Followupā¦I upgraded to 0.115.1, and probably a few other things and now the custom cards are back.
I canāt say what action caused them to come back.
The mediabrowser is a very cool addition, is there a reason it doesnāt support (doesnāt show) symbolic links inside the /media directory? This is a common feature on Linux.
kodi issue fixed in 115.1
With the addition of the following, do I set homeassistant.core to debug?
Log template listeners when debug logging is on ([@bdraco](https://github.com/bdraco) - [#40180](https://github.com/home-assistant/core/pull/40180))
Iām having the same issue with container on a raspberry pi. Submitted an issue on github and it seems like others are seeing it as well. I rolled back to 0.115b1 and donāt have any problems.
Iām sorry I havenāt found the time yet to try what you suggested.
After updating to 0.115.1 I have enabled the debug logging and noticed that many requests came from the deConz integration, in fact after removing the usb dongle the cpu load dropped drastically returning to an average of 5%.
Now that I think I have identified the problem, however, I have no idea how to fix it.
homeassistant.event for the template logging
Google Home tts cloud seems broken (v0-115-1)
configuration.yaml:
tts:
- platform: google_cloud
key_file: <secret>.json
language: en-US
gender: female
voice: en-US-Wavenet-D
encoding: linear16
speed: 1.1
pitch: 0
gain: 0.0
profiles:
- medium-bluetooth-speaker-class-device
Log:
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 206, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 416, in _async_call_service_step
await self._async_run_long_action(service_task)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 375, in _async_run_long_action
long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1315, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1350, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 215, in service_handler
await script_entity.async_turn_on(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 320, in async_turn_on
await coro
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 944, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 198, in async_run
await self._async_step(log_exceptions=False)
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 413, in _async_call_service_step
await service_task
task.result()
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 167, in async_say_handle
url = await tts.async_get_url(
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 340, in async_get_url
filename = await self.async_get_tts_audio(
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 367, in async_get_tts_audio
data = self.write_tags(filename, data, provider, message, language, options)
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 470, in write_tags
tts_file["artist"] = artist
File "/usr/local/lib/python3.8/site-packages/mutagen/_file.py", line 74, in __setitem__
self.tags[key] = value
File "/usr/local/lib/python3.8/site-packages/mutagen/id3/_tags.py", line 339, in __setitem__
raise TypeError("%r not a Frame instance" % tag)
TypeError: 'en-US-Wavenet-D' not a Frame instance
I also notice a much higher CPU usage in 0.115 (~23%) than 0.114 (~10%).
I have some template sensors that count stuff, like lights on as in the code below. Should these be changed as well?
count_all_inside_lights_on:
# entity_id: sensor.time
friendly_name: 'Aantal lampen binnen aan'
icon_template: >
{% if is_state('group.inside_lights', 'on') %}
mdi:lightbulb-on
{% else %}
mdi:lightbulb-off
{% endif %}
value_template: >
{% set count = namespace(value=0) %}
{%- for entity_id in states.group.inside_lights.attributes.entity_id if states(entity_id) == 'on' -%}
{% set count.value = count.value + 1 %}
{%- endfor %}
{{ count.value }}
count_all_doors_open:
friendly_name: 'Aantal deuren open'
# entity_id:
# - binary_sensor.diepvriesdeur
# - binary_sensor.garagedeur
# - binary_sensor.keukendeur
# - binary_sensor.koelkastdeur
# - binary_sensor.tuindeur
# - binary_sensor.tuindeur_speelkamer
# - binary_sensor.tuinpoort_deur
# - binary_sensor.voordeur
icon_template: >
{% if states.binary_sensor | selectattr('state', 'eq', 'on') | selectattr('attributes.device_class', 'eq', 'door') | list | count | int > 0 %}
mdi:door-open
{% else %}
mdi:door-closed
{% endif %}
value_template: >-
{{ states.binary_sensor | selectattr('state', 'eq', 'on') | selectattr('attributes.device_class', 'eq', 'door') | list | count | int }}
Try turning on the debug logging for homeassistant.event
in 0.115.1 to see if its templates that are the issue so you donāt spent a lot of time optimizing templates if they arenāt the issue.
For count_all_inside_lights_on
, something like this would be more efficient:
{{ expand('group.inside_lights') | selectattr('state', 'eq', 'on') | list | count | int }}
Wow really nice release ! a lot of cool thing ! but Iām a bit lost ā¦ Am I suppose to be able to take Spotify music and lunch it on a google home ? or could It be a future feature that integrate something like spot cast ?
Ever since updating to version 0.114 my webOS integration stopped working. Did I miss any breaking change?
Works for me on 0.115, I have not changed anything since I added it in may/june (I think)
Not seeing anything in the logs with homeassistant.event set to debug.
That probably means the performance issue is somewhere else (not related to templates), and we will need a py-spy
to diagnose it.
I confirm. Itās the same for me.
await getattr(
await service_task
task.result()
TypeError: 'pl-PL-Standard-A' not a Frame instance
Iām still not able to get py-spy installed on pi, any alternative?
Linux hassbian 5.4.51-v7+ #1333 SMP Mon Aug 10 16:45:19 BST 2020 armv7l
system info:
Distro......: Raspbian GNU/Linux 10 (buster)
Kernel......: Linux 5.4.51-v7+
Uptime......: up 14 hours, 38 minutes
Load........: 0.86 (1m), 0.96 (5m), 0.99 (15m)
Processes...: 120 (root), 20 (user) | 140 (total)
CPU.........: ARMv7 Processor rev 4 (v7l)
Memory......: 271Mi used, 29Mi free, 925Mi in total
services:
home-assistant@homeassistant: active
Same here, HA has become completely unusable
The three most common options are:
pip install py-spy
cargo install py-spy
. (youāll need to install cargo first if its not already there via apk add cargo
or apt-get install cargo
or yum install cargo
)Same here, nothing in the logs.
Thx, changed these templates.
Will have a look at py-spy
