OMG, the Entities quick search bar is FANTASTIC. Thank you, thank you!!! Been wanting something like that for quite some time.
Heads up for anyone that checks - I’m having trouble with the Daikin integration after updating.
Did Swipe Navigation go away?
For Compact Header, I would love a couple more Theme options, in addition to header-height:
- Ability to remove the carats to left and right of the tabs (when there are too many tabs to show on the screen)
- Ability to remove the ‘three vertical dots’ to the right of the header.
Those would free up enough Horizontal space for all my tabs to fit on my phone just perfectly.
No, it’s broken, look in the issues.
You can create a different user for your phone, and hide enough tabs for that user to remove the carats.
oh no! can you tell me more about what you’re seeing? that would 100% prevent me from updating.
This is a great update!
Favorite feature so far is the entity picker, very helpful when having multiple of the same ZWave Devices!
Thanks Devs!
thanks for fixing Efergy ! love it love it love it
Looks like there’s an undocumented breaking change for Daikin units that use an API Key rather than password (BRP072Cxx and Skyfi devices)
I had to delete and recreate them and they’re working again. The breaking change is noted on the PR but didn’t make it into the release notes.
Thanks. I missed the issues section.
If you are looking for an alternative to the BOM platform, please add my repo to HACS, it is using the new BOM API and avoids FTP and webscraping.
Looks like the Xbox gamer score is missing a unit_of_measurement.
Legend! thanks mate
Quick Bar. It can be launched anywhere in Home Assistant; with the keyboard shortcuts
e
for entities andc
for commands. You can switch between the entities and command modes by removing or adding the>
at the start of the search input.
This is very nice but I’m not sure if one-letter shortcuts are great. I would think a shortcut like cmd+k
(or equivalent on non-Mac platforms) might be more reasonable. It’s pretty standard in various communication apps like Slack or Discord.
This got talked about in a PR. Look in the betas release notes to see when it got changed. It was originally Ctrl+P and Ctrl+Shift+P.
I see that it was changed in https://github.com/home-assistant/frontend/pull/7496 but I don’t see why.
Also, single-letter shortcuts seem to be causing issue https://github.com/home-assistant/frontend/issues/7517 which was the kind of thing I was concerned about.
Anyone tried to install manually the xbox integration? It gives me error immediatly
Use a separate lovelace dashboards for desktop/mobile.
https://www.home-assistant.io/lovelace/dashboards-and-views/
Can’t add xbox via integrations neither:
No login box appears.
