Has 0.112.5 been withdrawn ?
appeared this morning, I saw it around 7:00. I know it takes 2 hours to build, but now it is 14:42, and still no sign on docker hub ?
I am having the same problem. Have you solved it? I Cannot update from 0.110 to 0.112.4 because this is happenning.
Running it in a NUC with Ubuntu Server and Docker
Looks like it failed to build https://dev.azure.com/home-assistant/Core/_build/results?buildId=50770&view=results
Looks like there are tons of ‘libcec’ errors on the build log…
I also tryed to docker pull the update, and got the same version I already had, lol.
Not seeing the 112.5 update using supervisor? Did it get pulled?
It is being pulled. We have changes standing by for 0.113, which aren’t compatible with the builds for 0.112.5. We have decided the risk for fixing this now is to high for a patch release.
As a result 0.112.5 will only be available for people using the Home Assistant Core installation method.
I’m currently on 0.112.5 (Home Assistant Core in a venv). Will this cause me any issues if I update to the 0.113 Beta when it’s available?
No, it won’t cause any issues. Patch releases contain cherry picked things from the next release (0.113 in this case). Essentially, every patch release you are upgrading closer to the next release already.
Yes. I’m having the exact same issue. My MQTT broker appears to be receiving and sending msgs okay, but HA is ignoring…
Thanks for the info.
Yes indeed lots of libcec errors on the 112.5 build… explains why my update sensor hasn’t ticked off since reading the release notes for .5 yesterday. Oh well no love lost on my end… looks like the asuswrt patch hasn’t made it through yet anyways.
Hi all, I started 1.5 years ago with hassio. Last week I successfully updated to 112.4. Beside my broken blink integration I must say, that I never had such a smooth and stable HA version like this one. Nearly no issues in the logbook within 3 days. I thought first, that there must be something broken But no, simply running without any issues.
Guys, great job!! Congrats!.
From my point of view, we’re close to the first official release. That’s how it should work. Looking forward to the 113 improvements in automations and script. That makes fun
Thanks to all contributors and helpers and the great community.
And by the way, the last two upgrades saved money.
Before, I had the feeling, that I have to upgrade from RaspB3+ to Rasp4 due to performance issues.
During 111 and 112 the performance increased so rapidly, that I’m far away from updating the hardware
Sorry amazon
Is anyone else having an issue with the play_stream camera service? When I try and use the service to play to a chromecast device all I get is the chromecast emblem and no stream. The same automation worked fine in previous builds.
Quick question about combining entities in a condtions
Do they have to be the same type? For example could I include a light and a switch and in input boolean
- condition: state
entity_id:
- binary_sensor.withings_in_bed_me
- light.bedside_lamp
- switch.wall_plug
state: 'off'
I could not find any examples of such.
As far as I know, as long as all entities have exactly the same state type, it should work.
Simply test it out
You can mix them, no problem
Apparently since the July 14th update, my Smartthings Z-wave switches are being pressed on every 5-minutes. I’ve got no automation, script, routine associated with these switches and the only thing that has changed was an update to Release 0.112.5. If I disable the devices in HA, the lights operate normally, re-enabled? Every 5-minutes.
@frenck Would it be possible for future release notes, to include a link/anchor at the top of the blog entry, for added notes of minor versions?
That would be great and would safe a lot of scrolling. Thanks in advance
EDIT to clarify in contrary to the answered post above:
What I’m asking is a simple link inside the blog post , actually easy to copy and paste while writing the news . Nothing, that would need to be changed in code or so, just a link at the top, basically a html anchor.
