0.110: Speed! OpenZWave beta, HomeKit Cameras, ONVIF, Calendars
Have you tried
hs core rebuild
take a look at this post
The worst update EVER. I don’t know if it’s problem between this update and HACS but many things are broken, not showing in lovelace dashboard etc. Hope it will be fixed in coming updates. Reverting back to 0.109.6 - even this not without problems.
ha core rebuild
Cogneato has said at least twice in various places that ‘HA supervised on Debian’ is a good choice going forward and I’m expecting that is not going to be depreciated on the basis of that.
many of us disagree. Perhaps operator error?
Did you update your custom cards?
Did you post your errors here and seek help?
No, looks like you just came here to moan. Good luck getting anything going by moaning.
My challenge is that usually want to have a 20s arming time, but in some cases I want to immediately trigger based on manual input.
Deprecated!
Depreciated: depreciation is what happens when you buy a car and 12 months later it is worth 30% less.
Deprecation is when a feature is about to be no longer supported, and you are discouraged from using it in future.
Operator? What? Reverted back and everything working just fine, so no - it’s a miss.
Yes, all of them. Also checked them in resources - everything seemed fine, but couldn’t load custom:stack-in-card/custom:button-card and probably few more which resulted in not seeing most of my cards.
No specific errors for cards issue. Only few hacs github 500 errors.
Learned by experience - it’s easier to wait. I have no time for troubleshooting something that was working just fine. Moaning takes much less time.
Troon - can you share the steps you took to upgrade your VENV version of python to 3.8.2?
Yeah, blaming the HA update for your custom components not working is normally a good solution. :+1:
Go and post issues on their gihub pages then.
Hs anyone still got issues with the Daikin integration? I updated to 0.110.1 and still cannot control my Daikin Airbase. It shows an an entity but no commands work for it. Worked perfectly in 0.109.6, no errors in logs that I can see either.
Have you turned logging level up for the integration?
I haven’t but have just found some info on GitHub, looks like it will be fixed in .2 so all good :slight_smile:
Then that’s an issue of the custom card, not the update.
Suggest you contact the developer of the custom card to update it to work with 0.110.
Actually upon investigation it is an HA problem that will be fixed in 0.110.2 - https://github.com/custom-cards/stack-in-card/issues/8 - so my bad on that.
Does the issue affect custom-button-card also?
Time will tell but what’s not being deprecated is firestrife’s claim that it’s the “docker installation method”.
I haven’t seen an issue posted on that github, but it is the same author :slight_smile:
