Wish I never pressed the update-button. Something is eating so much cpu I canāt get anything loaded anymore, canāt even access my configuration to edit it. This is going to be a long night, sucksā¦
I experimented with this, and was able to mount a network share by:
- SSHing into my HA server
- Creating a folder under the media folder
- Mounting a SMB share into it using the mount.cifs command
like this:
sudo mkdir <config path>/media/Movies
sudo mount.cifs //<server>/<share> <config path>/media/Movies -o user=<user>
After doing this, the Media Browser allowd me to view and play the videos in that folder.
I run Home Assistant Core on a Raspberry Pi, so this may not be possible if youāre using Home Assistant OS due to restrictions.
No dice with any of these,
Cloning into 'py-spy-v0.3.3-armv7-unknown-linux-gnueabihf.tar.gz'...
remote: Not Found
fatal: repository 'https://github.com/benfred/py-spy/releases/download/v0.3.3/py-spy-v0.3.3-armv7-unknown-linux-gnueabihf.tar.gz/' not found
With Cargo
error[E0658]: use of unstable library feature 'alloc': this library is unlikely to
--> /home/pi/.cargo/registry/src/github.com-1ecc6299db9ec823/target-lexicon-0.10
12 | extern crate alloc;
error: aborting due to previous error
For more information about this error, try `rustc --explain E0658`.
error: Could not compile `target-lexicon`.
warning: build failed, waiting for other jobs to finish...
error: failed to compile `py-spy v0.3.3`, intermediate artifacts can be found at `
Iāve upgraded to 115.1 but frontend fails to start due to
Sep 18 20:01:32 ha hass[11424]: 2020-09-18 20:01:32 ERROR (SyncWorker_17) [homeassistant.util.package] Unable to install package pillow==7.2.0: Failed building wheel for pillow
Sep 18 20:01:32 ha hass[11424]: Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-nc_bq8bb/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-drt01bn1/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.7/pillow" failed with error code 1 in /tmp/pip-install-nc_bq8bb/pillow/
Anyone else with the same issue? Iām on virtual env on debian inside LXC.
Update: just found it:
I have the exact same error.
Configuration invalid
Platform error tts.google_cloud - Error relocating /usr/local/lib/python3.8/site-packages/grpc/_cython/cygrpc.cpython-38-arm-linux-gnueabihf.so: backtrace: symbol not found
āāā
I have created bug for broadlink canāt connect. Please reply here, if you have same problem https://github.com/home-assistant/core/issues/40267
That was my conclusion too. I posted an issue on github.
Smooth install here way to go everyone!
I am using the standard installation (not sure what they are calling it now) on a Pi4.
I have my iphone and all of itās sensors in an area and it used to show up in my automatically generated lovelace dashboard but since the upgrade to 0.115.1 itās no longer there. Anyone else seeing this? Was it a design decision or is this something that would be a bug?
Not a bug, intentional. Mobile App entities are now hidden from the automatically generated Lovelace starting with this release. Was a design decision as the mobile apps have loads of sensors. It was creating lots of badges above your content in the generated view.
Any chance next version of HA is going to concentrate on fixing broken stuff?
Donāt get me wrong I really do appreciate new content but 0.114 broke so many thingsā¦ and now 0.115 came outā¦ and more stuff is not workingā¦ Tensorflow 2 is utterly useless since 0.114 came outā¦ So, I wonder how many months I need to wait before it is fixed and works like in 0.112.
Spotify in the media browser is showing a maximum of 48 albums for me. Is there a setting somewhere that controls this? Would like to be able to browse more than just the last 48 Iāve added?
This is also the case in the new releases - 48 seems to be the magic number. It doesnāt show more than that but there are more in the Spotify app.
Now the yr integration is removed I try to remove it from my setup.
The log and the configuration validation mention the following error: āPlatform error sensor.yr - Integration āyrā not found.ā
I searched everywhere, but I canāt find this integration in my configuration.yaml or any of the other yaml files.
What Iām I missing?
Do you have it anywhere in a sensor.yaml file ? Thatās where mine was hidden.
It indeed was. I checked the file, but when I opened it in visual studio code the file wasnāt at the top.
Thx!
there you go, caught me as well
Have posted a github issue?
its not broken for everyone, jeez. people so in a rush to update then complain. maybe wait a couple of days before hitting the button
If the dev of the tensorflow integration is awol or busy in RL then not a lot people can do, but why do others have to wait for stuff because of one integration they never use. You cant force other developers to look at something they know nothing about.
Huge amount of work and looks great. With the media browser, I cannot see .mkv files. .mp4 and .mp3 etc show and play fine - is there a way to also access .mkv media files?
