Unfortunately it’s nothing on HA end, Google added a captcha to the service and it remains to be seen if it can be fixed and work as usual or if you’ll need to look for a new solution.
The only things that are playing for you are the .mp3 files that it got before the service went down.
In my case I switched over to Google Cloud and the voice is a lot better. If you pay Nabu Casa you can also use their TTS but not many many languages are supported.
One issue I have seen come up but not a major concern is with the Withings integration. It all of a sudden start re-asking for permissions for each user. Not a big deal since it is just going to the site and authorizing HA to access the data but I just noticed it ever since the 0.117 update started. In addition, Amazon Alexa integration keeps losing the 2FA permission every so often. Before you just put in the 2FA code all was good, it didn’t drop.
Please fix Yeelights. They are not working if they are on a separate VLAN as pointed out in this post: Yeelight in 0.115 not working
I’m not aware of any workaround solving this particular issue as of yet. So i’m stuck at 0.114.4 for now.
Yeah, my ZHA is working currently. I found out why it wasn’t working for me in the first place on this update.
So I run my HA on docker in Ubuntu. I have both Aeotec Gen 5 Z-wave stick and Conbee II as a hub for both z-wave and zigbee respectively. What I found out was the Conbee II stick wasn’t passed to the docker container like it normally would without sudo. So all I had to do was run the docker on sudo. Not sure why this is happening as the zwave stick was passed fine without.
Hi all,
Tasmota integration generates message errors for every offline object.
I know this is a beta, so this is a point to consider for improvement.
Bye!
Logger: homeassistant.util.logging
Source: util/logging.py:108
First occurred: 1:11:25 (5 occurrences)
Last logged: 1:11:26
Exception in discovery_message_received when handling msg on ‘tasmota/discovery/2462AB4CA783/config’: ‘{“ip”:“192.168.1.102”,“dn”:“Stufa Nunki”,“fn”:[“Stufa Nunki”,null,null,null,null,null,null,null],“hn”:“aaa000-1923”,“mac”:“2462AB4CA783”,“md”:“Sonoff Basic”,“ofln”:“Offline”,“onln”:“Online”,“state”:[“OFF”,“ON”,“TOGGLE”,“HOLD”],“sw”:“8.5.1”,“t”:“aaa000”,“ft”:"%prefix%/%topic%/",“tp”:[“cmnd”,“stat”,“tele”],“rl”:[1,0,0,0,0,0,0,0],“swc”:[-1,-1,-1,-1,-1,-1,-1,-1],“btn”:[0,0,0,0],“so”:{“11”:0,“13”:0,“17”:0,“20”:0,“30”:0,“68”:0,“73”:0,“80”:0},“lk”:1,“lt_st”:0,“ver”:1}’ Traceback (most recent call last): File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 174, in discovery_message_received payload = TasmotaDiscoveryMsg(json.loads(payload)) File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 133, in init config = TASMOTA_DISCOVERY_SCHEMA(config) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 272, in call return self._compiled([], data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 594, in validate_dict return base_validate(path, iteritems(data), out) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: required key not provided @ data[‘so’][‘82’]
Exception in discovery_message_received when handling msg on ‘tasmota/discovery/68C63A9D3349/config’: ‘{“ip”:“192.168.1.199”,“dn”:“Luci Nunki”,“fn”:[“Tasmota”,null,null,null,null,null,null,null],“hn”:“lucinunki-4937”,“mac”:“68C63A9D3349”,“md”:“Sonoff Basic”,“ofln”:“Offline”,“onln”:“Online”,“state”:[“OFF”,“ON”,“TOGGLE”,“HOLD”],“sw”:“8.5.1”,“t”:“lucinunki”,“ft”:"%prefix%/%topic%/",“tp”:[“cmnd”,“stat”,“tele”],“rl”:[1,0,0,0,0,0,0,0],“swc”:[-1,-1,-1,-1,-1,-1,-1,-1],“btn”:[0,0,0,0],“so”:{“11”:0,“13”:0,“17”:0,“20”:0,“30”:0,“68”:0,“73”:0,“80”:0},“lk”:1,“lt_st”:0,“ver”:1}’ Traceback (most recent call last): File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 174, in discovery_message_received payload = TasmotaDiscoveryMsg(json.loads(payload)) File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 133, in init config = TASMOTA_DISCOVERY_SCHEMA(config) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 272, in call return self._compiled([], data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 594, in validate_dict return base_validate(path, iteritems(data), out) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: required key not provided @ data[‘so’][‘82’]
Exception in discovery_message_received when handling msg on ‘tasmota/discovery/68C63A9D38E6/config’: ‘{“ip”:“192.168.1.196”,“dn”:“CH4N1”,“fn”:[“Tasmota”,“Tasmota2”,“Tasmota3”,“Tasmota4”,null,null,null,null],“hn”:“ch4n1-6374”,“mac”:“68C63A9D38E6”,“md”:“Sonoff 4CH Pro”,“ofln”:“Offline”,“onln”:“Online”,“state”:[“OFF”,“ON”,“TOGGLE”,“HOLD”],“sw”:“8.5.1”,“t”:“ch4n1”,“ft”:"%prefix%/%topic%/",“tp”:[“cmnd”,“stat”,“tele”],“rl”:[1,1,1,1,0,0,0,0],“swc”:[-1,-1,-1,-1,-1,-1,-1,-1],“btn”:[0,0,0,0],“so”:{“11”:0,“13”:0,“17”:0,“20”:0,“30”:0,“68”:0,“73”:0,“80”:0},“lk”:1,“lt_st”:0,“ver”:1}’ Traceback (most recent call last): File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 174, in discovery_message_received payload = TasmotaDiscoveryMsg(json.loads(payload)) File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 133, in init config = TASMOTA_DISCOVERY_SCHEMA(config) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 272, in call return self._compiled([], data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 594, in validate_dict return base_validate(path, iteritems(data), out) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: required key not provided @ data[‘so’][‘82’]
Exception in discovery_message_received when handling msg on ‘tasmota/discovery/68C63A9D32B6/config’: ‘{“ip”:“192.168.1.195”,“dn”:“Stufa Nunki”,“fn”:[“Tasmota”,“Tasmota2”,null,null,null,null,null,null],“hn”:“stufanunki-4790”,“mac”:“68C63A9D32B6”,“md”:“Sonoff Dual R2”,“ofln”:“Offline”,“onln”:“Online”,“state”:[“OFF”,“ON”,“TOGGLE”,“HOLD”],“sw”:“8.5.1”,“t”:“stufanunki”,“ft”:"%prefix%/%topic%/",“tp”:[“cmnd”,“stat”,“tele”],“rl”:[1,1,0,0,0,0,0,0],“swc”:[-1,-1,-1,-1,-1,-1,-1,-1],“btn”:[0,0,0,0],“so”:{“11”:0,“13”:0,“17”:0,“20”:0,“30”:0,“68”:0,“73”:0,“80”:0},“lk”:1,“lt_st”:0,“ver”:1}’ Traceback (most recent call last): File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 174, in discovery_message_received payload = TasmotaDiscoveryMsg(json.loads(payload)) File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 133, in init config = TASMOTA_DISCOVERY_SCHEMA(config) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 272, in call return self._compiled([], data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 594, in validate_dict return base_validate(path, iteritems(data), out) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: required key not provided @ data[‘so’][‘82’]
Exception in discovery_message_received when handling msg on ‘tasmota/discovery/ECFABC5949A9/config’: ‘{“ip”:“192.168.1.197”,“dn”:“CH4N2”,“fn”:[“Tasmota”,“Tasmota2”,“Tasmota3”,“Tasmota4”,null,null,null,null],“hn”:“ch4n2-2473”,“mac”:“ECFABC5949A9”,“md”:“Sonoff 4CH Pro”,“ofln”:“Offline”,“onln”:“Online”,“state”:[“OFF”,“ON”,“TOGGLE”,“HOLD”],“sw”:“8.5.1”,“t”:“ch4n2”,“ft”:"%prefix%/%topic%/",“tp”:[“cmnd”,“stat”,“tele”],“rl”:[1,1,1,1,0,0,0,0],“swc”:[-1,-1,-1,-1,-1,-1,-1,-1],“btn”:[0,0,0,0],“so”:{“11”:0,“13”:0,“17”:0,“20”:0,“30”:0,“68”:0,“73”:0,“80”:0},“lk”:1,“lt_st”:0,“ver”:1}’ Traceback (most recent call last): File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 174, in discovery_message_received payload = TasmotaDiscoveryMsg(json.loads(payload)) File “/usr/local/lib/python3.8/site-packages/hatasmota/discovery.py”, line 133, in init config = TASMOTA_DISCOVERY_SCHEMA(config) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 272, in call return self._compiled([], data) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 594, in validate_dict return base_validate(path, iteritems(data), out) File “/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py”, line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: required key not provided @ data[‘so’][‘82’]
