0.115: B-Day release! Media browser, tags, automations & WTH
Sounds like you are hitting the same issue I am: https://github.com/home-assistant/core/issues/39873
Where did you see the error message about the depreciated login?
chrome developer tools under the console tab and you can see the failures under the network tab
Can anyone get a condition like this to work?
conditions:
  - condition: numeric_state
    entity_id: sensor.test
    below: input_number.temperature_test_threshold
Because I cant. Issue:
In my case it was solved upgrading firmware… There was an update in my Shelly EM.
Check it… And good luck! :wink:
Wow guys, you’re really cooking on full gas, first 114 and now 115. Amazing releases of features.
Hi;
After updating from 112 to 115 my Xiaomi Switch does not work any more with Home Assistant.
But the behavior is curious: If I click the button the state doesn’t change, but if I see the info for this entity the change is registered.
Can anyone shed some light on this?
  - platform: event
    event_type: xiaomi_aqara.click
    event_data:
      event_id: binary_sensor.switch_xxxxxxxxxxxx
      click_type: single
Thank you very much for your help!
Thx, a restart thit the trick.
i’m running into an issue with mysensors
before the update everything was running fine, its still is but in my Log i have these errors
Logger: mysensors
Source: /usr/local/lib/python3.8/site-packages/mysensors/init.py:67
First occurred: 10:21:36 PM (1 occurrences)
Last logged: 10:21:36 PM
Not a valid message: too many values to unpack (expected 5)
and
Logger: mysensors.message
Source: /usr/local/lib/python3.8/site-packages/mysensors/message.py:58
Error decoding message from gateway, bad data received: 14;255;3;0;22;28;1;1;0;16;1
there were more but i tried to restart and updated to 0.115.2 but still see these errors
nothing changed from my end, but is there a place i should look into?
thanks
Yes the entities with, say, a click state, have been done away with and replaced with events.
I have found the issue causing the extra cpu load allthough there was nothing in the logs when turning on debug logging for homeassistant.event.
I had one template sensor which was using {{ states | ... }}. Once I removed that the cpu load is back to the 0.114 level. Wasn’t even using that sensor :see_no_evil: so not missing anything here. Thanks for the quick help.
Thanks nickrout;
Can you explain me how to configure my automations with the new feature?
How can I do to click the button and trigger an action?
Thank you again!
An event is also available as a trigger when using the UI automation editor.
is this new to HA 115, or didnt we get all sun.sun attributes in the more-info card before?
Improve performance of accessing template state by bdraco · Pull Request #40323 · home-assistant/core · GitHub should make these much faster in 0.116.
I have read the documentation you post.
I think I am already configuring my automation as an event.
I don’t find anything that I could be doing wrong.
My trigger has the following form:
  - platform: event
    event_data:
      click_type: single
See my post here:
I have the sonos integration, but when I click on the browser I just get " Local library not found."
Is there something that I need to do in order to get the media into HA?
That trigger code works for me. Are you sure the issue isn’t elsewhere in that automation?
I use zigbee2mqtt, so slightly different, but this is how I use the button in an automation.
# XIAOMI BUTTON #
- alias: Xiaomi Button
  initial_state: True
    platform: mqtt
    topic: 'zigbee2mqtt/0x00158d000155d403'
  condition:
    condition: template
    value_template: "{{ 'single' == trigger.payload_json.click }}"
    service: light.toggle
    entity_id: light.steps
