Any idea why RAM metrics of supervisor do not match the sensor.memory_use_percent?
The former says Core RAM 15% and Supervisor RAM 5.5% while the latter says 40%.
Hi
I was looking for the secondary info and thought I would get it with the LEDs but doesnt seem I have.
Have I missed something ?
Thanks Martyn
now this is new behavior… initially usage went down, but since 4 am look what happens:
accompanied with endless issues in the log:
2020-10-08 04:13:24 ERROR (Recorder) [homeassistant.components.recorder] Error executing query: Instance <States at 0xad86c580> is not present in this Session
2020-10-08 04:13:24 ERROR (Recorder) [homeassistant.components.recorder] Error saving events: Instance <States at 0xad86c580> is not present in this Session
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 442, in _commit_event_session_or_retry
self._commit_event_session()
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 497, in _commit_event_session
self.event_session.expunge(dbstate)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 1854, in expunge
raise sa_exc.InvalidRequestError(
sqlalchemy.exc.InvalidRequestError: Instance <States at 0xad86c580> is not present in this Session
anyone with a hint how to solve this?
Oh, WTH!!!. Without the posssibility to hide the header most of my smaller displays are worthless.
When will MCP23017 I/O Expander integration be fixed ?
As of 0.115.0 it does not work and 0.116.0 did not fix it
Here is github issue related to this: https://github.com/home-assistant/core/issues/40192
Yes it is the same behavior on RPI3+ venv core install
It happened when database purge was taken place (somewhere about 4:00 AM) .
Did not roll dice any further and reverted to stable 0.115.6
And not only CPU usage went up… RAM was eaten up as in 0.116 betas…
Best, JR
Thanks, already saw that but could not link it to my problem- need more coffee it seems
Hi, after this upgrade, logbook no longer working and got error in log
2020-10-08 09:46:02 ERROR (Recorder) [homeassistant.components.recorder] Error saving events: (sqlite3.IntegrityError) UNIQUE constraint failed: events.event_id
[SQL: INSERT INTO events (event_id, event_type, event_data, origin, time_fired, created, context_id, context_user_id, context_parent_id) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?)]
[parameters: ((2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 07:45:01.778246', '2020-10-08 07:45:02.313078', '2c1cf36a093a11ebb0a95bdf141d567b', None, None), (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 07:44:31.708647', '2020-10-08 07:44:32.225946', '1a30ab86093a11ebade6f39fa10ffd89', None, None), (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 07:44:01.837387', '2020-10-08 07:44:03.418719', '0862b309093a11ebb47a0dc8de6d89be', None, None), (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 07:43:31.369963', '2020-10-08 07:43:32.470243', 'f639b779093911ebb14e1b8e33b37505', None, None), (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 07:43:01.435675', '2020-10-08 07:43:02.798523', 'e462219d093911eba635e98de1f6f51a', None, None), (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 07:42:31.361601', '2020-10-08 07:42:32.225285', 'd2752b49093911ebbc7655cb5615dba5', None, None), (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 07:42:01.402016', '2020-10-08 07:42:02.797142', 'c099b8d6093911ebb71f671d2762dfe0', None, None), (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 07:41:31.355102', '2020-10-08 07:41:33.110167', 'aeb0e6be093911eb88205d413e5b1c52', None, None) ... displaying 10 of 606 total bound parameter sets ... (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 02:13:58.363361', '2020-10-08 02:13:59.010282', 'ec985fe1090b11eb98159f4ddf293b96', None, None), (2218486, 'state_changed', '{}', 'LOCAL', '2020-10-08 02:13:28.367851', '2020-10-08 02:13:29.010333', 'dab76c02090b11eb8a9b3dbb77efcf83', None, None))]
(Background on this error at: http://sqlalche.me/e/13/gkpj)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1256, in _execute_context
self.dialect.do_executemany(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/default.py", line 590, in do_executemany
cursor.executemany(statement, parameters)
sqlite3.IntegrityError: UNIQUE constraint failed: events.event_id
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 493, in _commit_event_session
self.event_session.flush()
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2523, in flush
self._flush(objects)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2664, in _flush
transaction.rollback(_capture_exception=True)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/langhelpers.py", line 68, in __exit__
compat.raise_(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/compat.py", line 182, in raise_
raise exception
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py", line 2624, in _flush
flush_context.execute()
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/unitofwork.py", line 419, in execute
n.execute_aggregate(self, set_)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/unitofwork.py", line 521, in execute_aggregate
self.execute(uow)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/unitofwork.py", line 586, in execute
persistence.save_obj(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/persistence.py", line 239, in save_obj
_emit_insert_statements(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/persistence.py", line 1083, in _emit_insert_statements
c = cached_connections[connection].execute(statement, multiparams)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1011, in execute
return meth(self, multiparams, params)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/sql/elements.py", line 298, in _execute_on_connection
return connection._execute_clauseelement(self, multiparams, params)
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1124, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1316, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1510, in _handle_dbapi_exception
util.raise_(
raise exception
sqlalchemy.exc.IntegrityError: (sqlite3.IntegrityError) UNIQUE constraint failed: events.event_id
Anyone tried to get te MQTT tag scanner to work? I tried the example given on the MQTT Tag Scanner page but I’m not getting any resutls yet
Someone have problems with MQTT all my devices ar gone.Rollback to 115.6 and MQTT working
The same errors appear in my log.
Error saving events 5272 times
Error executing query: 5272 times
since yesterday evening at 22:26 o’clock when I installed 0.116.0
Upgrading to 116 caused all my Vera entities to be rediscovered and recreated - that’s a breaking change. I’ve since rolled back to 115
There is a recorder problem in 0.116.0. Appears to be solved and will be released in 0.116.1.
For now, I have rolled back to 0.115.6.
Just for info - I just installed 116.0 and got this:
For me it is not working along with other custom cards (ie Weather Card)
I’ll give that a try Tim. I’ve already rolled back to my 0.115.6 snapshot. I’ll delete Vera, upgrade to 0.116.0 and see what happens.
Update: I deleted the Vera integration, then updated to 0.116.0 and then re-added the Vera integration. I had 3 entities to repair (switches that I class as lights) all I had to do was delete the switch_ part of the description and all was good. Much better than having to deal with a duplicate of every Vera entity.
Thanks for the tip Tim
Exactly the same issue here…
- title: Lights
path: default_view
type: vertical-stack
cards:
- type: entities
title: Lights
entities:
- type: custom:text-divider-row
text: Kitchen
- group.kitchen_lights
- light.light_kitchen_window
- type: custom:slider-entity-row
entity: light.light_kitchen
toggle: true
entity: light.bar
toggle: true
text: Living
- group.living_lights
Not sure if it is related to custom:text-divider-row
I also went back to 0.115.6
Pretty disappointing that nobody takes the time to look at the SmartThings and HomeConnect integrations.
Cheers Tim your method worked a treat
