Searched for it:
Didn’t know there is light group. I only knew “group”
thanks for the eye opener!
Searched for it:
yes, posted here
I raised an issue regarding that during the beta:
Same for me here. After a few hours 0.117.1 Home Assistant stops working on my Proxmox. I also went back to 0.116.4.
I haven’t seen it made explicit during this thread but…
Do we have to completely remove the deprecated Custom Header from HA before we update to this version? Or will other functionalities of CH still work along with the new built-in minimized header?
Ch still working fine
Updated from 116.4 to 117.2 today. I noticed markdown works different now. There is a stylesheet variable with height: 100%
that overrides card mod styling (I have height: 30px
on ha-card to make it smaller. Is there a way to remove that? I tried using !important
in my styling. This kinda works, but is very hacky and the UI jumps when reloading page.
Also: I noticed I can now pinch to zoom on iOS app (same as using a browser). This is pretty bad when using double tap because then it zooms in… You can now pinch to zoom/ zoom out the entire lovelace view on iOS. I hope this is a bug and not a feature…
I’ll restore my snapshop for now. I hope I can find a way to properly style the card height and the iOS zoom ‘feature’ gets patched in a future update.
Awesome! Good to hear!
Hopefully the functions I want will be put in HA core before CH completely dies.
Mainly just better control over user access to views/tabs (the current “visibility” functionality is a bit lacking and kludgy) and the ability to turn on & off view/tab visibility completely for everyone thru the back end (or in some other dynamic way like a “conditional card” for views/tabs).
I have a bunch of tabs I don’t always want to see cluttering up my dashboard but I still need them to show up occasionally as needed.
Since @mayker is officially in the HA dev team now, consider this a FR, please?
yeah, in fact, really only the header size has been introduced into core now.
All other functionality we could simply set using an input_boolean or a template is lost on us now (well not exactly now, because it still completely works, but officially it is…). Which is a true bummer.
as a matter of fact, I’ve just posted a small thingy on the card-theme thread of card-mod. Which isnt anywhere near the functionality of CH of course, but the only thing we have for now.
Really hope we can have the Options options, the exceptions, which you are referring to here and the builtin variables back, anytime soon in a new custom add-on, or preferably core of course.
I am on Proxmox, too with a Debian VM running Docker. I only have seen a Raspberry user @SiriusGen claiming similar issues with post 0.117.0 continual memory increase.
There is a post that ONVIF could be resonsible. Are you on ONVIF? I am.
I assume you mean 0.117.2. Trouble is, the latest seems to be 0.117.1
True!
sorry for my late reply.
No, I only see it the issue only in the home assistant app or the safari mobile view on my iphone and ipad
Hi, since update 0.117 I have a bad thermostat card, see picture. Thanks
Hello, is the REST problem fixed with version 1.117.2?
I don’t dare reactivate my sensor …
thank you
No REST platform is still bad! I need this fix. I have lots of rest sensor. After upgrade :ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
All my REST sensors are running fine without any issues. What error did you get? And please also show the code of the non-working sensor.
When running “Check Home Assistant configuration” to check 0.117.2 I get this error. This error does not show on 0.117.1.
aiohttp 3.6.2 requires multidict<5.0,>=4.5, but you'll have multidict 5.0.0 which is incompatible.
[12:36:07] INFO: Installed Home Assistant 0.117.2
[12:36:07] INFO: Making a copy of your configuration for checking...
[12:36:07] INFO: Checking your configuration against this version...
[12:36:34] ERROR: The configuration check did not pass!
[12:36:34] ERROR: See the output below for more details.
Testing configuration at /tmp/config
Fatal error while loading config: (multidict 5.0.0 (/usr/local/lib/python3.8/site-packages), Requirement.parse('multidict<5.0,>=4.5'), {'aiohttp'})
Failed config
General Errors:
- (multidict 5.0.0 (/usr/local/lib/python3.8/site-packages), Requirement.parse('multidict<5.0,>=4.5'), {'aiohttp'})
Anything to be concerned about?
