config entry for roomba not r
